    Sketchup is Inacurrate???
    513 Posts 38 Posters 60.6k Views 38 Watching
      The beauty of the V6 is that anybody can reload it! (v6v7v8) πŸ‘
      The Follow Me and Keep gives the same result! πŸ˜„
      • jeff hammondJ Offline
        most of the plugins do unless they are specifically designed to work properly.
        shapebender shows the error. roundCorner avoids the error..
        try putting a round edge on a cube using followme.. then do the same thing with roundCorner.
        see the difference?
        [edit]-- i should add however that roundCorner only 'fixes' this issue in one circumstance.. in others, it will still give the same error as followme..
          david.
          Re: the utube, that definitely looks like a problem. It seems the Follow Me version used a different (incorrect) arc radius of 10.0215cm and that arc center point is offset by 0.6554cm from the correct center point. In certain applications, that could be a serious issue. IMO, this should be submitted to Google as a bug.
            hi david.. it's not a bug per se.. there are basically 2 ways to draw/build that pipe… one is by bending (in which case you would use an arc for the followme path… the other way to build it would be to take one length of straight pipe then miter cut it into a bunch of individual pieces then weld them together.. like this:
            and sketchup has accurately depicted this scenario in the .skp i posted..
            the problem is that my model used an arc in the path as opposed to straight lines, in which case, the results would be different..
            but regardless of my input being an arc or straight lines, sketchup treats both of them the same… it ignores the fact that i have an arc..
              oh.. and i think i should reiterate what my original post(s) in this thread were meant to say..
              you can accurately draw this shape, as a bend, in sketchup..
              in the utube case, i'd push/pull the straight sections to 20cm then use TIG's lathe.rb, anchored at the cpoint shown in the .skp to form the semi-circle.. the lathe plugin set to 180ΒΊ and 12 segments would leave me with geometry that exactly matches the profile array in scene3..
              my main point is this: do not use offset or followme on arcs/circles/curves and expect accurate results.. if accuracy is important, use other methods to obtain the precision you require..
              if all you need to do is draw a representation of said object and accuracy isn't important, feel free to use offset and followme.. they are generally the fastest way to go about it..
                david.
                Yes, you are correct. It can't be said to be a bug with any certainty. However, the algorithm being used seems to do something other than what I would expect in this case.
                  even then, the algorithm is working just fine (for offsetting shapes which consist of straight edges..).. but now that some people are starting to see this offset error, the topic can maybe shift to why the error occurs and realize how simple it is to fix it..
                  the process of offsetting isn't difficult at all and it's just simple movement of geometry.. this is why i said earlier that i feel this issue is totally fixable in sketchup.. it's not as if offsetting requires some sort of complex mathematical equation which is failing in certain circumstances.. the problem or inaccuracies occur because of a human choice to ignore 'arcs'.. (ie- it's not that there's a 'bad' algorithm for offsetting.. the problem is that there's no algorithm to begin with for dealing with arcs)
                  here are a couple of pictures that attempt to illustrate what exactly is happening when offsetting.. the first picture shows how sketchup offsets in all situations.. the second shows how sketchup should offset in the case of an arc..
                  click pic -> bigger
                  The next picture shows what sketchup should (and could) do if it recognizes an arc as part of the path…
                  click pic -> bigger
                  if it's a line, move the line… if it's an arc, move the vertices β˜€
                  if a user wants to offset in a manner of the first image and they have an arc in the path, they simply explode the arc prior to offsetting..
                  [ in the same way you would have to explode a 'triangle' created with the so called polygon tool prior to doing anything with it.. a triangle created with the polygon tool is actually a circle being represented by 3 points on the circumference.. entity info of this 'triangle' returns a circle's circumference as opposed to the length of the three sides.. push/pulling this 'triangle' results in softened edges etc.. it's a circle - not a triangle.. if you want to use it as a triangle then you have to explode it first.. (but i guess this is for a different thread πŸ˜‰ )
                  • Rich O BrienR Online
                    Here you go Frenchy....
                    Error 404 (Not Found)!!1
                    (sketchup.google.com)
                    Join our club
                      oh.. with the utube example, scene8 was an attempt at making people realize the connection between the offset tool and follow me..
                      i don't think i nailed it with that example but the following file should, without a doubt, make people see how these two tools are so closely related that it doesn't matter if we speak about them interchangeably.. (i know i keep flip flopping between offset and follow me in my examples.. i just want people to understand that talking about one of these tools applies directly to the other.. it doesn't matter which tool we're talking about.. they work exactly the same and they both ignore arcs..
                      v6
                        You forget me πŸ˜‰
                        oops.. changed the file in the post to v6
                          You forget me πŸ˜‰
                            Thx πŸ˜„
                            On a same plan
                            A funny thing : you can't offset one segment
                            You can Offset 2 segments not welded but touching them
                            You can't Offset 2 separated sets of 2 segments not merged but touching them
                            @Rich : not on this too old computer πŸ˜‰
                              Thx πŸ˜„
                              right, but it makes total sense in sketchup.
                              it simply has no way of knowing which direction you want to offset if there's only a single line. with more than one line, you've defined a plane so sketchup now knows which direction to go.
                                So maybe Radial lines or Radial Lines Fixed Length by Tig can help πŸ˜‰
                                http://forum.zbrush.fr/index.php?action=dlattach;topic=1622.0;attach=13997;image
                                http://forum.zbrush.fr/index.php?action=dlattach;topic=1622.0;attach=13998;image
                                here only Font faces were selected! (Snap is automatic ! )
                                select a CPoint + something then call the plug
                                Sand Box from scratch for draw lines extremities + some CleanUp/erase πŸ’š
                                And finally normal Offset for straight lines πŸ˜„
                                Projections by Didier Bur or Thomthom Guides Tools for Put CPoints at some positions
                                And if you have exploded some arcs : Explode arcs centerpoint finder by Chris Fullmer πŸ˜‰
                                • ely862meE Offline
                                  ely862me
                                  I'm working at the moment on some very small components and...yes sketchup is not accurate. When I draw some lines, sketchup grabs the lines from different lines,changes lengths,creates some other lines, hides lines.. as it's no able to work with small faces.
                                  Beside that, orbiting or zooming in in small components it's a pain- the clipping/ disappearing objects issue makes i even harder .
                                  Elisei (sketchupper)
                                  Come and See EliseiDesign
                                  • DesertRavenD Offline
                                    DesertRaven
                                    [off:ywwrl90u]@jeff hammond EdIT -- the thread was bumped at this point.. conversation is now 9 months later than eli's post[/off:ywwrl90u]
                                    The offset tool is not just a wee tad off, it is way off! And I see no reason why it should not be just fixed. Even if I use this as a conceptual tool only, there are underlying errors that one does not catch right away, only way down the road. I say the programming of the core of sketchup is just straight out sloppy and does, in many cases, not follow geometrical accuracy.
                                    These issues should be honestly sought out, admitted and disclosed to anyone who considers using it to make a living.
                                    By playing these errors down or ignoring them nobody is helped. What it boils down to is deception and who want's that? (the easy to use design tool, but some things don't count on)
                                    Why is it so hard to admit these issues, which indisputably exist and try and work to fix them?
                                    The units are precise enough just the execution of some commands lack performance; why? I just don't get the whole discussion there is no two ways! A command either performs geometrical correct or it does not. If it does not why not fix it?
                                    simplicity is the ultimate sophistication
                                      sonder
                                      Huh? Never had issues with the offset tool. It's always been accurate for me, and I use it all the time.
                                      Clipping occurs if you are far from the origin and set your field of view too wide.
                                        πŸ˜• Some clear examples of Offset's inaccuracy please...
                                        You shouldn't make sweeping statements about something like this without some backup 😞
                                        You type in a value or snap to something that is a known distance off, like a guideline...
                                        It is that distance offset.
                                        If you are later measuring offsets on 'arcs' remember that they are 'segmented' and you must measure 'square' to these lines, not from their vertices which will not provide the true offset as this is the 'miter diagonal'...
                                        That is the only source of measurement confusion I can think of... but then that is mis-measurement... and not the application's inaccuracy ?
                                        Which as far as I know is fine for most expected uses...
                                        It's not for designing the innards of swiss-watches or whole city-suburbs but at normal 'building' dimensions it's just fine πŸ˜’
                                          DesertRaven
                                          @tig said:
                                          :? Some clear examples of Offset's inaccuracy please...
                                          Well let us just pretend you never encountered what I'm talking about so here is an example:
                                          http://img19.imageshack.us/img19/5027/sketchupoffseterror.jpg
                                            hey.. i tried back on pg 9 πŸ˜‰
                                            oh, hey..can we get a sketchup rep in the thread ? πŸ’š
                                            • 25
                                            • 26
                                            • 5 / 26
