    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    Sketchup is Inacurrate???
    513 Posts 38 Posters 49.4k Views 38 Watching
    • jeff hammondJ Offline
      @tig said:
      I can still 'conjure' with the olde fractional feet-and-inches - but 'metric' IS so much easier...
      my daughter is learning length & volume in school right now..
      her homework the past two weeks has been all metric stuff.. (you know.. how to move a decimal point around ๐Ÿ˜„ )
      i just wish they were teaching her metric as 'the way things are' as opposed to 'here, you might see this stuff occasionally'.
        That's a very good example Jeff ๐Ÿ‘
          The USA is already quite 'metric'... ๐Ÿ˜ฎ
          You have had 'decimal' money forever.
          You buy coke/pop in 'liters'.
          Your cars have 'cc' engine data.
          The US Army measure horizontal distances in 'meters' [but then heights in 'feet' - as do aircraft the world over!].
          Most complex science in conducted in 'metric'.
          So I expect that much of the US space-program is 'metric' too...
          Now if only we can get you into using a few 'metric lengths'... ๐Ÿ˜‰
          I find it surprising that given the US's break with the UK just as the French were pushing their newfangled 'metric' system, that the US didn't adopt it too, much of the rest of the world did...
          We are not trying to get you to adopt a decimal time or calendar system ๐Ÿ˜ฒ
            Remember the Mars Climat Orbiter ๐Ÿ˜’
            Some millions $ in smoking vapors for error between unities in translation! ๐Ÿ’š
              right. much of it is. unfortunately, not all of it.
              we crashed a probe into mars by accident due to some imperial/metric conflicts ๐Ÿ˜ฎ
              re:length.
              all of our official land surveys etc are metric as well.. it's just the tradesmen that won't switch. I think most of us would be into switching but most of our materials are still sold imperial only.
              it's pretty much the govt and manufacturers of building materials that need to lead the way.
              Edit. well, I see frenchy has beaten me to the mars thing ๐Ÿ˜„
                maybe one of these days I'll get the point across that I've been trying to ๐Ÿ˜†
                  @arcad-uk said:
                  I can see the argument from both sides for arc offsets because in the past I've wanted both results. Ideally SU will be given true arcs at some point. But from this thread I now understand why things are the way they are and on balance from an architectural perspective I prefer to have any offset from an arc create a consistent (wall) thickness which is what happens now rather than tapering the arc section to maintain a vertex offset.
                  I guess I'm now flogging a dead horse but the way it works now doesn't give a consistent wall thickness. see my last upload in this thread which shows an example using an actual wall.
                  • andybotA Offline
                    andybot
                    Hey, what's better than a dead horse to beat! Anyhoo, wouldn't you use follow-me in a case such as the one you show? That way you are certain to have a consistent profile along the path.
                      it would be nice if I could. but if I were to put a 2x6 profile at the end of one of those perimeter edges (in my latest example skp) then run follow me, it would produce the exact same (bad) geometry as offsetting the perimeter then push/pulling the face upwards.
                      these two tools (offset/followme)use the same brain..
                      • andybotA Offline
                        andybot
                        oh. learn something new every day... I guess this one is a dead horse of the highest order. Oh well, back to ACAD.
                        Edit: oh hell, I'm back for more. The profile width is absolutely correct with follow me, but why is it not correct in your example? (5.489")
                        followme-what.skp
                        • Wo3DanW Offline
                          Wo3Dan
                          Your first example, the one that you think is correct, doesn't have a constant wall thickness.
                          The other one (by your standards being incorrect) does indeed have a constant wall thickness.
                          I can see the occasional need for offsetting an arc to get predictable new arcs instead of curves with unpredictable radii. But here in your example the wall thickness is correct by using SketchUp's basic 'Offset' tool.
                          Why do you measure/dimension its thickness not perpendicular to its surface? ๐Ÿ˜ฎ
                          • Wo3DanW Offline
                            Wo3Dan
                            @wo3dan said:
                            ...Why do you measure/dimension its thickness not perpendicular to its surface? ๐Ÿ˜ฎ
                            Let me put it this way: you use 2x6 for the base plate. It's not a 2x6 anymore in your correct example. It is in the incorrect one at the right, (scene 4).
                            Due to the correct offset method SU correctly calculate the (inside) lengths, etc. that you marked in red. This is exactly what you'll get when you cut the 2x6 to match the outside frame perimeter.
                              it's an arc.. the only point(s) on the arc that are true are the vertices.. the straight segments in between have nothing to do with it..
                              draw an arc with 2 segmentsโ€ฆ there are exactly three points that are going to be true.. those are the endpoints and the one vertex in the middle.. those three point will be the only place to accurately measure the radius.. these are also the only points where you can measure the thickness of an arced wall.
                              for all intents and purposes, i could do the same drawing using only guide points to represent the geometry.. the lines connecting the guide points do not matter at all..
                              notice for this wall, i have original arc with segments spaced at 12" (arc length.. not segment length).. the reason for that is because i also want the studs to be on 12" centers and they must be placed on the vertices to be true.. the can't be placed on the straight segments because things won't line up..
                                It's better than a broken watch who give the good true time twice a day! ๐Ÿ’š
                                  click pic -> larger
                                  maybe this helps? (rhino)
                                    Roger
                                    Why does this matter? Is the project going to be build with a CNC machine or by a carpenter? The carpenter will read and cut to the correct dimension. A CNC machine the will facet the curve incorrectly. How many buildings are built with CNC machines. This is an honest quest as I don't know if it really matters. For a machine designer it would be critical if CNC is used in manufacturing. If the plans are meant to be read by a human and are annotated properly I don't see the problem.
                                    http://www.azcreative.com
                                      lol.. you're right.. the carpenter will read and cut the dimension given.. only it's the wrong freaking dimension โ˜€
                                        it's because you're measuring the arc wall at the wrong point.. i want to build a curved wall -- not one consisting of a bunch of straight 2x6s mitered together (in which case yes, the 5.5" width would be proper)..
                                        but it's an arc -- and theonly place an arc is accurate in sketchup is the vertices.. you have to measure your arcs/circles etc from there..
                                        edit.. for instance.. draw a circle in sketchup then draw a few diameter lines across itโ€ฆ the only place where the lines will be the true length are at the vertices.. if you draw a line connecting a segment to a segment, it's going to be shorter than the actual diameter
                                          Are you beating your head against a wall there?
                                            It's for that is not very cautious to build an atomic Plant from Su but no problem for draw it! โ˜€
                                            • 25
                                            • 26
                                            • 7 / 26
