    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.3m Views 329 Watching
      Maker - if the bent form will involve facets that are very small it will fail - scale up, bend, then scale down...
      • Chris FullmerC
        I agree with everything TIG and Dave said.
        @Maker - sounds like you just need to scale everything up by 100 times. SU does not like small faces
        @Fightingfish - That is generally an installation error. Just extract it to you plugins folder and it will install it with the right folder structure.
        @Esther - Yup, like they said. You should read up on how to install a SketchUp plugin. Its a matter of putting the files and folders into the plugins folder. Then SketchUp will load the plugin the next time you open SketchUp.
        Good luck folks. Was there a tutorial posted somewhere that included shapebender? 3 people in a day or 2 seems like a lot.
          deprezzar
          thanks!!!
          • L
            LannorMov
            Gracias Cris, le voy a sacar el jugo a este plug.
            • L
              LannorMov
              @chris fullmer said:
              woohoo, we're getting somewhere.
              You didn't install it right.
              Chris, Te cuento que a mi también me ha dado problemas con la selección de la línea, pero lo que hago es explotar el grupo o componente y le vuelvo a dar "crear grupo o componente" y luego me funciona muy bien.
              Chris, I tell you that I too have been problems with the selection of the line, but what I do is to exploit the group or component and it keeps coming back "create group or component" and then I work very well.(excuse my English)
                stillhouse
                Struggling to get shapebender to work on Sketch-up 8 for windows 7.
                I have downloaded both shape bender and progressbar and have put them in my sketchup plugins folder.
                I draw a line on the red axis
                I extrude a bar next to it and make it a group
                I make a curved line a little ways away
                I select the bar and go under plugins and select shape bender. It asks me to select the line on the red axis but I can't select it.
                Any help would be great. I love this plugin and I have used it in the past on my old mac, and would love to get this going on my new pc.
                Cheers,
                BW
                • Chris FullmerC
                  This sounds like an installation error. You should have clf_shape_bender_loader.rb in the plugins folder, and then clf_shape_bender.rb and all the shapebender icons should live in a subfolder called clf_shape_bender.
                  If that doesn't help, open the Ruby Console (in the windows menu). Then try to run shape bender and see what errors it gives.
                  Let me know how it goes,
                  • T
                    tsunamile
                    Hi Chris Fullmer.
                    I did same everything you said..., but i can use this plugin; when i run sketchup... a load error appear!
                    I use sketchup 8, win Xp sp2 32bit.
                    Help me fix it..
                    Thank's.
                    • GaieusG
                      The instructions also say that you need this additional plugin as well:
                      http://www.smustard.com/script/ProgressBar
                      • T
                        tsunamile
                        Thank's Gaieus...
                          driven
                          hi,
                          First time I've needed to use this since V8 M2 and I'm getting this
                          Error: #<NameError: undefined local variable or methodclf_shape_bender' for main:Object>
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/clf_shape_bender.rb:995`
                          which is Toolbar related, I'm seeing it, but get the error on clicking.
                          I haven't changed anything to do with it since it last worked, other then M2...
                          osx 10.5.8
                          EDIT: fixed it by changing to this Sketchup.active_model.select_tool Clf_shape_bender.new
                          • Chris FullmerC
                            Weird, I swear this plugin has a mind of its own.
                              • K
                                k_drive
                                Thanks for the Shape Bender and the posts about the Progress Bar.
                                I got the load error message; but, once I read and followed the instructions for the Progress Bar Plug-in, the Shape Bender worked.
                                • mitcorbM
                                  mitcorb
                                  Hi.
                                  I have not used shape bender in a while, but due to another post on it I was experimenting. Probably somewhere in this thread it is mentioned, but I noticed this: I started with a group as instructed. When I decided to edit this group, only "Edit Component" was available on right click. Probably better that way, but I was not aware of this before.
                                  Thanks Chris for a job well done.
                                    ShapeBender's result is always a component, even if the original UNbent object starts its life as a group !
                                    • Chris FullmerC
                                      Yup, that was "by design" though I'm not sure it is the correct way to do it.
                                      • irwanwrI
                                        irwanwr
                                        i like it the way it is.
                                        probably because i tend to make components more than groups 😛
                                          It doesn't really matter... If the user wants a group he simply Selects the new Instance, Explodes it and immediately makes a Group of the still Selected Geometry... Sometimes we authors worry too much about how users will use tools - they always find new ways of using [or breaking] them and some always want them to work differently from the way they do - sometimes they have a good idea and I adopt it - sometimes its pants!
                                            Atena
                                            Hi Chris
                                            I've the same problem as other people described. Cannot select line parallel to red axis. In my Ruby console I get Error: #TypeError: No implicit conversion from nil to integer>. Do you know what might be wrong?
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 63
                                            • 64
                                            • 45 / 64
