    [Plugin] Selection Memory
    39 Posts 17 Posters 24.6k Views 17 Watching
      @massimo said:
      I have SU 7.1 and can confirm that here not works with left-->right selection while it works with right-->left selection.
      Just tried it myself - I see no problems with Left to Right as oppose to Right to Left...
      Are you able to make a short video of what you see?
        Ah - it's something to do with how it retrieves back the previous selections. What you are experiencing is probably that it retrieves an earlier selection set. Might be empty.
        There is five slots of selection sets - always - even when you start a fresh model. Keep cycle through and it will come back. I'll have a look at it. But this plugin isn't on top of my priority list.
        • massimoM Offline
          massimo Moderator
          Ehm...I'm afraid not. Anyway this is what i do:
          • Draw a simple rectangle for example;
          • Select all (edges and face) with a left-->right window.
          • click anywhere to deselect;
          • run "cycle previous selection" and nothing happens.
            EDIT it's not working with right-->left selection either.
          • massimoM Offline
            massimo Moderator
            Ah! That's maybe the reason. Thought that with a fresh model the "memory" would have been deleted.
              Well, it does - but there's a pre-reserved set of slots regardless. Which then are "filled" as you use it.
              The plugin was written very quickly so unfortunately it has this behaviour which is illogical from a user point of view. πŸ˜•
              • massimoM Offline
                massimo Moderator
                Ok, no problem. πŸ˜„
                • andybotA Offline
                  andybot
                  Thanks Thomthom πŸ‘ πŸ‘
                  works as expected for me!
                    Version 1.0.1
                    Did a quick tweak to it. I believe it should retrieve the previous selection more predictably now.
                    • massimoM Offline
                      massimo Moderator
                      Now it seems to work just fine. πŸ‘ πŸ‘
                      • john2J Offline
                        john2
                        yeeeeeeeeeaaa
                        http://vitalogics.net/wp-content/uploads/2011/02/pic_excited_man.jpg
                        Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                          Ben Ritter
                          Sweet! Thank you so much, again.
                          • john2J Offline
                            john2
                            thanks a llllot thomthom..great plugin. saves a lot of time during accidents πŸ˜‰
                            http://i.imgur.com/aTTyR.jpg
                            • EarthMoverE Offline
                              EarthMover
                              Thanks bro for this great tool. I've always enjoyed having the selection in the undo stack with 3ds Max, now it's possible in sketchup as well! You deserve a chocolate fudge covered peanut butter chocolate chip cookie with oreo filling!
                              Content Creator at Skapeup
                                http://www.talknerdytomelover.com/storage/drooling_homer.gif?__SQUARESPACE_CACHEVERSION=1286480521201
                                • StinkieS Offline
                                  Stinkie
                                  Thanks, Thom. Most useful. πŸ‘
                                  • halroachH Offline
                                    halroach
                                    Thanks Thom!
                                    You could add it to your already marvelous set of tools in 'selection toys'.
                                    That's it!
                                    I'm all out of keys on my keyboard for another shortcut for such a good tool. either I scrap some short cut I barely use, or I'll bump it up to them less used Shift+ and Ctrl+ shortcuts πŸ˜‰
                                    FlexTools - Super Quick Windows, Doors, Slats...
                                    • V Offline
                                      victor hugo
                                      Buenos Dias.
                                      If I want to revert the "selection_stack size" to default which number would be; or by removing the plugin it will go back to default?
                                      Thanks.
                                        If you reinstall then it would revert back, yes.
                                        • gonashviliG Offline
                                          gonashvili
                                          This be them bombz.
                                          Big up yourself, sir, etc.... πŸ˜„
                                            AtefZ
                                            Hello
                                            Please how can I modify this constant: SELECTION_STACK_SIZE ? 😎
                                            Thanks πŸ€“
                                            • 2 / 2
