    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 543.8k Views 172 Watching
      @farmerjoe50 said:
      I dropped file into plugins folder but it is not showing up in sketchup...I noticed the file is .rar, not a rb file. What is the secret?
      Doh!
      A .rar file is a compressed file - like a .zip file - just made by another application.
      So, like with a zip file you must extract its contents - i.e. the .rb file and intact subfolder[s] of miscellaneous files that then go into the Plugins folder.
      There's a sticky-post in the Plugins Forum about installing tools from zip files - read that - substituting 'rar' when it says 'zip'...
      πŸ˜‰
      • F
        farmerjoe50
        momentary lapse of reason....got it.
        • V
          Vicspa
          I tried all 3 versions, none worked properly, but after reading all 25 pages of forum, and about an hour and a half of loading and re-loading plugins, it's FINALLY working well for me, hope it stays that way. Rendering in Thea,
          but the alpha channels do not import, but no big deal, I do it manually, and renders just fine.
          Thank you Pierreden.
          • bigstickB
            bigstick
            I didn't have your patience to get it to work. I did install it and the dialog worked fine. It just didn't seem to 'grow' the ivy, and it's not like I didn't check the installation and read up about it. The reality is that I didn't need the functionality enough to put the time and effort in.
            The frustrating thing is that it looks like a really excellent plugin, but it needs sorting out before it's ready for most users.
            If a lot of people have to make a considerable effort to get it working after 25 pages of posts, it shows that more work is necessary.
            Sorry - I don't mean any criticism or disrespect to the author in the slightest, it seems to be a wonderful plugin and the effort you have made is very much appreciated!
            • V
              Vicspa
              I hear you Bigstick, it seems to be working on/off and can get frustrating, but it promises to be a great plugin, and I hope all the bugs will be worked out.
              • bigstickB
                bigstick
                Agree 100%, I really hope these niggles can be fixed, because for lots of users it will be a 'must have'! The only reason I haven't persisted more is time unfortunately. All my spare time is taken up with SUPodium, and I would love to get the two to work together nicely.
                Actually this could be the basis of a tree/plant generator, to make any kind of plant. Huge undertaking though I suspect...
                • irwanwrI
                  irwanwr
                  πŸ‘ i totally agree on that opinion, bigstick.
                  at least from the description and exhibits showing what it might capable of.
                    I'm using sketchup 8
                    The leaf size outcome look nice at sketchup
                    but everytime i render, it become standard value size (5)
                    anyone can help me with this issue ?
                    Many thanks
                    • C
                      cmuhleman
                      Great looking plugin. This would be immensely practical for a few projects i've got sitting around.
                      I gave the 0.6.3 and also the last stable version a try on my mac and can't seem to get it to work. I'm running Sketchup 8.0.11751 on a Mac.
                      I'm having a similar issue to bigstick. It's creating the paths and generating spots for leaves, but wont actually create the volumes.
                      Keep up the good work! This one's a winner.
                      • irwanwrI
                        irwanwr
                        I just realised that this plugin put components into a model right away after sketchup started.
                        Does it meant to work that way?
                        Found Ivy's components in the comp browser when I check it. After seeing how a door model file size became around more than 1 MB.
                        Still learning to use this plugin.
                        Thank you Pierre
                        • bigstickB
                          bigstick
                          Yeah, it's not really ready for general use yet because there are far too many anomalies. The inserting leaves into every model is one example, which causes problems with other plugins.
                          I really don't intend any criticism of Pierreden (because he's been kind enough to share the results of huge amounts of work with us for free) because this plugin is almost spectacular, and we all owe him thanks for his time and generosity.
                          I've tried for a long time to try to work out what the problem is, but I have failed to make it work. I don't have the time or need for the results to devote any more time to making it work, and if it requires hours of effort for at least some people, something doesn't seem quite right.
                          • T
                            tomot
                            How Sad! the last time I used this Ivy generator all was well, I even recall posting a set of alternative IVY leaves, I don't know whats happened since. Perhaps the latest release of SU is at fault.
                            1. trying to open any of the 3 Ivyleaf files Ivyleaf_1.skp, Ivyleaf_2.skp, Ivyleaf_3.skp causes an instant SU Bugsplat!
                            2. opening the Ruby Console, run the Ivy generator and a list of errors scrolls by.
                            3. the stem is not created!
                            4. the leaves do not get attached!
                            Argh!
                            my plugins
                            tomot
                            • T
                              tpskinner
                              Hey guys...
                              Ive been trying to go through all the posts and I realise that theres been some issues with MAC but some seem to have got it to work...
                              Ive got SU8... I unpacked the 0.6.3 RAR file and put the files into my plugins folder. I can open the Ivy window with all the various options... but when I click on the model nothing happens. Ive tried various clicks and alt clicks cmd clicks... but nothing. There are no error messages, just nothing happens.
                              Any ideas?
                              Tim
                              • OxerO
                                Oxer
                                @tpskinner said:
                                Hey guys...
                                Any ideas?
                                Tim
                                Hi Tim, i use Mac too see this http://forums.sketchucation.com/viewtopic.php?f=323&t=36882&start=330 the las post.
                                • T
                                  tpskinner
                                  Hey guys...
                                  Still can't get this plugin to work... Im on Mac, SU8 and using 0.6.3 Ivy.
                                  I can successfully open the parameters dialogue box and move sliders etc... However, this is all I can do. Clicking on my model does nothing, CMD clicking does nothing etc.
                                  any ideas?
                                  Thanks,
                                  Tim
                                  • C
                                    Cyberdactyl
                                    Been enjoying the plugin a lot. Thank you very much Pierreden.
                                    I've read through this massive thread and understand why half the leaves have the white background. But I'm curious why some leaves have a transparent square for the textures behind, yet has an edge that sees completely through a copy of the same texture?!
                                    Is there any more versions of this going to be released? I see it hasn't been worked on in 10 months.
                                    http://img.photobucket.com/albums/v606/Cyberdactyl/SketchUp/leaves.jpg
                                      arqmiguelc
                                      i fkn love you! great work although i had to modify the leaves components in order to have transparency on my leaf backround, but it works really fine!
                                      One more question, when are you planning to pull up a new version of the plug in? you should spread this worldwide, it is a fantastic idea.
                                      greetings from mexico.
                                      • KrisidiousK
                                        Krisidious
                                        can we see some people's settings for certain types of results and can we see the default settings?
                                        By: Kristoff Rand
                                        • KrisidiousK
                                          Krisidious
                                          I had to resave each of the leaves as a new sketchup file with the original name. I also saved them using png textures that I saved into the same textures folder so I could have transparency.
                                          this fixed the issue of the vine not producing leaves or branches.
                                          here are the default settings if you mess them up and can't find your way back.
                                          By: Kristoff Rand
                                            jellybean2012
                                            I hope you can help because your render looks awesome - I've installed it and followed your instructions which all seem to work perfectly - however, when I try and render it in vRay it's not visible -- it's like it doesn't exist...
                                            am i just being thick?
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 36
                                            • 37
                                            • 20 / 37
