    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
      The instructions also say that you need this additional plugin as well:
      http://www.smustard.com/script/ProgressBar
        tsunamile
        Thank's Gaieus...
          driven
          hi,
          First time I've needed to use this since V8 M2 and I'm getting this
          Error: #<NameError: undefined local variable or methodclf_shape_bender' for main:Object>
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:995`
          which is Toolbar related, I'm seeing it, but get the error on clicking.
          I haven't changed anything to do with it since it last worked, other then M2...
          osx 10.5.8
          EDIT: fixed it by changing to this Sketchup.active_model.select_tool Clf_shape_bender.new
          • Chris FullmerC Offline
            Weird, I swear this plugin has a mind of its own.
            • Rich O BrienR Online
              ๐Ÿ‘
                k_drive
                Thanks for the Shape Bender and the posts about the Progress Bar.
                I got the load error message; but, once I read and followed the instructions for the Progress Bar Plug-in, the Shape Bender worked.
                • mitcorbM Offline
                  mitcorb
                  Hi.
                  I have not used shape bender in a while, but due to another post on it I was experimenting. Probably somewhere in this thread it is mentioned, but I noticed this: I started with a group as instructed. When I decided to edit this group, only "Edit Component" was available on right click. Probably better that way, but I was not aware of this before.
                  Thanks Chris for a job well done.
                  • TIGT Online
                    ShapeBender's result is always a component, even if the original UNbent object starts its life as a group !
                      Yup, that was "by design" though I'm not sure it is the correct way to do it.
                      • irwanwrI Offline
                        irwanwr
                        i like it the way it is.
                        probably because i tend to make components more than groups ๐Ÿ˜›
                        • TIGT Online
                          It doesn't really matter... If the user wants a group he simply Selects the new Instance, Explodes it and immediately makes a Group of the still Selected Geometry... Sometimes we authors worry too much about how users will use tools - they always find new ways of using [or breaking] them and some always want them to work differently from the way they do - sometimes they have a good idea and I adopt it - sometimes its pants!
                          ๐Ÿค“
                            Atena
                            Hi Chris
                            I've the same problem as other people described. Cannot select line parallel to red axis. In my Ruby console I get Error: #TypeError: No implicit conversion from nil to integer>. Do you know what might be wrong?
                            • TIGT Online
                              Atena
                              Is your red-axis line completely separate from all other geometry, and your curve too? They can't 'touch' anything else...
                                Atena
                                Hi TIG
                                Yes it is comletely separate.
                                • TIGT Online
                                  Have you reset your axes ?
                                  Open the Console before starting the tool.
                                  Please post the whole Ruby Console message.
                                  A screenshot would help us too...
                                    Atena
                                    • gillesG Offline
                                      gilles
                                      you should post your model for test.
                                      • TIGT Online
                                        There's nothing wrong with the SKP, although placing the group that's to be bent on that side of the line/curve might give an unexpected bent result!
                                        The error message means you don't have the icon png files in the right subfolder, so the tool fails as it can't make the cursor needed at the pick-line stage...
                                        The tool's clf_shape_bender sub-folder inside the Plugins folder should look like thisCapture.PNGIt must already have the .rb file in it otherwise you wouldn't get as far as you do before the error appears [unless of course that too is in Plugins by mistake] !
                                        Find the missing .png files... Were they put directly into Plugins ?
                                        There should only be a script file called clf_shape_bender_loader.rb in Plugins.
                                        If so move them back: if not reinstall the toolset and ensure that this time you get everything in the right places!!
                                          Atena
                                          Untitled.pngThis is what I did:
                                          Downloaded the file from this website;
                                          It was a zip file so I extracted it on my desktop and I tried follow instructios on Sketchup Help how to installe ruby skript.
                                          This is what my plugin folder looks like:
                                            As TIG said, you installed it incorrectly. The png files should be in a folder as they were in the ZIP file.
                                            As the instructions for installing plugins from ZIP files clearly says, you must not change the file structure when you extract the files.
                                            Look at the screen shot TIG posted. All those files you see in his screen shot are supposed to be in a folder called clf_shape_bender and not loose in the Plugins folder.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 63
                                            • 64
                                            • 18 / 64
