    Draw 3D arc point to point
    25 Posts 9 Posters 1.7k Views 9 Watching
    • brookefoxB Offline
      brookefox
      I can fake it OK with 'tools on surface' plugin, after hoping and failing to do it by simply moving one end through Z, but I'd like to do it properly, accurately, smoothly. The usual inference clues for tangency don't seem to display.
      ~ Brooke
        Would an intersecting plane give the arc you want?
          brookefox
          That's a good idea... Draw the 2d arc, close the shape to get a face, pull it up and intersect the volume with a tilted plane.
          At that point it would be short, though, so it could be scaled to fit.
          ~ Brooke
            One possible problem is the shape you got is sort of a helical shape so a single plane wouldn't do the trick. So, let's think about an alternate approach.
              brookefox
              I see. It would take at least two such intersections, or an infinite number, I am not sure at the moment.
              I thought I might be able to do a vertical scaling, but no such luck, except for this fakery.3D ARC-2.JPG
              Perhaps I'm just asking too much. It is not really an arc from point to point but rather several, tangential...
              Still, if one could just make it sticky at the origin and move the end up vertically and have the usual sticky stretchy deformation happen, that would do it.
              ~ Brooke
                MattC
                Hi , I see it like that:
                • Assume that You select curve, that means you can calculate distance from beginning to every vertex , lets call it "di" for i-vertex. Total length of a curve will be "L"
                • Start vertex stays in his place and end vertex will be moved with a distance "z" up
                • Every vertex in between will move up by a value "dz" where dz=z*di/L
                  This will give you linear slope, for other possibilities (expotential, etc. ) dz will be calculated with another equation
                Maybe someone can write a simple plugin ?
                Matt
                • jeff hammondJ Offline
                  @matt
                  that's already possible with tools on surface
                  @brooke
                  which tool in TOS are you using? arc on surface?
                  if so, try using a simple line on surface.. click on the start point then the end point and that's it.
                  that should give you what you want (unless I'm missing something.. I think your use of the words arcs and tangent are confusing me here as it's very unlikely the resulting curve and/or segment of said curve will be an arc)
                  • gillesG Offline
                    gilles
                    Have you tried Shape bender?
                      brookefox
                      @Matt I did think of calculating the linear slope, but being lazy, wanted something easier and thought modelers with better skills than mine could nail it quicker. Perhaps shape bender can help with the slope calc (see below).
                      @Jeff I was using TOS arc but tried other TOS tools as well. TOS draw line wants to do the job and comes quite close but does not, for me. I can get it to make 3 tangent arcs but not resulting in the end at my desired end, or to accept my endpoint for one, which would be the ticket. There's hope there. If I were more proficient with it, probably. Fredo built it with what appear to be such robust inferencing tools that probably I just need to practice. Can you get it to work?
                      @gilles I had thought of shape bender also but am not sure how to use it here. One possibility: take the 2d arc copy it up; join the arcs to make a face, unroll the face; connect the end points, thus getting the new 3d arc (with linear slope) unrolled; roll it back up. Can shape bender roll it back up? I must try. Seems like what is needed is shape unbender and rebender; after a quick look it does not look like shape bender at present can do this. Further tips?
                      Thanks very much for your tips. Very much appreciated.
                      ~ Brooke
                        ah.. ok. I think I'm understanding what you're after a little better now..
                        the best way (which isn't possible in sketchup afaik) would be to have a soft selection/move tool.. thomthom has shown us this is possible with his vertex tools (as well as the sandbox tools) but neither would work in this case.. you'd want to move one end of the arc up while each subsequent vertex of said arc receives less and less weight until the final seqment which won't move at all..
                        there is a way to get what you want if you're looking for utmost accuracy but it involves a lot of manual drawing.. shapebender will work as well but it's also going to require some manual drawing (customized arcs) prior to running it.
                        I'll try to upload an example file later tonight to show my technique.
                        (can't do it now.. I'm at a 6yr old's bday party 😄 )
                        • charly2008C Offline
                          charly2008
                          @matt
                          be an arc)
                          I Have tried it with the line but it does not work. I do not know if I did something wrong.
                          Untitled.skp
                            brookefox
                            I don't think you did anything wrong, the tool just isn't cooperating. If you did as you did but instead of clicking the desired endpoint, travel along the surface toward it and note the line proposed by TOS, it looks good, but apparently since the desired end wraps a bit, as it were, TOS gets confused or wants to go another way. Drawing the line with multiple segments allows inferencing from the first drawn, say to continue along the same path or something equivalent but since the end has not been accurately input the result here will not be as desired, though it may be quite similar. Does this make sense?
                            @Jeff please do post something if it is quick and easy but don't trouble yourself otherwise. Q and E is what the doctor prescribed.
                            I still think TOS is the key, I just can't make it work.
                            ~ Brooke
                              This is an interesting puzzle. I just had a thought that we need some method of flattening the curved surface to allow drawing the sloped line and then rolling it back up. I envision something a bit like the way the Scale tool can be used with components for avoiding the small face issue. For example, if I want to draw a small item with detailed curves--a small, turned knob for example. I will draw the profile and a Follow Me path. Then I make all of that geometry a component, copy it and scale up the copy by 100 times or something. I then open the large copy for editing and run Follow Me. After the operation is complete, I close the large copy and delete it. The original copy which is still the proper size been made with no holes in it.
                              So, could a plugin be created to flatten out a copy of a component without flattening the original instance?
                              • gillesG Offline
                                gilles
                                If you want a linear slope I see no problem with Shape bender.
                                You will need some extra plugins:
                                -BZ tools
                                -Weld
                                #1 draw your three arcs
                                #2 weld them
                                #3 select the resulting curve, in context menu choose BZ convert to, choose polyline segmentor, choose how many segments.
                                #4 select your curve, in entity info look at its length, let say 1000.
                                #5 on red axis draw a triangle length 1000 height ,let say 400 then make it a group.
                                #6 on red axis draw a line length 1000.
                                #7 apply Shape bender, note that you may have to use arrow keys to get the result you expect.
                                • Rich O BrienR Online
                                  Something like this?
                                  [flash=800,600:2f3ymz0f]http://www.youtube.com/v/LzuiBX-N7Fc[/flash:2f3ymz0f]
                                    brookefox
                                    My experience here with trying to use TOS inferencing is that the same inference, drawn from the same edge, can lead to seemingly contradictory results, though both can be 'logical'.
                                    The first segment is drawn, sloping up, and the second is meant to continue this as if tangent. The continue along edge inference is locked and the resulting line slopes up and then down, even though the first was only sloping up. It is as if at some point the tool says OK, this line is sloping down, which of course it is: any up sloping line is also sloping down from the other end.
                                    ~ Brooke
                                      brookefox
                                      That sure looks like it, Rich.
                                      Fredo Tools Curvishear. I will go-a-looking.
                                      Thank you.
                                      And thank you, gilles, I will try that.
                                      ~ Brooke
                                      • kenK Offline
                                        ken
                                        Rich
                                        I wasn't looking for this, however, you demo was impressive. It is hard to keep up with all the plugins and what exactly they will do.
                                        So thanks Rich
                                        Ken
                                        • gillesG Offline
                                          gilles
                                          Curvishear !!
                                          I forgot this one, yes too much plugins.
                                            oh wait.. if curvishear is doing it then I guess I didn't actually realize what you wanted. 😳
                                            I was picturing 3 different radius arcs being tangent at the start point then being applied to a curved surface..
                                            (which is possible to do btw.. just not with plugins (yet))
                                            please ignore my post in the thread 😄
