    Sketchup is Inacurrate???
    513 Posts 38 Posters 49.4k Views 38 Watching
    • andybotA Offline
      andybot
      Hey, what's better than a dead horse to beat! Anyhoo, wouldn't you use follow-me in a case such as the one you show? That way you are certain to have a consistent profile along the path.
      • jeff hammondJ Offline
        it would be nice if I could. but if I were to put a 2x6 profile at the end of one of those perimeter edges (in my latest example skp) then run follow me, it would produce the exact same (bad) geometry as offsetting the perimeter then push/pulling the face upwards.
        these two tools (offset/followme)use the same brain..
        • andybotA Offline
          andybot
          oh. learn something new every day... I guess this one is a dead horse of the highest order. Oh well, back to ACAD.
          Edit: oh hell, I'm back for more. The profile width is absolutely correct with follow me, but why is it not correct in your example? (5.489")
          followme-what.skp
          • Wo3DanW Offline
            Wo3Dan
            That's a very good example Jeff 👍
            maybe one of these days I'll get the point across that I've been trying to 😆
            Your first example, the one that you think is correct, doesn't have a constant wall thickness.
            The other one (by your standards being incorrect) does indeed have a constant wall thickness.
            I can see the occasional need for offsetting an arc to get predictable new arcs instead of curves with unpredictable radii. But here in your example the wall thickness is correct by using SketchUp's basic 'Offset' tool.
            Why do you measure/dimension its thickness not perpendicular to its surface? 😮
            • Wo3DanW Offline
              Wo3Dan
              @wo3dan said:
              ...Why do you measure/dimension its thickness not perpendicular to its surface? 😮
              Let me put it this way: you use 2x6 for the base plate. It's not a 2x6 anymore in your correct example. It is in the incorrect one at the right, (scene 4).
              Due to the correct offset method SU correctly calculate the (inside) lengths, etc. that you marked in red. This is exactly what you'll get when you cut the 2x6 to match the outside frame perimeter.
                it's an arc.. the only point(s) on the arc that are true are the vertices.. the straight segments in between have nothing to do with it..
                draw an arc with 2 segments… there are exactly three points that are going to be true.. those are the endpoints and the one vertex in the middle.. those three point will be the only place to accurately measure the radius.. these are also the only points where you can measure the thickness of an arced wall.
                for all intents and purposes, i could do the same drawing using only guide points to represent the geometry.. the lines connecting the guide points do not matter at all..
                notice for this wall, i have original arc with segments spaced at 12" (arc length.. not segment length).. the reason for that is because i also want the studs to be on 12" centers and they must be placed on the vertices to be true.. the can't be placed on the straight segments because things won't line up..
                  It's better than a broken watch who give the good true time twice a day! 💚
                    click pic -> larger
                    maybe this helps? (rhino)
                      Roger
                      Why does this matter? Is the project going to be build with a CNC machine or by a carpenter? The carpenter will read and cut to the correct dimension. A CNC machine the will facet the curve incorrectly. How many buildings are built with CNC machines. This is an honest quest as I don't know if it really matters. For a machine designer it would be critical if CNC is used in manufacturing. If the plans are meant to be read by a human and are annotated properly I don't see the problem.
                      http://www.azcreative.com
                        lol.. you're right.. the carpenter will read and cut the dimension given.. only it's the wrong freaking dimension ☀
                          it's because you're measuring the arc wall at the wrong point.. i want to build a curved wall -- not one consisting of a bunch of straight 2x6s mitered together (in which case yes, the 5.5" width would be proper)..
                          but it's an arc -- and theonly place an arc is accurate in sketchup is the vertices.. you have to measure your arcs/circles etc from there..
                          edit.. for instance.. draw a circle in sketchup then draw a few diameter lines across it… the only place where the lines will be the true length are at the vertices.. if you draw a line connecting a segment to a segment, it's going to be shorter than the actual diameter
                            Are you beating your head against a wall there?
                              It's for that is not very cautious to build an atomic Plant from Su but no problem for draw it! ☀
                                Roger
                                I would say the problem is with the architect who inserted his dimensioning at the wrong point on the drawing. In this case wouldn't you insert your dimension at the vertice where the measurement is correct? Or manually change the dimensioning if it MUST be inserted at another point? Not arguing, just filling gaps in my knowledge.
                                  the real solution is to draw it accurately in the first place. that way, the drawing is accurate and the dimensions are accurate... and any subsequent geometry in the model will be accurate and so will those dimensions.. and so on and so forth.
                                  drawing sloppy then editing dimension is both hack and inefficient..
                                  and again, you can draw this wall accurately in sketchup and obtain proper dimensions etc. it's just that you can't use certain tools (which should be the right ones for certain situations) to obtain the true dimensions.
                                    not quite. getting there though. hopefully I'll just give up before any cranium crushing over this 😄
                                      Roger
                                      Now that I dig under the surface this become more interesting. I just drew two circles within each other and used the dimensioning tool to obtain the diameters. They are both accurate at any point on the circle (vertex or not) as long as you don't explode the circle. Also if you dimension the circle at any point and then explode the circle, the dimensioning does not change. Now I wonder if you could create a special ruby that allows you to click between the inner and outer vertex for a correct board dimension and the apply that dimension anywhere on the circle when you make a third click on the circle. Said differently, the first two clicks determine the correct distance and the third click will attach that dimension to the circle at the point of your third click. I think we may have invented something usefully similar to the angle dimensioning ruby. Anybody want to write the tool?
                                        @wo3dan said:
                                        yes and no.. 2x6 for the straight sections.. 2 layers of 3/4" ply with the arcs drawn/cut from the larger piece for the round plates.
                                        (ie. you can't cut a 5 1/2" wide arc in a 5 1/2" wide board).. the actual laminated plates on site are true radii.. not segmented as it appears in sketchup..
                                          right.. that's what i was getting at earlier in the thread.. notice also that if you look at the entity info's expanded view of a 'circle' or 'arc' , it will accurately list its length.. if you explode it, it will then show the sum of the segments' lengths..
                                          so what i was saying is that since sketchup is 'smart' enough to recognize when a user wants an arc/circle and provide accurate properties of said curve (as opposed to a collection of straight lines), then i wish it was also smart enough to transform the geometry according to the way the user has assigned it..
                                          if it's an arc, move the vertices.. if it's a collection of edges, move the segments.. it's really that simple ☀
                                          as it is now, it treats all geometry, regardless of the type, as a collection of straight segments when offsetting/sweeping.
                                          your ruby idea, while i see what you're saying, would pretty much be a waste in most situations unless sketchup would also move the geometry accurately.. if the ruby was made then you tried to use it on geometry obtained via the offset tool, it would just show you that the drawing is messed up..
                                          edit- well, that, and i'm pretty sure these ruby geniuses don't have much (if any?) access to dimensioning tools..
                                            Roger
                                            Well someone created a much needed angle dimensioning tool that worked as I describe.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 21 / 26
