    The Blender Tree Generator
    33 Posts 12 Posters 4.5k Views 12 Watching
    • andybotA
      andybot
      @michaliszissiou said:
      1. SU exports non welded vertices as obj. Import in blender/edit mode, select all, delete double verts (under the [W] menu). This welds all verts.
      nice, this sounds like the answer I'm looking for, thanks!
      1. SU uses ngons internally and exports triangulated meshes. Terrible topology for subdivisions, displacements etc. The funny thing is that new builds of blender 2.62/bmesh implemented these ngons too. You have knifes, push pulls, insets (SU F tool), arcs etc . And some terrible topology in the end. If you're going for displacements, subdivisions, sculpting.
      I've found the Blender command to convert triangulated faces to quads works very well for providing good topology. Once I do that I can modify and subdivide at my leisure. The only thing it does funky is large planes, so I triangulate and make those more regular before exporting.
        Amazon---ing! 😎
        • michaliszissiouM
          michaliszissiou
          Increasing transparent bounces in cycles.
          It took 1:50 hour to render. A cycles render, right? Monet's paintings? 😆
          http://dl.dropbox.com/u/24090090/TransMax64H.jpg
            Gorgeous! ☀
            • michaliszissiouM
              michaliszissiou
              Another one,
              Using particles/weight painting. A better technic and a bit time consuming.
              But, render time ~2 mins
              http://dl.dropbox.com/u/24090090/otree%231.jpg
              • andybotA
                andybot
                nice work! Is this a blender file you can share? I am still trying to wrap my head around some of these concepts.
                • michaliszissiouM
                  michaliszissiou
                  Thank you pilou, andybot.
                  Of course, what file do you need? A tree?
                  Are you familiar with how to relink textures? Cycles is still under development.
                  Why don't you register in http://blenderartists.org/forum/index.php?
                  Not very polite blenderheads 🤣 , but you may find lot of help.
                  • andybotA
                    andybot
                    Michalis, that would be great! The things that interest me are - how you are texturing the leaves, what setting you are using for the tree generator (all the branching parameters, etc.), and what settings do you have for cycles. I think I have a decent understanding regarding texture links, etc. If you have a file with a tree and the cycles setup, that would be
                    • michaliszissiouM
                      michaliszissiou
                      This "decent" is what fears me 😆
                      Cycles isn't that decent, you see.
                      Use the official blender 2.62
                      http://www.blender.org/download/get-blender/
                      Download it before it's too late, newer builds made things upside down
                      Watched the tutorial? http://vimeo.com/27668302
                      Here a blender tree (blend file, link the textures)
                      http://dl.dropbox.com/u/24090090/testBlendtree.zip
                      In recent builds, r45308 from http://www.graphicall.org/ , you don't need separate masks, a transparent png works fine. But, tree generator is broken.
                      About UV maps on foliage. Tree generator, when using rectangular leaves, has automatically generated them. Apply a shader in cycles node system, image (link it) and that's all.
                      • andybotA
                        andybot
                        So is the tree generator a different plugin than "Sapling"? Looks like the tree is a mesh, not a curve. Is there something obvious I'm missing or is there anothter add-on that needs to be installed?
                        Edit - oh, never mind - it's just converted to mesh from a curve...
                        I guess I'd like to see the curve settings you have for your tree.
                        • michaliszissiouM
                          michaliszissiou
                          No, sapling is the name of the addon.
                          Curves have to be converted to real geometry before unwrapping. Watch the tutorial! It's a good one.
                          Go to prefs first and enable it.
                          • E
                            Ecuadorian
                            Amazing.
                            Just wondering... Why do you prefer TIG's obj-out instead of Collada? I see Blender can now import Collada.
                            -Miguel Lescano
                              About import obj
                              There is free one here (bottom page) some biggest than the Tig one ; (11 megas against 13 kb 💚
                              But very more speedy, useful for the very big files!
                              • michaliszissiouM
                                michaliszissiou
                                @Pilou
                                This is an obj importer, right?
                                Tig's exporter is very fast and works beautifully on very dense and complicated models.
                                For importing to SU, 3ds format, despite its limitations, works fine.
                                (max single mesh 64 K faces, max texture name 8 digits, it is also broken in latest SU build. I use SU 7 for importing)
                                Why to import? Using SU just as a modeler and export, is more interesting after all.
                                @Ecuadorian
                                Have you tried to import collada to latest blender 2.62? You'll get an empty space.
                                  sepo
                                  Looks great and the rendering of instances looks amazingly fast.
                                  • michaliszissiouM
                                    michaliszissiou
                                    Thank you sid.
                                    3 mins isn't great, it's a CPU render, using NVIDIA GeForce GTX 560 Ti, CUDA render, 56 seconds!
                                    • simon le bonS
                                      simon le bon
                                      Dear Michalis, dear all,
                                      what amazing trees and work 👍 👍
                                      As I'm finally learning Blender (!), I'm at the first level interested by this very instructive thread ++
                                      (!)SU + Blender = war machine)
                                      Re: The Blender Tree Generator
                                      http://forums.sketchucation.com/viewtopic.php?f=179&t=44345#p395545
                                      Thanks for the kind comments.
                                      About the skp file:
                                      It looks heavy ~15Mb for downloading. It's not that huge though, I just don't use components.
                                      I tested another skp tree, full of components ~400kb downloading. It behaves heavily in SU making rather impossible to load 10-20 such trees. It won't happen with the one a shared.
                                      @andybot
                                      http://forums.sketchucation.com/viewtopic.php?f=323&t=33448&p=372812#p372812
                                      TIG's obj exporter thread.
                                      2. The ruby addon, remove inner faces. Very useful to kill non manifolds at once.
                                      3. be aware of the inverted faces in SU (the blue ones), you may fix it in blender but will mess the exported SU UVs.
                                      4. SU uses ngons internally and exports triangulated meshes. Terrible topology for subdivisions, displacements etc. The funny thing is that new builds of blender 2.62/bmesh implemented these ngons too. You have knifes, push pulls, insets (SU F tool), arcs etc . And some terrible topology in the end. If you're going for displacements, subdivisions, sculpting.
                                        So, don't subdivide SU meshes. Just render them, apply better textures, unwrapping, materials for rendering (cycles), bumps. But never subdivide, it's logically impossible. You may retopo all these but not practical for archi vis projects.
                                      5. Components: Explode them before it's too late 😆
                                      I've experienced some difficulty to find the Wikii Inner faces Remover you are talking about.I was remembering this inner faces remover but too vaguely to be able to find it on the forums and have found it into my downloaded plugins repertory. It is not referenced as a normal plugin but it is a reply from Wikii to a Pilou's request.
                                      So here are the links :
                                      Pilou _ [Plugin] Internal surfaces
                                      http://forums.sketchucation.com/viewtopic.php?f=180&t=12668&p=92295#p92295
                                      Wikii remove_inner_faces.zip
                                      Simon
                                        My SolidSolver tool might also fix your non-manifold 'inner partition faces' issues [and small holes/flaps etc]
                                        It only works on groups mind - so if it's a component you need to edit it, select all, and group temporarily... once fixed you can explode the group and the containing component should then be manifold too ?
                                        • simon le bonS
                                          simon le bon
                                          Nice usage of these tools untested until now 😄
                                          tt_solid_inspector.rb
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/tmtm_SolidInspector.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/tmtm_SolidInspector_menu.jpg
                                          TIG-solidsolver.rb
                                          @tig said:
                                          Parts are based on ThomThom's 'solid_inspector' tool which can also be
                                          used prior to this tool, so that you get a better understanding of what
                                          is wrong with your Non-Solid Group...
                                          Menu: 'Tools' > 'SolidSolver'
                                          Usage: [Note this works on v8/Pro only]
                                          Please note that all instances of the group are solved together even if only one is selected. (So I've been obliged to explode one copy of the invalid solid group to keep the errors of the group on the same picture as the one solved)
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TIG_SolidSolver.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/RemoveInnerFaces_2.jpg
                                          😎Simon
                                          • EarthMoverE
                                            EarthMover
                                            Nice Simon. Thanks for compiling links for these great scripts! Kudos to the authors as well!
                                            Content Creator at Skapeup
