    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 543.8k Views 172 Watching
    • C
      cmuhleman
      Great looking plugin. This would be immensely practical for a few projects i've got sitting around.
      I gave the 0.6.3 and also the last stable version a try on my mac and can't seem to get it to work. I'm running Sketchup 8.0.11751 on a Mac.
      I'm having a similar issue to bigstick. It's creating the paths and generating spots for leaves, but wont actually create the volumes.
      Keep up the good work! This one's a winner.
      • irwanwrI
        irwanwr
        I just realised that this plugin put components into a model right away after sketchup started.
        Does it meant to work that way?
        Found Ivy's components in the comp browser when I check it. After seeing how a door model file size became around more than 1 MB.
        Still learning to use this plugin.
        Thank you Pierre
        • bigstickB
          bigstick
          Yeah, it's not really ready for general use yet because there are far too many anomalies. The inserting leaves into every model is one example, which causes problems with other plugins.
          I really don't intend any criticism of Pierreden (because he's been kind enough to share the results of huge amounts of work with us for free) because this plugin is almost spectacular, and we all owe him thanks for his time and generosity.
          I've tried for a long time to try to work out what the problem is, but I have failed to make it work. I don't have the time or need for the results to devote any more time to making it work, and if it requires hours of effort for at least some people, something doesn't seem quite right.
          • T
            tomot
            How Sad! the last time I used this Ivy generator all was well, I even recall posting a set of alternative IVY leaves, I don't know whats happened since. Perhaps the latest release of SU is at fault.
            1. trying to open any of the 3 Ivyleaf files Ivyleaf_1.skp, Ivyleaf_2.skp, Ivyleaf_3.skp causes an instant SU Bugsplat!
            2. opening the Ruby Console, run the Ivy generator and a list of errors scrolls by.
            3. the stem is not created!
            4. the leaves do not get attached!
            Argh!
            my plugins
            tomot
            • T
              tpskinner
              Hey guys...
              Ive been trying to go through all the posts and I realise that theres been some issues with MAC but some seem to have got it to work...
              Ive got SU8... I unpacked the 0.6.3 RAR file and put the files into my plugins folder. I can open the Ivy window with all the various options... but when I click on the model nothing happens. Ive tried various clicks and alt clicks cmd clicks... but nothing. There are no error messages, just nothing happens.
              Any ideas?
              Tim
              • OxerO
                Oxer
                @tpskinner said:
                Hey guys...
                Any ideas?
                Tim
                Hi Tim, i use Mac too see this http://forums.sketchucation.com/viewtopic.php?f=323&t=36882&start=330 the las post.
                • T
                  tpskinner
                  Hey guys...
                  Still can't get this plugin to work... Im on Mac, SU8 and using 0.6.3 Ivy.
                  I can successfully open the parameters dialogue box and move sliders etc... However, this is all I can do. Clicking on my model does nothing, CMD clicking does nothing etc.
                  any ideas?
                  Thanks,
                  Tim
                  • C
                    Cyberdactyl
                    Been enjoying the plugin a lot. Thank you very much Pierreden.
                    I've read through this massive thread and understand why half the leaves have the white background. But I'm curious why some leaves have a transparent square for the textures behind, yet has an edge that sees completely through a copy of the same texture?!
                    Is there any more versions of this going to be released? I see it hasn't been worked on in 10 months.
                    http://img.photobucket.com/albums/v606/Cyberdactyl/SketchUp/leaves.jpg
                      arqmiguelc
                      i fkn love you! great work although i had to modify the leaves components in order to have transparency on my leaf backround, but it works really fine!
                      One more question, when are you planning to pull up a new version of the plug in? you should spread this worldwide, it is a fantastic idea.
                      greetings from mexico.
                      • KrisidiousK
                        Krisidious
                        can we see some people's settings for certain types of results and can we see the default settings?
                        By: Kristoff Rand
                        • KrisidiousK
                          Krisidious
                          I had to resave each of the leaves as a new sketchup file with the original name. I also saved them using png textures that I saved into the same textures folder so I could have transparency.
                          this fixed the issue of the vine not producing leaves or branches.
                          here are the default settings if you mess them up and can't find your way back.
                          By: Kristoff Rand
                            jellybean2012
                            I hope you can help because your render looks awesome - I've installed it and followed your instructions which all seem to work perfectly - however, when I try and render it in vRay it's not visible -- it's like it doesn't exist...
                            am i just being thick?
                              Can v-ray render 'images' inside a SKP ?
                              Some renderers can't.
                              Perhaps they need exploding ??
                              • KrisidiousK
                                Krisidious
                                I have no idea about that... sorry.
                                By: Kristoff Rand
                                • KrisidiousK
                                  Krisidious
                                  love this plugin... still trying to get the hang of it. I don't seem to get consistent results. like adhesion doesn't seem to really make the vine adhere as it does make it grow shorter distances with each click.
                                  By: Kristoff Rand
                                  • T
                                    tomot
                                    This Ivy generator is a got attempt at copying Thomas Luft's Ivy generator , but still has some minor problems such as collision detection which the SketchUp API may not not contain. 😞
                                    my plugins
                                    tomot
                                    • T
                                      the.pjt
                                      is it possible to change the SKP files located in the Plugins\LiveIvy\Textures and replace its JPEG textures with PNGs ?
                                      so this plugin could results transparent textured leafs ...
                                      because now we should change textures every time
                                      can I do it ? ...or ... will the plugin make bad results ?? longer time ??
                                      thanks ... 😉
                                      • rodrigonotorR
                                        rodrigonotor
                                        Hi Pj, is not problem change the files, only make shure you put the same names for components.
                                        http://img215.imageshack.us/img215/3357/20052011070953pm.jpg
                                        http://img803.imageshack.us/img803/6654/20052011075532pm.jpg
                                        You can use the *.png file inside the leaf component.
                                        Here are the leaf component I use.
                                        ivy_leaf_enavas.rar
                                        • Sketchando.net • www.arqcad.net •
                                        • KrisidiousK
                                          Krisidious
                                          thanks ... 😉
                                          yes you can... that's what I did to allow transparency.
                                          By: Kristoff Rand
                                          • T
                                            the.pjt
                                            thanks ..
                                            so I have another question .. why Pierreden (author) have used JPG textures in Plugins\LiveIvy\Textures ? he could use PNGs ... couldn't he ? ...
                                            I'm going to change components in the directory (Plugins\LiveIvy\Textures) .. 😄
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 36
                                            • 37
                                            • 20 / 37
