    Shortcut to ungroup
    14 Posts 7 Posters 5.0k Views 7 Watching
    • N Offline
      NickGenerator
      Hi.
      I am using CTRL + G to group, but wasn't able to create a shortcut like SHIFT + CTRL + G to ungroup. Is it my fault or not possible?
        It's called 'Explode'.
        Select a Group.
        Open Windows > Preferences > Shortcuts.
        Filter for 'Explode'.
        Select the command and set up your preferred shortcut...
        OK/Save/Close
        Some shortcut commands are context-sensitive - for example if you want to shortcut face-reversal you will need a Face to have been selected BEFORE opening the dialog for you to be able to see 'Reverse' as one of the available commands...
        • massimoM Offline
          massimo Moderator
          What do you mean with "ungroup"? Explode? You can customize your shortcuts going to window-->preferences-->shortcuts. Remember to select a group first.
          • N Offline
            NickGenerator
            Not in my version. Sorry.
            Thanks a lot. That is news to me.
              Marcus
              When you select a Group the relevant context-menu IS 'Explode' on a PC - I'd be surprised if the MAC version were different, because you can select a combination of Groups AND Components and 'Explode' them all at once... what'd your context-menu say then ?
              You may well have some third-party tool loading that adds 'Ungroup'... but it's not a native tool, and God knows what it does...
              • N Offline
                NickGenerator
                @tig said:
                When you select a Group the relevant context-menu IS 'Explode' on a PC ... what'd your context-menu say then ?
                No, my version is just German.
                  Okay, what do you have here (in the context or "right click" menu)?
                  or here (under the edit menu)?
                  For both, you need to pre-select the group first - and also you need to pre-select it in order for the available shortcut to appear in the Preferences list.
                    lecra
                    People,
                    I noticed the same!! In the shortcut menu 'Explode' is only available if you have already grouped an object! Maybe a bug.
                    Draw some objects and group through the CTRL+G and then go to the shortcut editor and search for Edit/Item/Explode. Assign the new shortcut. I used U for ungroup. It is assigned to another command but I took it anyway.
                    Greetings to Germany
                    KR; Lecra
                    I'm new to SU but so thirstily to learn all the stuff. Help me fighting against my thirst
                    • massimoM Offline
                      massimo Moderator
                      @lecra said:
                      People,
                        @lecra said:
                        People,
                        No it isn't a bug. If you haven't selected a group or component, there's nothing to explode so it doesn't show in the context menu or the Shortcuts editor. It's supposed to work that way. There is a large number of other items that only show in the Shortcuts editor when something is selected on which that shortcut can be performed.
                        • cottyC Offline
                          cotty
                          @lecra said:
                          People,
                          In german it is called "In Einzelteile auflösen" and the possible bug is not in the contextmenu but in the preferences:
                          • If no group or component is selected, the entry is not there (see picture)
                          • If a group is selected, you can find the entry in the shortcut list
                          my SketchUp gallery
                            Cotty
                            You misunderstand - 'Explode' [or whatever it's called in your locale] will only appear in the Preferences > Shortcuts filtered list IF an appropriate object is selected in the SKP.
                            You can 'Explode' Groups/Components [same 'Explode'] BUT note there are other 'Explode' tools too - for a selected 'Image', and a selected 'Curve' - these are both different 'Explodes'. So if you want to shortcut to Explode a Curve select an arc and filter for 'Explode' and then shortcut to that [using a different key-combo]. Then one shortcut key-combo will Explode Groups/Components, the other key-combo will Explode Curves etc.
                            There are many commands that only appear in [context-]menus IF certain criteria are met - in turn these commands will not show on the list for shortcutting if they are not in the menu - so if you don't select a Group you don't see Explode in the list, if you don't select a Face you don't see Reverse in the list, if you don't select one Section-Plane you won't see SectionCutFace in the list etc etc...
                            It's quite logical ?
                              @cotty said:
                              @lecra said:
                              People,
                              The short of it is, there is no bug.
                              • cottyC Offline
                                cotty
                                Yes, I knew that, but I thought that in the general preferences there should be all possible entries independent of the model or the selection. So the general preferences are not as general as I expected... good to know 😉
                                my SketchUp gallery
