    Sketchup is Inacurrate???
    513 Posts 38 Posters 60.7k Views 38 Watching
      This is all true with curves (segments) but I would not call it inaccuracy but a limitation of SU (and as a matter of fact, any polygon modellers that use segments to approximate curves). SU accurately reports the volume of that multi-sided prism (not the ideal cylinder).
      This is not only true for volumes but also this is the reason of that "offsetting quirk".
      • H Offline
        Howard leslie
        If I may rephrase the question to: is SU accurate ?
        IMHO....
        Mostly YES, but sometimes NO (strictly speaking).
        Straight lines / Orthogonal Shapes / and any Geometry, Volumes etc created from them, no problem.
        SU will be as accurate as the user wants to model / level of detail required.
        Typically this will be limited by any source informatiom (site measurements, original drawings you may be working from, your original design etc) and the modeller's skill with SU (eg care with the snaps / inferencing)
        Circles, Curves, Arcs and any Geometry or Volumes derived from them - strictly speaking NO.
        I consider this a limitation of SU and not an inaccuracy. Provided you are aware of this, its usually not a problem either.
        For example, circles in SU - the corners of these many sided polygons (~circles) will be coincident with a true circle eg as if you'd just drawn it in Autocad etc, but the lines between the corners are not accurate.
        It follows from this that if you derive a Volume and calculate a Mass eg of Concrete or Steelwork of any shape containing curves, arcs etc, then this will also be slightly out.
        However, I've found that for most practical purposes the difference is negligible and can be worked around eg bump up the number of sides of any circle from say 24 to 64 etc if required.
        Some Top Tips I'd Recommend for Circles, Curves etc...
        1. When drawing circles, pull the circle out in either the red, green or blue direction (as opposed to some random direction).
        2. Use a number of sides that neatly divides up your Circle or Arc. By default, a circle in SU has 24 Sides. This is good as 360/24 = 15 degrees. Adjust number of sides as required. Any setting-out on Circles, Arcs etc will typically be every 15 degrees, 30 degrees etc. The setting-out points will now be true as they will coincide with the corners of your SU "Circle".
          Hope this Helps
        Howard L'
        • jeff hammondJ Offline
          i'm not quite sure i'd call this a limitation.. (well yeah, it's a limitation but it's preventable imo)..
          the 'offsetting quirk' happens over and over again throughout sketchup.. it's just easiest to see it with the offset tool..
          another notorious tool is follow-me..
          both the offset tool and follow me tool should only be used on straight lines/corners (such as a hipped roof etc.).. any attempt at using either of these tools on curves will result in an inaccurate model..
          the problem, as i see it, is that even tough sketchup recognizes an arc or circle (it will give accurate arc lengths for instance instead of simply giving a sum of it's segments), it seems to ignore the fact that you're dealing with an arc prior to doing anything with it and treats it as a collection of individual segments.. (in fact, su will explode an arc if it's part of a follow me path etc..)
          this (again, imo) is a fault of the program/programmers and it is preventable.. if you have a circle, arc, or even curve then sketchup should make the proper calculations and draw properly/accurately with them.. i haven't tested this out on other polygon modelers but i assume modo and the like can accurately deal with these situations..
          here is an example file showing some of the problems with using the follow me tool..
          inaccurate.skp
          it also shows the desired results / workaround using tig's lathe tool..
          i'll repeat this though -- never use offset, follow me, or even rubies that are simply tying in to sketchup's core functionality (shapebender etc.) for accurate work using curved lines or surfaces..
            Not sure of that πŸ˜„
              mac1
              @edson said:
              a couple of decades ago solar energy had a bad reputation in brasil as being inefficient. it turned out it did not work because the people who introduced it to us had no idea as to how to make it work: panels very seldom faced the correct direction and the height relationship among the parts was wrong. as soon as cleverer people started dealing in it solar energy become known for what it is.
              could something similar happen at times with sketchup users? I remember hearing a colleague at my university say it was a pity sketchup could not be used to produce precise models... πŸ˜’
              It was well known back then of the geometery relations the real issue was the efficiency of the cells . Look at the helio stat array
                SketchUp's internal precision when it comes to lengths is 1/1000th of an inch. You can see that in the Ruby Console:
                ` 1.0.to_l == 1.001.to_l
                => true
                1.0.to_l == 1.002.to_l
                => false
                1.0.to_l == 1.0011.to_l
                => false
                1.0.to_l == 1.00101.to_l
                => false`
                If the difference is less than 0.001 then it is considered equal. This kind of comparisons is normal and required when doing floating point comparisons. The difficult part is picking the actual precision - in SketchUp isn't 1/1000th of an inch (0,0254mm). Other applications might have a variables precision, configurable by the user, but SketchUp's is hard-coded.
                I assume SketchUp's precision was picked with architecture in mind where 1/1000th of an inch would be more than enough precision.
                  Sure but when you build the Channel Tunnel (50.5 km) you can have 128.27 mm of error ! πŸ˜‰
                    You can get a pick-axe and hammer that small difference off. The trains can slow down in such a turn easily. πŸ˜„
                    • ToboboT Offline
                      Tobobo
                      I get given cad drawings by 'CAD Engineers' all the time. These drawings look great when printed but very few of the lines actually join. They don't use snap tools, their attitude is if it looks good at 1:100 then its fine.
                      How hard is it to use the snap to end point or even 'nearest'?
                      Toby
                      Philippians 4:13
                        I guess this thread illustrates how making such a general sweeping statement "sketchup is inaccurate" doesn't really do much good..
                        there are quite a few interpretations shown in this thread of what inaccurate actually means..
                        I guess whoever said that in the first place might of had an actual/specific gripe but we'll never know if it's user error (most probable) or a shortcoming of sketchup itself.
                        carry on πŸ˜„
                          What happen with this ?
                          A circle is simulated or not ?
                          http://www.print-value.fr/images/hp-designjet-4000.jpg
                            I don't really think it matters how accurate sketchup is for that type work (archviz).. as long as the picture looks good or conveys an idea properly, nothing else really matters.
                            accuracy mostly comes into play when you have to actually build what's being drawn.
                            • dukejazzD Offline
                              dukejazz
                              Displaying objects:
                              Accuracy and precision: Accuracy 999,999 to 0.000001 by factor of the units and the zooming changes the slue range of precision.
                              Sketchup can view the very small object with no limits: ?
                              Setting length to mm you can measurement to 1 nano-meter 10^-9 or you may change to another units scale.
                              You can square and resize sketchup objects by the scale tool
                              I use the meshtab to read measure unit only
                              Now if I wanted to show smaller units of measurement I would turn off the display unit format and then write-in the new units of measurementpic_0054.jpg
                              Examples
                              .3 to 3 Angstrom
                              1,75 to 15 femto meters
                              and keep going to dx
                              Sketchup can view the very large object with no limits too: to infinity: Also
                              Now the bad new:
                              Inaccuratcy
                              1. Sketchup with more then one objects in a model must follow this rule: Smallest and biggest objects has to be with in a trillion of each other or they won't be format to GUI.
                                trillion = 1,000,000 x 1,000,000
                              2. Plugin and tools will margin the range of precision in their process so wactch out.
                                β˜€ Have a nice day
                                Trogluddite
                                Surely, the question really should be "Is sketchup accurate enough?"
                                For example, I create a lot of files for sending to a CNC laser cutting machine. The cutting head movements are driven by stepper motors. Thus, there is a maximum precision that can be reached by the machine (one step of the motor transformed by whatever "transmission" is used.)
                                So, just like SU, the machine does not draw true circles - there are a fixed number of points on the bed to which the head can be sent, with a touch of intertia smoothing the steps a little on the way.
                                So, if I want to obtain e.g. a sufficiently smooth curve, I must judge how many edges are needed based on the precision of my machine and behaviour of the material. 1000 edges would be silly - it would generate a massive CNC file when uploaded to the machine for absolutely no improvement in the end product. If I'm making a hole to clear a 3mm bolt, I may use as few as 10 edges - the bolt head and/or washer will easily cover any slight "raggedness" of the circle.
                                So it all comes down to tolerances - if you saw a plank of wood by hand, there is effectively no difference between 15mm and 15.00034532mm - the "precision" of the numbers is illusory, as you can't possibly cut that accurately.
                                  That is still just half the question. Enough for what? For modelling the universe (very large units) or atoms (very small units) then it's not accurate enough. Because it's not designed to handle such extremes.
                                    Don't be so theoretical, TT. "Enough" meaning the normal use of it starting from mechanical design to landscape/urban planning.
                                    I have to say that for what I use SU - and that is somewhere between the scope of individual building architecture and landscape/urban size projects, it is accurate enough.
                                    I noticed that when surveyors survey land and sites, their "accuracy" is somewhere within the 10 centimetre (~ 4") "tolerance". When I measure an existing building, even if it is new and (supposedly) was built as accurately as the bricklayers/builder can go, there's at least about 1-2 cm (~ 1 ") "tolerance", too.
                                    Now why should my models be more accurate? (Of course, I can go for even more accuracy but other than getting things co-planar and arcs meeting in an arch, there's no reason for me).
                                      Point being is that in these types of discussions people tend to argue based on their own usage. Usage which often is never mentioned, so people argue on generic terms based on their specific experience. So two participants arguing their case can easily be both simultaneously right and wrong.
                                        Sorry for the question but as I never use with it 😳
                                        On a plotter (image above) circles from SU are transformed (postscript or other) or it's just like on the sreen so tiny segments ?
                                        From Jeff's answer seems yes (tiny segts)...
                                        • andybotA Offline
                                          andybot
                                          It's always segments as far as I know. Those circles in the mind of SU never translate into CAD circles. I find I have to redraw parts of an autocad export from sketchup because those line jagginess can look really awful on an otherwise smooth plot. Also, all the overlapping and partial line segments are just awful to work with. Don't know if Layout does anything different though, I don't imagine so.
                                            Trogluddite
                                            @thomthom said:
                                            Enough for what
                                            He he, yes I was being lazy with my words! "Enough" meaning - enough for the model to meet its ultimate purpose, as decided by the end user (or his/her client/customer).
                                            As you also hinted - the original question is unanswerable because we do not know the purpose of the model - without this information no definitive answer can be given, nor can the OP gauge the usefullness of any advice offered.
                                            The "universe" to "atoms" comparison is interesting - the units within SU are only notional, we are free to interpret the text labels as we wish. I could arbitrarily decide that the letter "m" really means miles or microns (or Mega light years!) if it made my model making more simple - and this would require no adjustment to the internal number representation of the software. In fact, we can see that this is even advisable sometime - use metres as a millimetre substitute to avoid the "small faces" problem.
                                            • 11
                                            • 25
                                            • 26
                                            • 9 / 26
