    Video card error, or sketchup error?
    22 Posts 11 Posters 7.7k Views 11 Watching
    • W Offline
      wheeljack
      I think I'm having similar issues. Disabling hardware acceleration has helped but yeah now it's slow.
        That indicate a graphic card issue. Have you tried updating your drivers?
        • W Offline
          wheeljack
          I'm gonna try that and get back to ya. thanks.
          • W Offline
            wheeljack
            ok the drivers and everything else is up to date on my computer. I tried purging unused and it didn't help. I also tried removing all the plugin and that didn't help either. the file size is only about 2.5 MB. and this only started about a week ago. my laptop is a month old.
            you guys got any other suggestions? at the moment I'm working on my stuff with the fast feedback unchecked.
              What have you got for a graphics card in your computer?
              • W Offline
                wheeljack
                uploaded a capture of it. Thanks for looking at this guys. This is so nice.
                  Ah, that's a built-in graphic card from Intel. Those often produce glitches. What is the exact make? Check what OpenGL capabilities it have. Good probability that it doesn't meet the requirement of SketchUp.
                    Well, that doesn't show anything about OpenGL being supported. That doesn't mean it isn't but that doesn't give that information. You need to check into that, though. Read the hardware recommendations here.
                    • irwanwrI Offline
                      irwanwr
                      an on-board graphic adapter mostly wont come with good performance for 3d apps.
                      • charly2008C Offline
                        charly2008
                        Hi Ninos,
                        you should identify your Graphic Chip , See picture below.
                        On the Intel side you can select the type and find out the OpenGL capabilities and settings.
                        301 Moved Permanently
                        (www.intel.com)
                        • W Offline
                          wheeljack
                          thanks again guys.
                          well it seems like I have all the requirements that are recommended here http://support.google.com/sketchup/bin/answer.py?hl=en&answer=36208
                          my graphic card is an Intel HD Graphics and it claims to support OpenGL 2.1 --> http://www.intel.com/support/graphics/sb/cs-031105.htm
                          but I did see this on sketchup's requirement page
                          "SketchUp's performance relies heavily the graphics card driver and it's ability to support OpenGL 1.5 or higher. Historically, people have seen problems with Intel based cards with SketchUp. We don't recommend using these graphics cards with SketchUp at this time."
                          so does this mean that the Intel HD graphics card does support OpenGL but that it's just not compatible with sketchup's requirements? 😲
                          I'm gonna go have a stiff drink
                          • AnssiA Offline
                            Anssi
                            OpenGL 2.1 is what Intel says its card supports, but it is likely that in reality only a subset of the commands are supported, maybe those required by some 3D games.
                            Anssi
                              sonder
                              I am surprised the Nvidia is giving trouble. In the past I have only had troubles with ATI cards. If it helps I am currently using the Nvidia GeForce GTX 550 Ti with no issues what so ever running Windows 7/64.
