    Reverse operation of view.screen_coords
    30 Posts 5 Posters 2.0k Views 5 Watching
      jpark
      How do you get 3-dimensional points @ each view.corners? Like an opposite method of view.screen_coords.
      I am trying to automatically pan one screen at a time in x or y direction while in top view of a model (sort of like microfiche machine used to read newspaper articles in olden days!!!).
      I figure adjusting camera eye and target position by model width/height displayed on screen should accomplish this; but I can't seemed to find the method to do this. Is this possible?
      Sincerely,
      John
        If you get the view.camera, get its .eye and .target and change these points 'in tandem', then apply them to a new/updated camera etc then the view should 'pan'...
        [I put that very simplistically but you ought to get the idea]
        So with eye.x=eye.x+10 and target.x=target.x+10 ... it should pan the camera by 10 to the right etc...
          <span class="syntaxdefault">ray </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pickray</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> x</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> y </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">result </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">raytest</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> ray </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span>
          But, may I ask why you want to perform such pan?
            He's trying to figure out how much he has to move the camera in order for it to shift by the size of the viewport.
              How about https://developers.google.com/sketchup/docs/ourdoc/inputpoint#position ?
                Doesn't that risk it snapping to nearby geometry? That's why I was thinking a raytest would be safest as it would not be affected by inference.
                  He can specify the view's inputpoint by using screen-coordinates (x,y) ?
                  And then get the inputpoint's position as a 3dPoint ??
                  That way he can get the screen width as with y at 0, and x at 0 and screen-width, gives two points - he can get the distance between them, then that's the amount to shunt the camera's eye/target across to pan a whole screen in the x-direction ?
                    This 'proof of concept' pans the whole screen to the right [in plan is easiest to see...]
                    def pan_whole_screen_to_the_right()
                      model=Sketchup.active_model
                      view=model.active_view
                      ip0=view.inputpoint(0,0)
                      ip1=view.inputpoint(view.vpwidth,0)
                      p0=ip0.position
                      p1=ip1.position
                      dis=p0.distance(p1)
                      cam=view.camera
                      eye=cam.eye
                      tar=cam.target
                      upp=cam.up
                      eye.x=eye.x+dis
                      tar.x=tar.x+dis
                      cam.set(eye,tar,upp)
                    Obviously you can make a more flexible method which could pan right/left and up/down as desired...
                      But my concern was that InputPoint will return a 3D point affected by inference, ie it snaps to mid points or something, based onthe 2D point.
                        I see the point. 😒
                        Here's a fuller version that avoids that [can you think of a better way?]
                          ents=model.entities
                          ants=model.active_entities
                          pants=ents.to_a+ants.to_a
                          hidn=pants.uniq.find_all{|e|not e.hidden?}
                          model.start_operation('pants')
                          hidn.each{|e|e.hidden=true}
                          hgeo=model.rendering_options["DrawHidden"]
                          model.rendering_options["DrawHidden"]=false
                          p0=ip0.position
                          p1=ip1.position
                          dis=p0.distance(p1)
                          cam=view.camera
                          eye=cam.eye
                          tar=cam.target
                          upp=cam.up
                          eye.x=eye.x+dis
                          tar.x=tar.x+dis
                          hidn.each{|e|e.hidden=false}
                          model.rendering_options["DrawHidden"]=hgeo
                          model.commit_operation
                          @tig said:
                          Here's a fuller version that avoids that [can you think of a better way?] [code]def pan_whole_screen_to_the_right()
                          http://forums.sketchucation.com/viewtopic.php?f=180&t=44290#p394956
                            Therefore we can substitute
                            p0=view.pickray(0,0)[0] p1=view.pickray(view.vpwidth,0)[0]
                            and get a simpler method because the ray's point doesn't get influenced by inferences and is made on the picture-plane, as it were...
                              dis=p0.distance(p1)
                              cam=view.camera
                              eye=cam.eye
                              tar=cam.target
                              upp=cam.up
                              eye.x=eye.x+dis
                              tar.x=tar.x+dis
                              Ah, yes! Of course - no need to pick anything. I forgot that the ray contained a point that could be used directly.
                                Two brains are better than one [at least our combined IQs add up to around the average!!]
                                  I've already determined that my brain is on timeshare lease... 😒
                                    jpark
                                    TIG and thomthom,
                                    Do you guys ever sleep!!??
                                    You gave me a plenty of assignment for the weekend; to digest all that you posted.
                                    For your info, I am attempting to model a 'plan viewer' for blueprints which will become framework for architectural components
                                    Thanks guys
                                    John
                                      "Sl-eep"..? 😕
                                        jpark
                                        Just finished reading up on view.pickray method and ran TIG's sample code. At first glance it should have worked but does not. In executing each line, I find that p0 and p1 return same value as camera eye position. See Ruby Console responses below:
                                        p0=view.pickray(0,0)[0] Point3d(3255.11, 1479.16, 8761.61) p1=view.pickray(view.vpwidth,0)[0] Point3d(3255.11, 1479.16, 8761.61) p2=view.pickray(0,view.vpheight)[0] Point3d(3255.11, 1479.16, 8761.61) p3=view.pickray(view.vpwidth,view.vpheight)[0] Point3d(3255.11, 1479.16, 8761.61) cam=Sketchup.active_model.active_view.camera #<Sketchup::Camera:0x7ce5de0> cam.eye Point3d(3255.11, 1479.16, 8761.61) cam.target Point3d(3255.11, 1479.16, 127.281) cam.up Vector3d(0, 1, 0)
                                        How could this be? I thought I understood pickray method but NOT
                                        Off the topic note: where can I find instruction on how to annotate posting w/ codes, images, smiles, etc ...
                                        John
                                          I added some 'ruby' tags to make it clearer...
                                          I hope this is not ALL of the code...
                                          Have you set the view and so on earlier ?
                                          IF so... you don't use
                                          but
                                          cam=view.camera
                                          My code is a working example.......
                                          • Dan RathbunD Offline
                                            Dan Rathbun
                                            There is a "hard to find" link on each message "POST A REPLY" page, in the right column, beneath the "Smilies" list.
                                            Notice how the line "BBCode is ON" has a link ??
                                            It leads you to a user guide for the code tags.
                                            Most of these usable tags have toolbar button "inserters" already set up for you to use. You just click the button, it inserts the tag. and positions the cursor between the tags so you can type text (or paste text,) into them.
                                            I'm not here much anymore.
