    Grass as component, not pattern
    12 Posts 6 Posters 993 Views 6 Watching
    • brookefoxB
      brookefox
      Don't laugh (so I can hear you), please. While I am texture ignorant, I don't like patterns for grass here because they are mapped to terrain facets that make for a homely look (first two images). Is there an effective way around this?. The stick grasses shown in the third image are components. Any suggestions/thoughts on this approach (apart from scale which is a bit large, I think)?
      These are country people; green types; they don't mow their native grasses.
      ~ Brooke
      • mitcorbM
        mitcorb
        Maybe "MakeFur"? Do a patch, make it a component, populate the scene with instances turned this way and that.
        • brookefoxB
          brookefox
          Good suggestion. Not sure what it offers over Spray but I'll try it. Thanks.
          ~ Brooke
          • Mike LuceyM
            Mike Lucey
            Let us know how you get on with Fur nd don't let those chickens near the grass, they will ruin it 😉
            • mitcorbM
              mitcorb
              yeah specially the purple headed one.
              • cheddaC
                chedda
                Hey Brookefox i posted this a while back take a look it even features a chicken !:
                404 Not Found
                (forums.sketchucation.com)
                i'd avoid fur with such large spaces it's heavy on geometry and sketchup will balk under the load.
                chedda
                Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                  That looks like my lawn. Well, except the bare spots aren't white. 😄
                  • brookefoxB
                    brookefox
                    Thank you, chedda. I feared as much. And it has more muscle and learning required than I require right now. I do hope to test it on a patch, though, as I'd like to learn it, as, you see, I'm pretty bald.
                    ~ Brooke
                    • brookefoxB
                      brookefox
                      This is about as good as I could do and it took me too long to do it, trying various. Three triangular leaves each component, no verticals.
                      Top: edges style normal.
                      Bottom: edge style as material.
                      ~ Brooke
                      • GaieusG
                        Here I have some grass patches if you like - they are png files on single faces:
                        http://sketchup.google.com/3dwarehouse/details?mid=7855528f6b0f76e9440b5e85fc05fc55
                        Though I used a different grass component here, this is how it could look with instanced grass:
                        https://lh6.googleusercontent.com/-9SVAwKBpsOA/TP9vbWFBhvI/AAAAAAAAE7s/GDIDfXqOz3U/s800/ortorony.jpg
                        Then if you need to cover a very big area, indeed consider that whatever components you use, you will have problems so another solution (trick) would be to use two surfaces above each other: the bottom surface is a "normal" grass texture and another surface placed somewhat (~5cm / ~2") higher is a material with "holes" on it (semi transparent) like here:
                        http://sketchup.google.com/3dwarehouse/details?mid=52aeba6fee1da988846ddcb7a97e4c0d
                        • brookefoxB
                          brookefox
                          Thank you, Gai...
                          But I don't really trust you soldiers' fashion sense. And where are they headed? Is that a stockade or a granary or a commissary or what?
                          Nevermind.
                          ~ Brooke
                          • GaieusG
                            a watchtower.
