    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 564.9k Views 108 Watching
    • C
      cadmunkey
      Just found this, I asked about a steel frame plugin but no-one suggested this. I detail building structures mainly so this will be very useful thanks!
      • T
        tak2hata
        Hi,cadmunkey.
        You are welcome. πŸ˜‰
        My goal is detail building modeling,too.
        Thanks for using this.
        by TAK2HATA
          davecoopstl
          I think there's a problem with your "bst_zip051.zip" file.
          When I Extract the .zip file in Windows into my Plugins folder for SketchUp, it places a "bst_zip" folder in the Plugins folder. The "building_structure_tool" folder and the"building_structure_tool.rb" needed to run the script are inside of the "bst_zip" folder...they need to sit directly in the Plugins folder to work.
          You have one too many sub-folders in your .zip file. It just doesn't extract correctly.
            davecoopstl
            One other thing:
            Is there any way to get the Toolbar back, WITHOUT using the Web Dialogue? I'd much rather have the toolbar up in my set of toolbars, than having to click to call up the web dialogue every time I want to use it. Just seems more cumbersome.
            Just a thought.
            • T
              tak2hata
              @davecoopstl said:
              One other thing:
              Just a thought.
              Hi,davecoopstl.
              I correct the toolbar as before.
              Thanks.
              by TAK2HATA
              • kenK
                ken
                Sir
                I have a single icon that will show a building tool toolbar. I also have a building tool toolbar. These appear to be loaded by differ plugins. Does the program really need to means of showing the toolbar or have I installed the program incorrectly?
                Another question, you give a PDF document to showing how to modify the CVS files showing the profiles. However, I haven't been able to get the program to read the new profiles. Also, there doesn't appear to be an icon for the circle shapes, L shapes. I must be missing something.
                Thanks for you help and this plugin.
                Ken
                  davecoopstl
                  Thanks for bringing back the regular toolbar!
                  However, the new version still has the same Unzipping problem. If you Unzip the files into the Plugins folder, it puts them in a "bst_zip052" sub-folder in the Plugins folder, and SketchUp cannot find the files. You need to create the .zip file so that they get Unzipped directly into the root Plugins folder, not a "bst_zip052" sub-folder.
                  Thanks again!
                  • T
                    tak2hata
                    Hi,Ken.
                    Your install is correctly.
                    If you not need toolbar,please show off.or delete "bst_toolbar.rb" from plugins folder.
                    Hi,davecoopstl.
                    I will remove folder in zipped file.
                    Thanks.
                    by TAK2HATA
                    • T
                      tak2hata
                      HI,
                      I update this to v0.5.3 with small bug fix.
                      Hi,Ken...
                      I add new youtube video about Profile list csv.
                      http://youtu.be/oSVrbJMSSB0
                      [flash=420,315:biq7w64j]http://www.youtube.com/v/oSVrbJMSSB0[/flash:biq7w64j]
                      I am not good for english.so I can not expression customize profile list csv well.
                      Please watch video.
                      Thanks.
                      by TAK2HATA
                        d_e_x
                        Hi Tak,
                        I am excited to see that I am not alone in developing a BIM plugin πŸ˜„ Great work!
                        My plugin (SketchUpBIM) is focused on Building Modeling, and follows a similar methodology as the commercial BIM softwares. I would be very happy if you check it out and provide your feedback and comments: http://forums.sketchucation.com/viewtopic.php?f=323&t=41840
                        other BIM gurus on this forum, please feel free to provide feedback as well!
                        dex
                        • T
                          tak2hata
                          @d_e_x said:
                          Hi Tak,
                          dex
                          Hi,d_e_x.
                          Your project is very exciting to me ,too.
                          I wish BIM being free and open.
                          Sketchup is one of best application for that goal.
                          I will check your project out.
                          Thanks.
                          by TAK2HATA
                          • guanjinG
                            guanjin
                            Hello: I edited the language file, change the language in the environment, selection, or display the original language!
                            Please enlighten me
                            • T
                              tak2hata
                              I update to v0.5.4 in Dec 18 , 2011.
                              Small Improve:Multi wall work on sketchup v6 ,too.
                              Hi,XIAOLONG.
                              Thanks to your reply.
                              I do not consider language setting enough.
                              I will improve lang setting after updating this plugin to v1.0.
                              Please wait small long time.
                              by TAK2HATA
                              • guanjinG
                                guanjin
                                Hi,XIAOLONG.
                                Most of the language can not change, 1.0 a long time oh
                                • F
                                  franki3
                                  Excellent plug in will save me tons of time
                                  • B
                                    boilingsnow
                                    Hello,tak2hata. Thanks for your tool.
                                    I failed to creat new mutiwall. I don't understand your sentence "the rule of the mutiwall is do not exist tha wall that hugo each other"...
                                    I tried to copy the planking of your existing Multi-wall and want to make it a new one, but by drawing it doesn't connect correctly.
                                    Can you tell me what I am doing wrong?
                                    • T
                                      tak2hata
                                      Hi,boilingsnow.
                                      "hugo" is like as "tag".
                                      This" multi wall tool" judges by "hugo" to combine the wall each other.
                                      walls-attributes-in-Mwall
                                      judge_combining_each_other
                                      If the walls have same "hugo",tool can not judge.
                                      So walls in multi wall must have different "hugo" each other.
                                      Thanks.
                                      queryattributes
                                      walltool
                                      by TAK2HATA
                                      • B
                                        boilingsnow
                                        Hi,boilingsnow.
                                        [attachment=1:czfqhlvd]<!-- ia1 -->walls-attributes-in-Mwall.jpg<!-- ia1 -->[/attachment:czfqhlvd]
                                        [attachment=0:czfqhlvd]<!-- ia0 -->judge_combining_each_other.jpg<!-- ia0 -->[/attachment:czfqhlvd]
                                        Thanks.
                                        Thank you for your explanation.
                                        But how can I define the "hugo" of an entity?
                                        Is "Query Attribute" another plugin which I have to install to check and change "hugo" of entities?
                                        • T
                                          tak2hata
                                          Hi,boilingsnow.
                                          "Query Attribute" is display the attributes of entity.
                                          It can be download in my homepage.
                                          But it can not change attributes.
                                          I will create editor for attribute of building structure tool.
                                          But this is too early alpha ,yet.
                                          Now,you open "default_pflist.csv" and add profiles with attaching attribute".
                                          or Use "Add New profile" in menu of building structure tool.
                                          And draw wall by using wall tool of building structure tool.
                                          Thanks.
                                          by TAK2HATA
                                          • T
                                            tewakul
                                            godd
                                            • 16
                                            • 17
                                            • 5 / 17
