    ๐Ÿ›ฃ๏ธ Road Profile Builder | Generate roads, curbs and pavements easily Download
    The Blender Tree Generator
    33 Posts 12 Posters 2.5k Views 12 Watching
    • michaliszissiouM Offline
      michaliszissiou
      Testing this interesting blender 2.62 addon.
      Here a tutorial on the older version.
      http://vimeo.com/27668302
      Trees, randomly generated. High or low poly trees are possible.
      A good reason to import SU files (tig's excellent obj exporter) to blender and render in cycles. Another reason is the ability of blender cycles to render instances, billions or hundreds of billions polys. Have a look, ~17 billions faces, rendered ~3 mins.
      http://dl.dropbox.com/u/24090090/treesBlenderInst.jpg
      Here my tests, still a WIP. Cycles renders of course.
      http://dl.dropbox.com/u/24090090/treesFol1map.jpg
      http://dl.dropbox.com/u/24090090/treeshexa%2301.jpg
      http://dl.dropbox.com/u/24090090/trees%236.jpg
      What all these have to do with SU? Except of using it as a modeler exporter to blender.
      Here, imported in SU ~50K, a podium render.
      http://dl.dropbox.com/u/24090090/treeTestBlend 2012-03-31 18134300000.jpg
      And feel free to use it if you like. The SKP file.
      http://dl.dropbox.com/u/24090090/treeTestBlend.skp.zip
      • numbthumbN Offline
        numbthumb
        Great stuff, michalis, thanks for sharing! Looks excellent ๐Ÿ‘
        Comfortably numb...
        • andybotA Offline
          andybot
          michalis,
          Indeed, trees generation in Blender is a revelation! It's very exciting to me too. Didn't know about the cycles proxy, I'll have to look at that.
          Since you seem to be pretty well versed in the SU to Blender workflow, I'd like to ask a question about your experience with the OBJ exporter. I find that it breaks groups/ components into individual faces, which means that you can't use smoothing or the various modifiers correctly. Is there a way you recombine a mesh, or do you just not worry about it? I am finding that using SU's 3ds exporter works the best in keeping meshes as connected pieces.
          Andy
          • EscapeArtistE Offline
            EscapeArtist
            Wow. That is awesome. I have been wanting to do some more creative things with SU/Blender, this would really help out in the architectural and landscape department.
            Thanks for sharing the find!
              michaliszissiou
              Thanks for the kind comments.
              About the skp file:
              It looks heavy ~15Mb for downloading. It's not that huge though, I just don't use components.
              I tested another skp tree, full of components ~400kb downloading. It behaves heavily in SU making rather impossible to load 10-20 such trees. It won't happen with the one a shared.
              @andybot
              http://forums.sketchucation.com/viewtopic.php?f=323&t=33448&p=372812#p372812
              TIG's obj exporter thread.
              1. SU exports non welded vertices as obj. Import in blender/edit mode, select all, delete double verts (under the [W] menu). This welds all verts.
              2. The ruby addon, remove inner faces. Very useful to kill non manifolds at once.
              3. be aware of the inverted faces in SU (the blue ones), you may fix it in blender but will mess the exported SU UVs.
              4. SU uses ngons internally and exports triangulated meshes. Terrible topology for subdivisions, displacements etc. The funny thing is that new builds of blender 2.62/bmesh implemented these ngons too. You have knifes, push pulls, insets (SU F tool), arcs etc . And some terrible topology in the end. If you're going for displacements, subdivisions, sculpting.
                So, don't subdivide SU meshes. Just render them, apply better textures, unwrapping, materials for rendering (cycles), bumps. But never subdivide, it's logically impossible. You may retopo all these but not practical for archi vis projects.
              5. Components: Explode them before it's too late ๐Ÿ˜†
              • andybotA Offline
                andybot
                nice, this sounds like the answer I'm looking for, thanks!
                1. SU uses ngons internally and exports triangulated meshes. Terrible topology for subdivisions, displacements etc. The funny thing is that new builds of blender 2.62/bmesh implemented these ngons too. You have knifes, push pulls, insets (SU F tool), arcs etc . And some terrible topology in the end. If you're going for displacements, subdivisions, sculpting.
                I've found the Blender command to convert triangulated faces to quads works very well for providing good topology. Once I do that I can modify and subdivide at my leisure. The only thing it does funky is large planes, so I triangulate and make those more regular before exporting.
                  Amazon---ing! ๐Ÿ˜Ž
                    michaliszissiou
                    Increasing transparent bounces in cycles.
                    It took 1:50 hour to render. A cycles render, right? Monet's paintings? ๐Ÿ˜†
                    http://dl.dropbox.com/u/24090090/TransMax64H.jpg
                      Gorgeous! โ˜€
                        michaliszissiou
                        Another one,
                        Using particles/weight painting. A better technic and a bit time consuming.
                        But, render time ~2 mins
                        http://dl.dropbox.com/u/24090090/otree%231.jpg
                        • andybotA Offline
                          andybot
                          nice work! Is this a blender file you can share? I am still trying to wrap my head around some of these concepts.
                            michaliszissiou
                            Thank you pilou, andybot.
                            Of course, what file do you need? A tree?
                            Are you familiar with how to relink textures? Cycles is still under development.
                            Why don't you register in http://blenderartists.org/forum/index.php?
                            Not very polite blenderheads ๐Ÿคฃ , but you may find lot of help.
                            • andybotA Offline
                              andybot
                              Michalis, that would be great! The things that interest me are - how you are texturing the leaves, what setting you are using for the tree generator (all the branching parameters, etc.), and what settings do you have for cycles. I think I have a decent understanding regarding texture links, etc. If you have a file with a tree and the cycles setup, that would be
                                michaliszissiou
                                This "decent" is what fears me ๐Ÿ˜†
                                Cycles isn't that decent, you see.
                                Use the official blender 2.62
                                http://www.blender.org/download/get-blender/
                                Download it before it's too late, newer builds made things upside down
                                Watched the tutorial? http://vimeo.com/27668302
                                Here a blender tree (blend file, link the textures)
                                http://dl.dropbox.com/u/24090090/testBlendtree.zip
                                In recent builds, r45308 from http://www.graphicall.org/ , you don't need separate masks, a transparent png works fine. But, tree generator is broken.
                                About UV maps on foliage. Tree generator, when using rectangular leaves, has automatically generated them. Apply a shader in cycles node system, image (link it) and that's all.
                                • andybotA Offline
                                  andybot
                                  So is the tree generator a different plugin than "Sapling"? Looks like the tree is a mesh, not a curve. Is there something obvious I'm missing or is there anothter add-on that needs to be installed?
                                  Edit - oh, never mind - it's just converted to mesh from a curve...
                                  I guess I'd like to see the curve settings you have for your tree.
                                    michaliszissiou
                                    No, sapling is the name of the addon.
                                    Curves have to be converted to real geometry before unwrapping. Watch the tutorial! It's a good one.
                                    Go to prefs first and enable it.
                                    • E Offline
                                      Ecuadorian
                                      Amazing.
                                      Just wondering... Why do you prefer TIG's obj-out instead of Collada? I see Blender can now import Collada.
                                      -Miguel Lescano
                                        About import obj
                                        There is free one here (bottom page) some biggest than the Tig one ; (11 megas against 13 kb ๐Ÿ’š
                                        But very more speedy, useful for the very big files!
                                          michaliszissiou
                                          @Pilou
                                          This is an obj importer, right?
                                          Tig's exporter is very fast and works beautifully on very dense and complicated models.
                                          For importing to SU, 3ds format, despite its limitations, works fine.
                                          (max single mesh 64 K faces, max texture name 8 digits, it is also broken in latest SU build. I use SU 7 for importing)
                                          Why to import? Using SU just as a modeler and export, is more interesting after all.
                                          @Ecuadorian
                                          Have you tried to import collada to latest blender 2.62? You'll get an empty space.
                                            sepo
                                            Looks great and the rendering of instances looks amazingly fast.
