    Reverse operation of view.screen_coords
    30 Posts 5 Posters 3.0k Views 5 Watching
      @tig said:
      If you get the view.camera, get its .eye and .target and change these points 'in tandem', then apply them to a new/updated camera etc then the view should 'pan'...
      [I put that very simplistically but you ought to get the idea]
      So with eye.x=eye.x+10 and target.x=target.x+10 ... it should pan the camera by 10 to the right etc...
      He's trying to figure out how much he has to move the camera in order for it to shift by the size of the viewport.
        How about https://developers.google.com/sketchup/docs/ourdoc/inputpoint#position ?
          Doesn't that risk it snapping to nearby geometry? That's why I was thinking a raytest would be safest as it would not be affected by inference.
            He can specify the view's inputpoint by using screen-coordinates (x,y) ?
            And then get the inputpoint's position as a 3dPoint ??
            That way he can get the screen width as with y at 0, and x at 0 and screen-width, gives two points - he can get the distance between them, then that's the amount to shunt the camera's eye/target across to pan a whole screen in the x-direction ?
              This 'proof of concept' pans the whole screen to the right [in plan is easiest to see...]
              def pan_whole_screen_to_the_right()
                model=Sketchup.active_model
                view=model.active_view
                ip0=view.inputpoint(0,0)
                ip1=view.inputpoint(view.vpwidth,0)
                p0=ip0.position
                p1=ip1.position
                dis=p0.distance(p1)
                cam=view.camera
                eye=cam.eye
                tar=cam.target
                upp=cam.up
                eye.x=eye.x+dis
                tar.x=tar.x+dis
                cam.set(eye,tar,upp)
              Obviously you can make a more flexible method which could pan right/left and up/down as desired...
                But my concern was that InputPoint will return a 3D point affected by inference, ie it snaps to mid points or something, based onthe 2D point.
                  I see the point. πŸ˜’
                  Here's a fuller version that avoids that [can you think of a better way?]
                    ents=model.entities
                    ants=model.active_entities
                    pants=ents.to_a+ants.to_a
                    hidn=pants.uniq.find_all{|e|not e.hidden?}
                    model.start_operation('pants')
                    hidn.each{|e|e.hidden=true}
                    hgeo=model.rendering_options["DrawHidden"]
                    model.rendering_options["DrawHidden"]=false
                    p0=ip0.position
                    p1=ip1.position
                    dis=p0.distance(p1)
                    cam=view.camera
                    eye=cam.eye
                    tar=cam.target
                    upp=cam.up
                    eye.x=eye.x+dis
                    tar.x=tar.x+dis
                    hidn.each{|e|e.hidden=false}
                    model.rendering_options["DrawHidden"]=hgeo
                    model.commit_operation
                    @tig said:
                    Here's a fuller version that avoids that [can you think of a better way?] [code]def pan_whole_screen_to_the_right()
                    http://forums.sketchucation.com/viewtopic.php?f=180&t=44290#p394956
                      Therefore we can substitute
                      p0=view.pickray(0,0)[0] p1=view.pickray(view.vpwidth,0)[0]
                      and get a simpler method because the ray's point doesn't get influenced by inferences and is made on the picture-plane, as it were...
                        dis=p0.distance(p1)
                        cam=view.camera
                        eye=cam.eye
                        tar=cam.target
                        upp=cam.up
                        eye.x=eye.x+dis
                        tar.x=tar.x+dis
                      πŸ˜„
                        Ah, yes! Of course - no need to pick anything. I forgot that the ray contained a point that could be used directly.
                          Two brains are better than one [at least our combined IQs add up to around the average!!]
                          πŸ˜†
                            I've already determined that my brain is on timeshare lease... πŸ˜’
                              jpark
                              TIG and thomthom,
                              Do you guys ever sleep!!??
                              You gave me a plenty of assignment for the weekend; to digest all that you posted.
                              For your info, I am attempting to model a 'plan viewer' for blueprints which will become framework for architectural components
                              Thanks guys
                              John
                                "Sl-eep"..? πŸ˜•
                                  jpark
                                  Just finished reading up on view.pickray method and ran TIG's sample code. At first glance it should have worked but does not. In executing each line, I find that p0 and p1 return same value as camera eye position. See Ruby Console responses below:
                                  p0=view.pickray(0,0)[0] Point3d(3255.11, 1479.16, 8761.61) p1=view.pickray(view.vpwidth,0)[0] Point3d(3255.11, 1479.16, 8761.61) p2=view.pickray(0,view.vpheight)[0] Point3d(3255.11, 1479.16, 8761.61) p3=view.pickray(view.vpwidth,view.vpheight)[0] Point3d(3255.11, 1479.16, 8761.61) cam=Sketchup.active_model.active_view.camera #<Sketchup::Camera:0x7ce5de0> cam.eye Point3d(3255.11, 1479.16, 8761.61) cam.target Point3d(3255.11, 1479.16, 127.281) cam.up Vector3d(0, 1, 0)
                                  How could this be? I thought I understood pickray method but NOT
                                  Off the topic note: where can I find instruction on how to annotate posting w/ codes, images, smiles, etc ...
                                  John
                                    I added some 'ruby' tags to make it clearer...
                                    I hope this is not ALL of the code...
                                    Have you set the view and so on earlier ?
                                    IF so... you don't use
                                    but
                                    cam=view.camera
                                    My code is a working example.......
                                    • Dan RathbunD
                                      Dan Rathbun
                                      There is a "hard to find" link on each message "POST A REPLY" page, in the right column, beneath the "Smilies" list.
                                      Notice how the line "BBCode is ON" has a link ??
                                      It leads you to a user guide for the code tags.
                                      Most of these usable tags have toolbar button "inserters" already set up for you to use. You just click the button, it inserts the tag. and positions the cursor between the tags so you can type text (or paste text,) into them.
                                      I'm not here much anymore.
                                        jpark
                                        Now I'm enlightened 😍 Thanks Dan
                                        No this is an output of individual Ruby Console execution. This is my attempt to debug each line of your sample code to check each variable's current value. Programming is my hobby and I just picked up Sketchup and Ruby couple of months ago so I have a lot to learn.
                                        Back to pickray method - All screen postions (ie p0, p1, p2, and p3) return different value yet pickray method of these points return identical 3D point as camera eye position but with different vector. How come?
                                        John
                                          eh.. TIG, I think we both did a brain-fart. We have to do a raytest - otherwise the ray will return a point which is based on the camera eye... because all pickray origin from the camera eye.
                                            Though, at 2:30 it's hard to process these thigns...
