    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 388.1k Views 80 Watching
      Aerilius
      This plugin allows to turn off (or on) certain elements of the SketchUp interface. Something that wasn't possible before. For example someone has no need for a statusbar, or to make SketchUp fullscreen for a presentation. Maybe Anton can make a little gif animation for the first post (or I could do one).
      • Rich O BrienR Online
        Please do. One of us can add it to Anton's OP for those that want to visualise its use.
          Aerilius
          I've created an animated gif of how it looks:
            Anton_S
            [attachment=0:1u31tebe]<!-- ia0 -->window styles.gif<!-- ia0 -->[/attachment:1u31tebe]
            Aerilius, thankyou really much!!! πŸ˜„ I'm just too lazy to add description myself.
              I wanna play 😞
              • guanjinG Offline
                guanjin
                Great, my Windows XP
                There is a problem, set the shortcut key to display the menu bar is invalid πŸ˜’ πŸ˜’
                  Anton_S
                  [attachment=0:28de3p4w]<!-- ia0 -->66666666666666.gif<!-- ia0 -->[/attachment:28de3p4w]
                  Yes, it should be invalid!!! Wanna know why? Well, I explained it a bit on first post. Its just the way of how shortcut pereferences works. Shortcut Pereferences script tends to select the menu bar items once the shortcut key is pressed. But, When the menu it self is no more there, Sketchup can no longer select the items. What's weird is that once u hide the menu bar other shortcuts that were set by sketchup (Ex: "s" - scale, "p" - push) work, but once u click the shortcut that belong to "show menu bar," all shortcuts stop working. Show/hide menu bar was just for fun, so yeah don't use it. Though, I'll try to fix that issue too.
                  • guanjinG Offline
                    guanjin
                    Thank you! Can not be restored, the canceled, resulting in unnecessary trouble πŸ˜’
                    • U Offline
                      unclex
                      only fullscreen can work
                      and
                      suggest to change the plugin menu from β€œPlugins” to β€œWindow"
                        Anton_S
                        @unclex said:
                        only fullscreen can work"
                        Is that about the updated or the first version?
                        • U Offline
                          unclex
                          updated
                          @ SU8.0.11
                          @ win7 pro patched 4GB
                            Anton_S
                            @unclex said:
                            updated
                            @ SU8.0.11
                            Is it 32 or 64 bit processor?
                            • U Offline
                              unclex
                              WellDone
                              Win7X86Pro
                              Su8.0.11Pro
                              except Toolbar, all worked
                              and i can not dare try the Menu Option, if i close it, how reopen it ??
                                Anton_S
                                @unclex said:
                                WellDone
                                Win7X86Pro
                                Su8.0.11Pro
                                The toolbars option is to hide toolbars that are not embedded into SU controll bar, meaning the onece that have a border and caption. They should work.
                                And yes, hide menu option is just for fun, There is no way of unhidding it through shortcut pereferences. Though you could set a timer or call a command to unhide it. Just read throuh posts and you'll figure it out.
                                Have you checked if show/hide "controll bars" work when SU is maximized or full_screen? If didn't, then can you please check that and reply.
                                  Anton_S
                                  updated february 10th, 2012
                                  Now works on windows 7 too!!! Well, read the 1st post for an info. πŸ˜‰
                                  Thankyou, for your replies and comments!!! They really improved the plugin plus my English. πŸ˜„
                                  Somehow, therefore, I don't strugle at the english essays anymore... ❗ 😍
                                  • CadFatherC Offline
                                    CadFather
                                    Hi Anton and Thank You - this is a really great plugin πŸ‘ β˜€
                                    is there a way that i could chain a few of those commands?
                                    say i press F12 and sketchup goes full screen + no controls + no status bar + no scene bar.. etc?
                                      Anton_S
                                      Well, rightnow threre isn't, but I'm planing to add two new command items to "window/settings". One will be "chain multiple" and the other "set multiple". The "chain multiple" will open a dialog box with a checkbox for each command ("full screen", "controll bar(s)", "status bar"...). The "set multiple" command item will show/hide the items that are checked in the dialog box. Like if "full screen" and "status bar" is checked, the "set multiple" command will toggle sketchup between "full screen" and show/hide "status bar".
                                      I already started doing that, but not having knowledge in html, javascript, css, and other will slow down the release of new version.
                                        CadFather
                                        sounds perfect Anton..looking forward to it..
                                          pololo
                                          For win7 64bits .... please!! πŸ˜’
                                            What do you mean by this? It should work as is. Nothing special about Win7 64bit. Do you get errors or anything when you try to use/load/install it?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 15 / 15
