    $500 for inference engine plugin
    33 Posts 12 Posters 1.7k Views 12 Watching
    • hellnbakH Offline
      hellnbak
      If one more person tells me that the inference engine is my "friend" I will scream! Yes, I know it is absolutely indispensible for using SU, without it SU would be completely unusable, and on and on. Yes, I know all that.
      BUT, there are times when it is more of a hindrance than a help. I just want the ability, in those circumstances, to temporarily disable it, do what I need to do, and then enable it again. Just temporarily.
      I can only speak for myself, but I know it would make my modeling experience a lot more enjoyable and productive, and a lot less frustrating.
      • andybotA Offline
        andybot
        Well, actually, there is a good point there - there is a difference between inferencing and snapping. I was thinking it would be nice to disable snapping. The issue with inferencing is that there would need to be a way to lock movement to a plane or, yes, you will be lost in 3D space...
          I'd also like to disable snapping on occasions - some times it's just impractical and making it avoid snapping to the unwanted point can be very disruptive to the workflow.
          However, there is no way one can hook into the inference engine from the SketchUp Ruby API. This is one of the things that would have been done if it could have been one. Google are the only ones that can address this.
          Mind you, if you want to offer that bounty for another issue... πŸ˜„ πŸ˜’
            Which tool do you want to disable inferencing for?
              Aerilius
              One could create new tools with optional inferencing ( inputpoint.pick <-> view.pickray).
              I don't think that it's possible to modify/hack/overwrite the built-in tools because most of them are written in C.
              • hellnbakH Offline
                hellnbak
                Ok, I surrender 😒
                I was just having a spectacularly bad day. Started a new project this morning, and, while I want it to be accurate, this one that has almost no reference photos. Should probably just abandon it but can't. I was experiencing an unusually large number infernal engine battles, like those instances when you are trying to draw a line, and it's just slightly off axis, and it won't let you unless you zoom in so close that you can no longer reference anything else in the model to figure out what you're doing 😠 😠 Tired of screaming at my computer. At one point I think I was screaming in tongues.
                Well, if I can shovel my way to the barn thru fifteen inches of this wonderful Michigan sunshine gonna head to Holland for some much-needed coffee.
                BTW, the bounty still stands πŸ˜‰
                  @hellnbak said:
                  BTW, the bounty still stands[/size] πŸ˜‰
                  I'm gonna hold you to that when Google implements Sketchup.inference_snapping = false πŸ˜‰ πŸ˜† $$$
                  • irwanwrI Offline
                    irwanwr
                    • Jean LemireJ Offline
                      Jean Lemire
                      Hi folks.
                      With SU, it is not the inferences that are proposed that are the problem, its more the quantity of those that can be a nuisance sometimes when trying to get a snap from a specific item in a very detailed sector of a model.
                      Although there are tricks and workaround to minimize the number of snaps proposed by the inference engine, as I pointed out in my previous post, I also feel that sometimes I loose a bit in efficiency because of these.
                      A few years back, well ... many years ago, after using SU for a couple of years, I proposed, on the now defunct @last Software forum, to add a system of inference filter, like the one that I was using in PowerDraw on my Mac in 1990. PowerDraw later became PowerCadd. I don't use it anymore since SU fills my needs very well but the system was quite simple and efficient.
                      The idea was to tell the program what kind of inference you want. This was acomplished by pressing some keyborad keys. The list was:
                      c --> for circle centers and possibly line center (midpointin SU, if my memory serves me well).
                      x --> for intersections
                      l --> for line (on edge in SU)
                      etc.
                      There were only a limited number of these. For example, there was one for a vertex (endpointin SU) or for which I don't remember the key.
                      Using such a key would limit the snaps to a specific type of item. Press x, for example, will yield snaps only from intersections. Press nothing and the engine works as usual, snapping to everything.
                      The only problem would be to let SU knows that you are not using a shortcut but are wanting to filter the inferences. Maybe some modifier key or a trigger key or even a serie of icons in the status bar would do the job. Pressing ESC would get you out of this filtering system, or pressing the icon again. Of course, the Status Bar should show the status of this filtering system. Maybe pressing a few icons would allow you to snaps to endpoints and midpoints, for example, or any combination you want. One icon could turn all filters off in one click.
                      Just ideas.
                      • andybotA Offline
                        andybot
                        Jean,
                        There are two different things discussed here. One is the snapping to geometry (which you describe in your post) and the other is inferencing (which hellnbak describes in another post about trying to draw a line slightly off-axis)
                        My thoughts:
                        1. turning on/off and filtering snapping would be great.
                        2. having a way (like Microstation or solidworks, etc) to draw in a plane without x-y inferencing. No inferencing at all would mean no control in the z direction... basically lost in 3D space.
                        • N Offline
                          numerobis
                          +1 for a simple snap toggle like in acad
                          and i still don't get it why this is so hard to implement...
                          but for me the even more important and useful "feature" (lol interesting view... function deactivation as a feature) would be the ability to disable the axes snap (ortho) only!
                            My impression is not that it's difficult for Google to implement - it's more that they want to keep the UI simple...
                            • AnssiA Offline
                              Anssi
                              What I would like to see would be a new pane to the Preferences dialog, with checkboxes for the various inferencing/snapping options. The first I would like to toggle would be the various "From outside active..." options. Of course, to be able to assign shortcuts to the options would be cool too.
                              Anssi
                              • hellnbakH Offline
                                hellnbak
                                I'm willing to pay $500 for my dream plugin -- how much are you guys willing to ante up for yours? πŸ˜†
                                • jeff hammondJ Offline
                                  @hellnbak said:
                                  like those instances when you are trying to draw a line, and it's just slightly off axis, and it won't ..
                                  Maybe you should try using Tools_on_surface's freehand tool..
                                  http://forums.sketchucation.com/viewtopic.php?t=11212
                                  and be sure to send Fredo the 500 spot πŸ˜‰
                                  • andybotA Offline
                                    andybot
                                    yes, tools on surface is great, but doesn't address the snapping issue, nor trying to draw a line in space. I was thinking construction plane would be helpful, but again you run into inferencing for something just off-axis.
                                    @hellnbak: One thing I was thinking was - couldn't you just change your axis temporarily to align, or is this a whole series of non-orthogonal lines?
                                      Work Plane v2.3 by TIG?
                                      • andybotA Offline
                                        andybot
                                        right! sorry, was just going off the top of my head... guess where that was... πŸ˜•
                                          TGI3D has a Move tool that ignores inferencing. You can also lock the movement perpendicular to your view then orbit to another view and it will remain locked to the locked view.
                                          It only works on verts though. Adding groups and components to that would be nice.
                                            I was thinking of maybe making the Gizmo I'm working on for Bezier Surface and Vertex Tools into a standalone plugin. One could then define custom axis for the gizmo - pick from model entities (lines, planes etc) So for basic operations like move, rotate and scale it'd be something that would work without inference.
