    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 476.3k Views 108 Watching
    • kenK Offline
      ken
      Sir
      I have a single icon that will show a building tool toolbar. I also have a building tool toolbar. These appear to be loaded by differ plugins. Does the program really need to means of showing the toolbar or have I installed the program incorrectly?
      Another question, you give a PDF document to showing how to modify the CVS files showing the profiles. However, I haven't been able to get the program to read the new profiles. Also, there doesn't appear to be an icon for the circle shapes, L shapes. I must be missing something.
      Thanks for you help and this plugin.
      Ken
        davecoopstl
        Thanks for bringing back the regular toolbar!
        However, the new version still has the same Unzipping problem. If you Unzip the files into the Plugins folder, it puts them in a "bst_zip052" sub-folder in the Plugins folder, and SketchUp cannot find the files. You need to create the .zip file so that they get Unzipped directly into the root Plugins folder, not a "bst_zip052" sub-folder.
        Thanks again!
          tak2hata
          Hi,Ken.
          Your install is correctly.
          If you not need toolbar,please show off.or delete "bst_toolbar.rb" from plugins folder.
          Hi,davecoopstl.
          I will remove folder in zipped file.
          Thanks.
          by TAK2HATA
            tak2hata
            HI,
            I update this to v0.5.3 with small bug fix.
            Hi,Ken...
            I add new youtube video about Profile list csv.
            http://youtu.be/oSVrbJMSSB0
            [flash=420,315:biq7w64j]http://www.youtube.com/v/oSVrbJMSSB0[/flash:biq7w64j]
            I am not good for english.so I can not expression customize profile list csv well.
            Please watch video.
            Thanks.
            by TAK2HATA
              d_e_x
              Hi Tak,
              I am excited to see that I am not alone in developing a BIM plugin πŸ˜„ Great work!
              My plugin (SketchUpBIM) is focused on Building Modeling, and follows a similar methodology as the commercial BIM softwares. I would be very happy if you check it out and provide your feedback and comments: http://forums.sketchucation.com/viewtopic.php?f=323&t=41840
              other BIM gurus on this forum, please feel free to provide feedback as well!
              dex
                tak2hata
                @d_e_x said:
                Hi Tak,
                dex
                Hi,d_e_x.
                Your project is very exciting to me ,too.
                I wish BIM being free and open.
                Sketchup is one of best application for that goal.
                I will check your project out.
                Thanks.
                by TAK2HATA
                • guanjinG Offline
                  guanjin
                  Hello: I edited the language file, change the language in the environment, selection, or display the original language!
                  Please enlighten me
                    tak2hata
                    I update to v0.5.4 in Dec 18 , 2011.
                    Small Improve:Multi wall work on sketchup v6 ,too.
                    Hi,XIAOLONG.
                    Thanks to your reply.
                    I do not consider language setting enough.
                    I will improve lang setting after updating this plugin to v1.0.
                    Please wait small long time.
                    by TAK2HATA
                    • guanjinG Offline
                      guanjin
                      Hi,XIAOLONG.
                      Most of the language can not change, 1.0 a long time oh
                      • F Offline
                        franki3
                        Excellent plug in will save me tons of time
                          boilingsnow
                          Hello,tak2hata. Thanks for your tool.
                          I failed to creat new mutiwall. I don't understand your sentence "the rule of the mutiwall is do not exist tha wall that hugo each other"...
                          I tried to copy the planking of your existing Multi-wall and want to make it a new one, but by drawing it doesn't connect correctly.
                          Can you tell me what I am doing wrong?
                            tak2hata
                            Hi,boilingsnow.
                            "hugo" is like as "tag".
                            This" multi wall tool" judges by "hugo" to combine the wall each other.
                            walls-attributes-in-Mwall
                            judge_combining_each_other
                            If the walls have same "hugo",tool can not judge.
                            So walls in multi wall must have different "hugo" each other.
                            Thanks.
                            queryattributes
                            walltool
                            by TAK2HATA
                              boilingsnow
                              Hi,boilingsnow.
                              [attachment=1:czfqhlvd]<!-- ia1 -->walls-attributes-in-Mwall.jpg<!-- ia1 -->[/attachment:czfqhlvd]
                              [attachment=0:czfqhlvd]<!-- ia0 -->judge_combining_each_other.jpg<!-- ia0 -->[/attachment:czfqhlvd]
                              Thanks.
                              Thank you for your explanation.
                              But how can I define the "hugo" of an entity?
                              Is "Query Attribute" another plugin which I have to install to check and change "hugo" of entities?
                                tak2hata
                                Hi,boilingsnow.
                                "Query Attribute" is display the attributes of entity.
                                It can be download in my homepage.
                                But it can not change attributes.
                                I will create editor for attribute of building structure tool.
                                But this is too early alpha ,yet.
                                Now,you open "default_pflist.csv" and add profiles with attaching attribute".
                                or Use "Add New profile" in menu of building structure tool.
                                And draw wall by using wall tool of building structure tool.
                                Thanks.
                                by TAK2HATA
                                  tewakul
                                  godd
                                  • Y Offline
                                    ygcl
                                    it looks very good
                                    • V Offline
                                      vilcoyote57
                                      Hi, great plugin.. but I can't understand how EXCHANGE tool works. Can you help me? thanks
                                        tak2hata
                                        Hi,vilcoyote57.
                                        "EXCHANGE" is not work well yet.
                                        How to use.
                                        1.Select the group / component that is solid.
                                        2.Click "EXCHANGE".
                                        3.Select "Type" in dialog.
                                        It is all.
                                        The longest edge of the group/ component is used to length about element of building structure.
                                        Thanks.
                                        by TAK2HATA
                                          SUFractal
                                          @millzye71 said:
                                          Very good plug in indeed!!! Could this be modified so that you could use these steel sections as rafters, and be able to rotate them at a degree up or down on the axis that you have drawn. This would be great when modelling steel frames.
                                          Cheers
                                          Millzye
                                          Couldn't you draw a 'wire frame' (for lack of a better way of saying it) then use the desired steel section tool to 'trace' along the wireframe line?
                                            SUFractal
                                            tak2hata:
                                            I've been working with your wonderful BuildingStuctureTools plugin recently. Are you planning on creating any additional tools (and icons) for your plugin?
                                            Although it appears relatively easy to add additional profiles to the existing tools you've created, I think it would be even more convenient if there were separate tools for things such as:
                                            "flanged" steel columns the (H-shapes as you've named them)
                                            round steel columns
                                            steel angles (L-shapes)
                                            steel channels ([-shape)
                                            C-shape steel (these appear to be steel studs)
                                            T-shaped steel
                                            flat bars
                                            By adding more tools, the list for each tool would not be quite so long in the window menu that pops up. For example, instead of just one "steel column" tool, having one (with its icon) for each shape "type" (H, round, square) would be easier/faster to find the structural member needed.
                                            Thanks,
                                            SUFractal
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
