    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 451.4k Views 80 Watching
      Aerilius
      I've been waiting to hide the menu bar (no joke). Thank you!
        Anton_S
        @anton_s said:
        use set_validation_proc and let it ask every frame whatever the status_bar is hidden or not. I could make it like that, thought it will slow down sketchup
        Have to take my thought back. I thought that set_validation_proc updates every frame, but it only updates once you entered the submenu that contains that item. So, yes I'll modify it to be toggled, including make it work on windows 7 64 bit.
        Thankyou for your replies!! They make me πŸ˜„
        • dereiD Offline
          derei
          What exactly this plugin does? From Rich O'Brien's post (http://forums.sketchucation.com/download/file.php?id=81834&mode=view) I understand that it doesn't work... so let me rephrase: what this plugin SHOULD do?
          Thank you very much.
          P.S. - when posting plugins, it would be nice to add a image/animated GIF/movie to visually exemplify what the plugin does, if possible. Some users are already doing this, but I think it should be implemented as a "must" rule, for everybody.
          DESIGNER AND ARTIST DEREI.UK
            ...on his system. For Gaieus it worked.
              Aerilius
              This plugin allows to turn off (or on) certain elements of the SketchUp interface. Something that wasn't possible before. For example someone has no need for a statusbar, or to make SketchUp fullscreen for a presentation. Maybe Anton can make a little gif animation for the first post (or I could do one).
                Please do. One of us can add it to Anton's OP for those that want to visualise its use.
                  Aerilius
                  I've created an animated gif of how it looks:
                    Anton_S
                    [attachment=0:1u31tebe]<!-- ia0 -->window styles.gif<!-- ia0 -->[/attachment:1u31tebe]
                    Aerilius, thankyou really much!!! πŸ˜„ I'm just too lazy to add description myself.
                      I wanna play 😞
                      • guanjinG Offline
                        guanjin
                        Great, my Windows XP
                        There is a problem, set the shortcut key to display the menu bar is invalid πŸ˜’ πŸ˜’
                          Anton_S
                          [attachment=0:28de3p4w]<!-- ia0 -->66666666666666.gif<!-- ia0 -->[/attachment:28de3p4w]
                          Yes, it should be invalid!!! Wanna know why? Well, I explained it a bit on first post. Its just the way of how shortcut pereferences works. Shortcut Pereferences script tends to select the menu bar items once the shortcut key is pressed. But, When the menu it self is no more there, Sketchup can no longer select the items. What's weird is that once u hide the menu bar other shortcuts that were set by sketchup (Ex: "s" - scale, "p" - push) work, but once u click the shortcut that belong to "show menu bar," all shortcuts stop working. Show/hide menu bar was just for fun, so yeah don't use it. Though, I'll try to fix that issue too.
                          • guanjinG Offline
                            guanjin
                            Thank you! Can not be restored, the canceled, resulting in unnecessary trouble πŸ˜’
                            • U Offline
                              unclex
                              only fullscreen can work
                              and
                              suggest to change the plugin menu from β€œPlugins” to β€œWindow"
                                Anton_S
                                @unclex said:
                                only fullscreen can work"
                                Is that about the updated or the first version?
                                • U Offline
                                  unclex
                                  updated
                                  @ SU8.0.11
                                  @ win7 pro patched 4GB
                                    Anton_S
                                    @unclex said:
                                    updated
                                    @ SU8.0.11
                                    Is it 32 or 64 bit processor?
                                    • U Offline
                                      unclex
                                      WellDone
                                      Win7X86Pro
                                      Su8.0.11Pro
                                      except Toolbar, all worked
                                      and i can not dare try the Menu Option, if i close it, how reopen it ??
                                        Anton_S
                                        @unclex said:
                                        WellDone
                                        Win7X86Pro
                                        Su8.0.11Pro
                                        The toolbars option is to hide toolbars that are not embedded into SU controll bar, meaning the onece that have a border and caption. They should work.
                                        And yes, hide menu option is just for fun, There is no way of unhidding it through shortcut pereferences. Though you could set a timer or call a command to unhide it. Just read throuh posts and you'll figure it out.
                                        Have you checked if show/hide "controll bars" work when SU is maximized or full_screen? If didn't, then can you please check that and reply.
                                          Anton_S
                                          updated february 10th, 2012
                                          Now works on windows 7 too!!! Well, read the 1st post for an info. πŸ˜‰
                                          Thankyou, for your replies and comments!!! They really improved the plugin plus my English. πŸ˜„
                                          Somehow, therefore, I don't strugle at the english essays anymore... ❗ 😍
                                          • CadFatherC Offline
                                            CadFather
                                            Hi Anton and Thank You - this is a really great plugin πŸ‘ β˜€
                                            is there a way that i could chain a few of those commands?
                                            say i press F12 and sketchup goes full screen + no controls + no status bar + no scene bar.. etc?
                                            • 14
                                            • 15
                                            • 1 / 15
