    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
      This is what I use to detect temp path:
      TEMP_PATH = File.expand_path( ENV['TMPDIR'] || ENV['TMP'] || ENV['TEMP'] ).freeze
      • fredo6F Offline
        @tig said:
        I use
        tempdir=ENV["TEMP"] ### it's a PC == 'TEMP' or 'TMP' tempdir=ENV["TMPDIR"] if not tempdir ### it's a Mac
        πŸ˜•
        TIG,
        Actually, my mistake. Yes indeed, I use TMPDIR for Mac environment (or /tmp which may be more secure)
        @supercylon
        Can you type ENV["TMPDIR"] in the Ruby console
        Fred
          supercylon
          @supercylon
          Just in case, can you type ENV["TEMP"] in the Ruby Console and tell me what you see.
          Hello Fredo,
          Thanks for your assistance. I did what you asked and here is a screenshot of the result.
          ![Results of ENV["TEMP"] in Ruby Console](/uploads/imported_attachments/iUOu_Picture2.png "Results of ENV["TEMP"] in Ruby Console")
          Thanks Supercylon
            supercylon
            @tig said:
            I use
            πŸ˜•
            TIG,
            @supercylon
            Fred
            I didn't notice this message, here is the screen shot of the result of your second request.
            Thanks,
            Supercylon
              And ENV['TMP'] ?
                supercylon
                @supercylon
                Can you try withe attached file to see if your error disappear and SU starts OK.
                [attachment=0:2f69w8lx]<!-- ia0 -->LibFredo6.rb<!-- ia0 -->[/attachment:2f69w8lx]
                Fredo,
                Thank you!Thank you! It works!
                Supercylon
                • fredo6F Offline
                  Supercylon
                  I will release the change tomorrow as v4.3c
                  It is strange however that on your Mac, the TMPDIR Environment variable is not defined.
                  @TIG, Thomthom: I just use /tmp when TMPDIR is not defined.
                  • fredo6F Offline
                    @supercylon
                    EDIT: file removed. Now part of the release 4.3c, 31 Jan 12
                      baranya
                      Under Ubuntu makes SU to crach on startup
                      • fredo6F Offline
                        It's difficult for me to diagnose on this platform which I don't have.
                        I think there are a few users running Sketchup on Linux flavors, and they may help you to troubleshoot.
                        • Y Offline
                          yogaseeker
                          I ran into some trouble when I placed this plugin in the SU plugin folder. I thought this solution might help others.
                          "LibFredo6 4.3c - 31 Jan 12" is the name of the folder that I unzipped and I placed in my plugins folder. But that didn't work. You have to drag the contents of the "LibFredo6 4.3c - 31 Jan 12" folder (LIBFREDO6_Dir_43 and LibFredo6) out of that folder and put it in the plugins folder.
                          THanks so much for this wonderful plugin!!!
                            mingjae
                            Hello Mr.LibFredo..
                            I have a diifficulty to install curviloft using libfredo in my SU8,
                            it wont load and something wrong with the fredo, this is the picture :
                            http://img594.imageshack.us/img594/7065/99471562.jpg
                            I dont have lib tranductor.rb in Libfredo6 package neither on curviloft,
                            how to solve this Mr?
                            I also trying to copy the lib_tranductor.rb in my SU7 to SU8 plugins folder but it always crash after copying it... 😒
                            • fredo6F Offline
                              I would suggest you redo a clean installation and make sure you overwrite all existing files.
                              Just in case, can you type in the Ruby Console and report what you get:
                              Sketchup.find_support_file('LibTraductor.rb', "Plugins")
                                mingjae
                                Hi, thank for your reply
                                my SU8 in plugin folder have not installed by LibFredo and curviloft before,
                                so I just put all unzipped libfredo and curviloft in my plugins folder,
                                after I redo to overwrite it, it result the same, it not load "lib traductor.rb
                                and here is I copy paste after I enter it on ruby console:
                                "Sketchup.find_support_file('LibTraductor.rb', "Plugins")
                                C:/Program Files/Google/Plugins/LibTraductor.rb"
                                edit: perhaps the lib traductor.rb crashes in the Google/Plugins folder?
                                I copy the "Plugins" folder from my friend notebooks and place it there.
                                I cut the lib traductor there and place it in SU8 plugins folder and the curviloft success to load...
                                but, where can I get "lib traductor.rb", there's no in lib fredo zip and curviloft zipped file installer right?
                                • fredo6F Offline
                                  Actually you do not need LibTraductor.rb for Curviloft (it's only for backward compatibility that it is checked).
                                    mingjae
                                    really?? 😳
                                    lol..i'm sorry, but thanks my SU8 now loading without any error notification..
                                    • fredo6F Offline
                                      By the way, you seem to have a non-standard installation of SU8.
                                      Normally, Sketchup folders are located in C:/Program Files/Google/**Google SketchUp 8**.
                                      • ElibjrE Offline
                                        Elibjr
                                        Wow, Thank you very much. All of these plugins are truly a life saver. They bring Sketchup to a completely different level. I love them. And the more I use them the more I appreciate what they do. This had made Sketchup more than just a modeling toy to play with, these plugins (and others listed on the forum) allow the software to truly and indisputably become more of a productive too hands down! Thank you (and all of the other people who write rubies for this Software) again! WE should NEVER take ANY plugin listed here for granted! πŸ˜„
                                          cquinn
                                          Pardon my ignorance, but where can I find the latest LibFredo version file to download? I have an old version and recall finding it buried in a forum discussion but no such luck this time.
                                          THanks!
                                            in the first post of this topic.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 109
                                            • 110
                                            • 17 / 110
