    [Plugin] CleanUp
    974 Posts 217 Posters 861.3k Views 217 Watching
      AlainBo
      Hello,
      When I export my model with LumenRT, it fails because it finds a zero length vector !?!
      It seems Cleanup cannot find such problem.
      How to find it?
      Is it possible to improve cleanUp to take it in account?
      Alain
        Hello,
        How to find it?
        Alain
        Can you provide a sample model?
        This zero length vector - is that from an error you get? Can you post the whole error?
        It could be that it is a bug in LumenRT's exporter - and not a model problem.
          AlainBo
          I found the problem, not precisely but it was related to a scene and not to the model.
          I did't really understand what caused the bug but it's sure it's not a geometry issue.
          Thanks a lot.
            tspco
            What did I do wrong? I just downloaded and installed cleanup 3.1.9 and latest ttlib 2.6 I open the model and run the plugin, The screen goes gray, and a long gray box appears with no options to select from. The ttlib file goes into the compatibility files folder, I think that is the problem. I cannot move in back into the regular plugins folder
            SU make 2017, /Twilight Render Hobby
            Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
              tspco
              I read back a few pages and found the issue, I now have the tt simple installer, and all "appears" as it was.
                Ensure that you have 'full access rights' to the Plugins folder [select its icon Properties > Security ...].
                Also do the same for Components, Materials and Styles...
                This will stop 'Compatibility Files' issues - where Vista stops you moving files/folders into certain 'program' folders to protect you from yourself if you have limited access rights... With full-rights it should behave...
                  tspco
                  I apparently already set permissions for everyone but the creator owner will not change, I am sure it is a windows thing I really don't need to know.
                    Why mess with that just give yourself 'full-permissions'...
                    • genma saotomeG Offline
                      genma saotome
                      Dunno if this has been mentioned before (40 pages is a lot to go thru) but the statistics presented afterwards are off. I'll run cleanup and be told it cleaned out quantities a, b, and c of types x, y, and z... do nothing, run cleanup again and be told it cleaned out quantities a, b, and c of types x, y, and z... and... rinse and repeat forever. Version 3.1.9.
                      I like the results... but I do wish it would tell the the straight story when it was done.
                        It's because SU some times doesn't heal broken edges after all - probably some accuracy issue. To rework it to be 100% accurate might slow it down significantly. I figured that the stats being in the ball park would be good enough.
                          genma saotome
                          Edges... that was one... ok, I understand. One of the others I recall now was a count of deleted components. Would delete 13, then another 13, etc., etc.
                          In truth, the numbers are a nice thing but not essential. I figure if you're aware and later happen to notice something the two might click and something gets fixed. Otherwise, oh well.
                            ?!? Got a sample model for that?
                            • john2J Offline
                              john2
                              how can i make cleanup not delete coplanar lines (like imported drawings from cad) which are locked?
                              Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                I have that in the list of bugs: https://bitbucket.org/thomthom/cleanup/issue/2/locked-groups-components-are-cleaned-up
                                • john2J Offline
                                  john2
                                  so when do we see this "don't delete the lockd objects version?" πŸ˜‰
                                  • kingsiK Offline
                                    kingsi
                                    Already said thanks for this plugin before, but felt had to say Tusen Takk!! when it just cleaned out 3million lines lol. Bloody genius
                                    Noobtastic
                                      πŸ‘ πŸ˜„
                                        kandehalux
                                        dang it....sorry for bothering, love your plugins!
                                        now a problem occured with the installation of cleanup:
                                        the TT_Lib2 is in the Plugins folder, the cleanup.rb is in the plugins folder.
                                        but when starting up sketchup i get this message:
                                        Error Loading File tt_cleanup.rb
                                        uninitialized constant TT::GUI
                                        in the forum i found suggestions with missing dlls on various windows, but no change. other plugins work fine.
                                        I'm on Win7 x64 using Sketchup 8.0.3117
                                        in addition i have to say,
                                        previously i resetted my pc and of course installed sketchup. before that, cleanup worked like a charme. i still have a backup of the old installation, so i tried using the older version of cleanup and ttlib, but i got the same message.
                                        any idea?
                                          Sounds like TT_LIb2 isn't installed correctly, there should be a TT_Lib2 folder with lots of .rb files in it.
                                          I made a small utility that makes it easier to install plugins correctly: http://forums.sketchucation.com/viewtopic.php?t=42315
                                          I recommend you update to the latest Maintenance Release 3 - it includes several bugfixes etc.
                                            kandehalux
                                            alright, so i updated to the m3 release v8.0.14346 (didnt really notice that it was an actual update due to the version number). the plugins are installed correctly.
                                            in the meantime i found out, that it must have something to do with the template-loader of sketchup. because every plugin loads correctly, when i start directly with an skp-file (even with original template-skps). if i start sketchup without an skp, half of the plugins dont load.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 48
                                            • 49
                                            • 19 / 49
