    Grass as component, not pattern
    12 Posts 6 Posters 1.1k Views 6 Watching
    • mitcorbM
      mitcorb
      Maybe "MakeFur"? Do a patch, make it a component, populate the scene with instances turned this way and that.
      • brookefoxB
        brookefox
        Good suggestion. Not sure what it offers over Spray but I'll try it. Thanks.
        ~ Brooke
        • Mike LuceyM
          Mike Lucey
          Let us know how you get on with Fur nd don't let those chickens near the grass, they will ruin it 😉
          • mitcorbM
            mitcorb
            yeah specially the purple headed one.
            • cheddaC
              chedda
              Hey Brookefox i posted this a while back take a look it even features a chicken !:
              http://forums.sketchucation.com/viewtopic.php?f=81&t=43722
              i'd avoid fur with such large spaces it's heavy on geometry and sketchup will balk under the load.
              chedda
              Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                That looks like my lawn. Well, except the bare spots aren't white. 😄
                • brookefoxB
                  brookefox
                  Thank you, chedda. I feared as much. And it has more muscle and learning required than I require right now. I do hope to test it on a patch, though, as I'd like to learn it, as, you see, I'm pretty bald.
                  ~ Brooke
                  • brookefoxB
                    brookefox
                    This is about as good as I could do and it took me too long to do it, trying various. Three triangular leaves each component, no verticals.
                    Top: edges style normal.
                    Bottom: edge style as material.
                    ~ Brooke
                    • GaieusG
                      Here I have some grass patches if you like - they are png files on single faces:
                      http://sketchup.google.com/3dwarehouse/details?mid=7855528f6b0f76e9440b5e85fc05fc55
                      Though I used a different grass component here, this is how it could look with instanced grass:
                      https://lh6.googleusercontent.com/-9SVAwKBpsOA/TP9vbWFBhvI/AAAAAAAAE7s/GDIDfXqOz3U/s800/ortorony.jpg
                      Then if you need to cover a very big area, indeed consider that whatever components you use, you will have problems so another solution (trick) would be to use two surfaces above each other: the bottom surface is a "normal" grass texture and another surface placed somewhat (~5cm / ~2") higher is a material with "holes" on it (semi transparent) like here:
                      http://sketchup.google.com/3dwarehouse/details?mid=52aeba6fee1da988846ddcb7a97e4c0d
                      • brookefoxB
                        brookefox
                        Thank you, Gai...
                        But I don't really trust you soldiers' fashion sense. And where are they headed? Is that a stockade or a granary or a commissary or what?
                        Nevermind.
                        ~ Brooke
                        • GaieusG
                          a watchtower.
