    (TRICK) To re-enable skp file preview
    147 Posts 60 Posters 206.8k Views 60 Watching
      Very weird. I haven't tried it yet. How'd you think to try that?
      -Brodie
      He's using 32bit windows.
      • brodieB
        brodie
        Oh, i didn't catch that. Thanks
        -Brodie
        • halroachH
          halroach
          I recently came across sage thumbs (free) which uses XNview libraries to view thumbnails right in explorer in windows 7 64bit.
          http://code.google.com/p/sagethumbs/
          It works well with PSD files, and all sorts of others, but skp files don't seem to be supported yet. I tried contacting the developer of sage thumbs (I think I contacted the right guy) and he just forwarded me to the xnview forums...
          http://newsgroup.xnview.com/viewtopic.php?t=19690&p=82964#p82964
          It seems like someone is trying to get skethcup to be supported, but I can't quite figure out where it's standing right now, I'll keep at it. anyway, If anybody else would like to pour their two cents into those forums to get it going... go for it!
          FlexTools - Super Quick Windows, Doors, Slats...
            MysticThumbs got .SKP support. Even .SKM - and lots more: http://mysticcoder.net/mysticthumbs.html
            • halroachH
              halroach
              Mystic Thumbs isn't free... and following this thread, it seems like some people are suffering from OS performance issues after installing...
              I've got Sagethumbs running, with no aparent problems yet, other than the iny tiny issue that it doesn't support skp or skm 😄
                I use MysticThumbs - well worth it the the amount of file formats it support. There are so many other applications that doesn't provide thumbnails for 64bit systems.
                • brodieB
                  brodie
                  I'd second Thomthom's mystic thumbs recommendation. It's not free but it's the sort of software you can buy super cheap and then forget about. It just works. I've been using it for a couple years now.
                  I tried sage and I tried getting used to xnview and some other softwares but in the end I found that if I couldn't have thumbnails within explorer and I had to keep fiddling around with a program to try to get it to do what I wanted, it wasn't going to work. With mystic, you don't have to change your workflow or anything.
                  -Brodie
                  • bazB
                    baz
                    Just in case it hasn't been mentioned. Adobe Bridge, part of the CS suite, will preview skp. files.
                    • G
                      geomp
                      No it doesn't.
                      Not on my Mac.
                      What's the best solution for Mac?
                      • bazB
                        baz
                        @geomp said:
                        No it doesn't.
                        Not on my Mac.
                        It had to happen sometime: Windows=1, Mac=0 😍
                        "What's the best solution for Mac?" Why that's obvious 😉
                          driven
                          check out Jeff's earlier post, GraphicConvertor.app is still the best solution I'm aware of...
                          • brookefoxB
                            brookefox
                            Doesn't work for me; Vista 64, Bridge CS5 4.0.4.2.
                            Any particular settings, etc.?
                            ~ Brooke
                            • bazB
                              baz
                              Hi Brooke, no particular settings. Windows 7 pro. CS5 4.05.11.
                              • brookefoxB
                                brookefox
                                Well, that's weird and not good. I'll have to continue this slog.
                                Thanks for getting back.
                                I can find no mention of skp support anywhere in the prog or searching 'adobe bridge supported file formats skp sketchup' variants.
                                You got a super bridge.
                                ~ Brooke
                                • P
                                  penumbra
                                  in Windows 7, at least on my machine, if you browse to a folder containing Sketchup files with say, internet explorer, the icons magically reappear.
                                  • broomstickB
                                    broomstick
                                    That IS weird. Normal explorer windows won't show preview. Explorer window from brows in internet explorer? There you go!
                                    Any registry hack we can think of to replicate the behaviour?
                                      If you use the File Dialogs of 32bit applications (such as for instance SketchUp) you will see thumbnails - because SketchUp only ship 32bit thumbnailer. I'm guesssing you're starting the 32bit version of IE instead of the 64bit version.
                                      • P
                                        penumbra
                                        @ ThomThom. Yep. running the 32 bit IE. don't know why that is since i have 64 bit Win7...
                                          Think it's default as browser extensions are mainly available in 32bit... ...just guessing.
                                          • broomstickB
                                            broomstick
                                            you're right!
                                            • 4 / 8
