    Using DropBox and symbolic links with SketchUp.
    46 Posts 19 Posters 14.8k Views 19 Watching
    • jeff hammondJ
      fwiw, apple's one button mouse hasn't been sold since 2005 or so.. the version after that, while it looked like it had only one button (well, i guess it looks like it has no buttons), actually had 4 pressure sensitive areas which could be used for right-clicking.. in 2009(?), they updated again to the magic mouse which again is only one button but it's much smarter than the previous version.. it now depends on where you click, how many fingers you click with, which direction you move your finger(s) in, etc as to what action it preforms.. it's basically a mashup between a mouse and a trackpad.
      regardless, i've never used an apple mouse.. always logitech.. but even then, osx requires no special drivers for (most)3rd party mice. plug and play..
      • Chris FullmerC
        My friend has one of the magic mice and I nearly bopped him over the head for being so stupid to have a single "mash here" one button mouse.
        The he showed me the truth.....wow, its pretty cool.
        I still can't live without a middle button to hold down for orbiting in SU. Not sure if you can make one of those magic mouse do that.
        • jeff hammondJ
          get a mouse with a thumb button(s)… thank me later 😉
          zoom while orbiting... your index finger is on the left button way more often.. faster/more flow-ey / more comfortable drawing..
          • Bob JamesB
            Bob James
            What model is that, Jeff?
            • Chris FullmerC
              My mouse at home is similar to that, I'll set it up that way and see how it goes. Thanks for the tip!
              • jeff hammondJ
                it's the MX Revolution.. I've had 3 of them 😮 (my daughter is 5 now so my latest model has lasted a couple of years.. in my experience, 2 year olds and mice do not coexist peacefully in the same house 😄 )
                apparently, logitech discontinued the revolution and replaced it with this model:
                http://www.logitech.com/en-us/mice-pointers/mice/devices/performance-mouse-mx
                it looks better than the older version.. they did away with the thumbwheel and added new little thumb button in a handy looking spot (4 thumb buttons total)
                for my laptops, i use the smaller MX.. the anywhere MX.. dunno, i like these things a lot because if i break/lose one, i'm not even going to shop around for anything else.. i just want an exact replacement..
                http://www.logitech.com/en-us/mice-pointers/mice/devices/9422
                  I don't see a version for lefties? 'Sculpted for right' is the blurb
                  • jeff hammondJ
                    like a Mac user... you'll get used to it 😉
                    weren't the teachers supposed to slap your hand every time you picked up a pencil with your left hand?
                      mk11
                      Jeff;
                      Thx a million for your MAC solution on doing this. One quick question: Where are the preference and keyboard shortcut files for SU located on a MAC?
                      Thx,
                      Marc
                      Marc Kleinmann
                      SU Pro 2015
                      Mac & Win
                      • irwanwrI
                        irwanwr
                        • jeff hammondJ
                          @mk11 said:
                          Jeff;
                          Thx,
                          Marc
                          the shortcuts are in your user library
                          ~/library/application support/google sketchup (x)/sketchup/
                          preferences are in
                          ~/library/preferences.. (a file named com.google.sketchuppro8 (or whatever))..
                          your user library is hidden by default on lion..
                          check this link for various ways to get there or unhide the folder
                          http://osxdaily.com/2011/07/22/access-user-library-folder-in-os-x-lion/
                          • shannakaeS
                            shannakae
                            Anyone know if using dropbox for the plugins will work for going from sketchup 8 to 13? Also, will it work on windows 8?
                            • mitcorbM
                              mitcorb
                              @Shanna:
                              Theoretically, you should have no problem with either of your questions.
                              I was just going to mention that many of the plugins have been updated to play nice with Sketchup 2013 and if you use the Sketchucation Plugin Store utility, it should be relatively simple to load your favorite items.
                              As for Windows 8, it is still windows core program, just a different interface.
                              • shannakaeS
                                shannakae
                                @mitcorb said:
                                @Shanna:
                                Thanks, looks like it would make the most sense to do a new install of the plgins to make sure i have the most up to date versions for 13. I am currently only using one computer for all of my work so I dont think i need to do the drop box thing for my plugins but if I do get a desktop do you think it iwll work the same with 13 as it did in the example for 8? I am guessing that the plugin store utility still puts the plugins into the plugin folder and if i move the bluging folder to dropbox and follow the intstructions for pointing sketchup to that folder I should be good. I was just wondeing if anyone had done this yet with 13? Also, i did not see my favorite Lib Fredo plugins in the plugin utility.... is that because his plugins require that because his require something else to be installed prior to using his plugins?
                                Thanks for your help!
                                • mitcorbM
                                  mitcorb
                                  As far as I know and as it appears in this link, Fredo6's Libfredo file is still separate. It is at version 5 according to the link.
                                  http://sketchucation.com/resources/pluginstore?pln=LibFredo6
                                  In case you need to look, click on the drop down "Resources" on the black bar above and click on PluginStore. You can search by the criteria at the top of that page. Just check Fredo6 in the drop list. Hope this helps.
                                  • halroachH
                                    halroach
                                    Hah,
                                    I've been using a similar mouse configuration for the past 4 years, I was in pain with my index and middle finger orbiting and panning too much. I second that the thumb solution is very very good! 👍 👍
                                    But in my case, I am still using the old style corded mouse with a ball! (I found it in my Dad's basement) and it's just super comfortable! And since it has a PS2 connector (remember those?) I found a USB to PS2 adapter. Works perfectly!
                                    My Logitech Mouseman + Yeahhhh!
                                    http://www.amazon.com/Logitech-M-CW47-Ergonomic-Connection-Compatible/dp/B004XJ4VP4/ref=pd_sim_sbs_e_1
                                    USB to PS2 Adapter:
                                    http://dx.com/p/usb-to-ps-2-cable-adapter-15cm-length-45594
                                    (maybe this topic should be split into "pride in cool hardware configurations" 😉
                                    FlexTools - Super Quick Windows, Doors, Slats...
                                    • maxhouserocksM
                                      maxhouserocks
                                      there are several threads on this issue now and i just realized i never posted my solution to using dropbox as a source for plugins to enable synchronization between multiple machines.
                                      I figured it out shortly after our conversation here and another post, so thanks again guys!
                                      THE COMMAND THAT WORKED FOR ME in cmd.exe
                                      mklink /J "C:\Users\rachristman\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\plugins" "D:\Dropbox\SketchUp Resources_SU Plugins\Plugins"
                                      I am not sure if /D did not work because i was linking from 😄 to d: but the /J did the trick. FULLY OPERATIONAL mklink, directory junction, is reading the plugins folder from my drop box as soon as i open Sketchup 2014.
                                      THE PROCESS:
                                      i had "successfully" created a symbolic link in cmd using mklink, however the tutorial thread i used had differing syntax. it took a while to determine that i had to use BOTH the existing path AND the new path in the mklink command as well as using "" around the paths. this was not mentioned in this post:
                                      http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=40866 (this post did not work for me)
                                      so i found some other references concerning the syntax:
                                      http://www.sevenforums.com/customization/149054-symbolic-folder-linking.html
                                      i will also share the info i came across while attempting this
                                      windows file junctions and symbolic links:
                                      http://devtidbits.com/2009/09/07/windows-file-junctions-symbolic-links-and-hard-links/
                                      links description:
                                      syncronize two windows folders in real time:
                                      http://superuser.com/questions/65524/how-do-i-synchronise-two-folders-in-real-time-in-windows-7
                                      Robert A. Christman
                                      http://rachristman.blogspot.com/
                                      • maxhouserocksM
                                        maxhouserocks
                                        FYI
                                        i just read that the quotes are needed if you have any spaces in the path.
                                        Robert A. Christman
                                        • 2 / 3
