    (TRICK) To re-enable skp file preview
    147 Posts 60 Posters 204.4k Views 60 Watching
    • E
      Ecuadorian
      Any alternatives to Mystic Thumbs? I tried it and it gave me a couple of problems including freeze-ups... so if you guys have found any other way, I would be grateful to know it.
      Also, it seems that Mystic Thumbs does not uninstall completely, as I still have some thumbnails it generated and now I'm in a worse situation than before installing it, as now I can't see thumbnails in the File > Open window, whereas before I was always able to see thumbnails in this window.
      -Miguel Lescano
        Jim
        I've heard, but haven't used http://www.xnview.com/
        • brodieB
          brodie
          xnview works very well, but it does require a bit of a workflow change that I just couldn't get used to. Basically you have to start using it rather than windows explorer to see the thumbnails. It's worth a shot if Mystic Thumbs didn't work for you (which is what I use on my Win7 machine).
          -Brodie
          • mooshonovM
            mooshonov
            I GOT IT!!!
            my machine is win 7 ultimate 32 bit
            su 8
            All i had to do is to change the name of the exe on program files/google/google sketchup 8/sketchup.exe
            TO: "Google SketchUp 8"[.EXE] and it worked! i can see now thumbnail of all skp files!
            hope this was helpful for ya'll
            shalom!
            Moshe.
            **V-Ray for SketchUp eBook author
            Buy your copy now at vfsbook.com**Licensed Instructor
            Chaos Group Partner
            CEO @ V-Ray Israel
            • brodieB
              brodie
              Very weird. I haven't tried it yet. How'd you think to try that?
              -Brodie
                -Brodie
                He's using 32bit windows.
                • brodieB
                  brodie
                  Oh, i didn't catch that. Thanks
                  -Brodie
                  • halroachH
                    halroach
                    I recently came across sage thumbs (free) which uses XNview libraries to view thumbnails right in explorer in windows 7 64bit.
                    http://code.google.com/p/sagethumbs/
                    It works well with PSD files, and all sorts of others, but skp files don't seem to be supported yet. I tried contacting the developer of sage thumbs (I think I contacted the right guy) and he just forwarded me to the xnview forums...
                    http://newsgroup.xnview.com/viewtopic.php?t=19690&p=82964#p82964
                    It seems like someone is trying to get skethcup to be supported, but I can't quite figure out where it's standing right now, I'll keep at it. anyway, If anybody else would like to pour their two cents into those forums to get it going... go for it!
                    FlexTools - Super Quick Windows, Doors, Slats...
                      MysticThumbs got .SKP support. Even .SKM - and lots more: http://mysticcoder.net/mysticthumbs.html
                      • halroachH
                        halroach
                        Mystic Thumbs isn't free... and following this thread, it seems like some people are suffering from OS performance issues after installing...
                        I've got Sagethumbs running, with no aparent problems yet, other than the iny tiny issue that it doesn't support skp or skm 😄
                          I use MysticThumbs - well worth it the the amount of file formats it support. There are so many other applications that doesn't provide thumbnails for 64bit systems.
                          • brodieB
                            brodie
                            I'd second Thomthom's mystic thumbs recommendation. It's not free but it's the sort of software you can buy super cheap and then forget about. It just works. I've been using it for a couple years now.
                            I tried sage and I tried getting used to xnview and some other softwares but in the end I found that if I couldn't have thumbnails within explorer and I had to keep fiddling around with a program to try to get it to do what I wanted, it wasn't going to work. With mystic, you don't have to change your workflow or anything.
                            -Brodie
                            • bazB
                              baz
                              Just in case it hasn't been mentioned. Adobe Bridge, part of the CS suite, will preview skp. files.
                              • G
                                geomp
                                No it doesn't.
                                Not on my Mac.
                                What's the best solution for Mac?
                                • bazB
                                  baz
                                  @geomp said:
                                  No it doesn't.
                                  Not on my Mac.
                                  It had to happen sometime: Windows=1, Mac=0 😍
                                  "What's the best solution for Mac?" Why that's obvious 😉
                                    driven
                                    check out Jeff's earlier post, GraphicConvertor.app is still the best solution I'm aware of...
                                    • brookefoxB
                                      brookefox
                                      Doesn't work for me; Vista 64, Bridge CS5 4.0.4.2.
                                      Any particular settings, etc.?
                                      ~ Brooke
                                      • bazB
                                        baz
                                        Hi Brooke, no particular settings. Windows 7 pro. CS5 4.05.11.
                                        • brookefoxB
                                          brookefox
                                          Well, that's weird and not good. I'll have to continue this slog.
                                          Thanks for getting back.
                                          I can find no mention of skp support anywhere in the prog or searching 'adobe bridge supported file formats skp sketchup' variants.
                                          You got a super bridge.
                                          ~ Brooke
                                          • P
                                            penumbra
                                            in Windows 7, at least on my machine, if you browse to a folder containing Sketchup files with say, internet explorer, the icons magically reappear.
                                            • 4 / 8
