    Video card error, or sketchup error?
    22 Posts 11 Posters 8.3k Views 11 Watching
    • P
      penumbradesign
      I am having a similar issue with my ATI radeon mobility video card. as soon as my work computer was upgraded to windows 7 i started having the same issues. In addition, there are other video issues with textures getting distorted as i zoom in and out of a group. very strange.
      To compound the problem, lenovo (my laptop's manufacturer) seems to be slow on updating the drivers for this video card on their website. Going to AMD (now the owners of ATI) yields no results either. I wonder if reverting the drivers to an earlier working version would work? any thoughts?
        Milo
        I have exactly the same problem with my GTX 570. I installed the latest update to the NVIDIA driver .... Effectively disabling hardware acceleration it works without bug but skectchup becomes too slow!
        Have you found a solution?
        FaceBook
        • W
          wheeljack
          I think I'm having similar issues. Disabling hardware acceleration has helped but yeah now it's slow.
            That indicate a graphic card issue. Have you tried updating your drivers?
            • W
              wheeljack
              I'm gonna try that and get back to ya. thanks.
              • W
                wheeljack
                ok the drivers and everything else is up to date on my computer. I tried purging unused and it didn't help. I also tried removing all the plugin and that didn't help either. the file size is only about 2.5 MB. and this only started about a week ago. my laptop is a month old.
                you guys got any other suggestions? at the moment I'm working on my stuff with the fast feedback unchecked.
                  What have you got for a graphics card in your computer?
                  • W
                    wheeljack
                    uploaded a capture of it. Thanks for looking at this guys. This is so nice.
                      Ah, that's a built-in graphic card from Intel. Those often produce glitches. What is the exact make? Check what OpenGL capabilities it have. Good probability that it doesn't meet the requirement of SketchUp.
                        Well, that doesn't show anything about OpenGL being supported. That doesn't mean it isn't but that doesn't give that information. You need to check into that, though. Read the hardware recommendations here.
                        • irwanwrI
                          irwanwr
                          an on-board graphic adapter mostly wont come with good performance for 3d apps.
                          • charly2008C
                            charly2008
                            Hi Ninos,
                            you should identify your Graphic Chip , See picture below.
                            On the Intel side you can select the type and find out the OpenGL capabilities and settings.
                            Invalid URL
                            (www.intel.com)
                            • W
                              wheeljack
                              thanks again guys.
                              well it seems like I have all the requirements that are recommended here http://support.google.com/sketchup/bin/answer.py?hl=en&answer=36208
                              my graphic card is an Intel HD Graphics and it claims to support OpenGL 2.1 --> http://www.intel.com/support/graphics/sb/cs-031105.htm
                              but I did see this on sketchup's requirement page
                              "SketchUp's performance relies heavily the graphics card driver and it's ability to support OpenGL 1.5 or higher. Historically, people have seen problems with Intel based cards with SketchUp. We don't recommend using these graphics cards with SketchUp at this time."
                              so does this mean that the Intel HD graphics card does support OpenGL but that it's just not compatible with sketchup's requirements? 😲
                              I'm gonna go have a stiff drink
                              • AnssiA
                                Anssi
                                OpenGL 2.1 is what Intel says its card supports, but it is likely that in reality only a subset of the commands are supported, maybe those required by some 3D games.
                                Anssi
                                  sonder
                                  I am surprised the Nvidia is giving trouble. In the past I have only had troubles with ATI cards. If it helps I am currently using the Nvidia GeForce GTX 550 Ti with no issues what so ever running Windows 7/64.
