    [Talk] Plugins Index
    179 Posts 70 Posters 72.3k Views 70 Watching
      No. It's just to make Jim happy. β˜€
        Jim explained on the Anchor thread why these are useful. So, thanks to those involved to adding extra functionality to the forums. πŸ‘
        • Dan RathbunD Offline
          Dan Rathbun
          @tig said:
          :sketchstatic:
          That new link to thomthom's list now works [for me at least]! πŸ˜„
          At last it works! β˜€
          TIG.. there was another topic recently, (openURL w/anchor on mac,) where a user was complaining that FireFox (on OSX,) didn't handle # in urls correctly.
          I posted the link to the FF bug forum, where you can search for "anchor", and get quite a few hits, where users are complaining of bugs.
          @tig said:
          You can just right-click over the anchor-link e.g. 'TIG' in the original post and get the link - it copies the full-code that you can then use - no need to worry about constructing it - ...
          Yes this is what I was trying to say.. create the anchor first, then use it's link, to go and set a url jump "from" link.
          I'm not here much anymore.
            Yay for anchors. I've wished for this - but strangely kept my mouth shut....
              FireFox works just fine with the # anchor tags... it was the Csaba's link was constructed [and in that I display posts in reverse chronological order so the first one is the most recent]. When the anchor-link is properly formed, so to looks to the very post itself and not to that post's thread, then it all works fine πŸ˜„
                Dan Rathbun
                Agreed... and being sure the post number is in the url, should eliminate conflicts with same named anchors in the same thread.
                  Ben Ritter
                  Jim,
                  Thanks again for the updates.
                  • irwanwrI Offline
                    irwanwr
                    so many plugins available. most of them works like miracles.
                    might be quite confusing for someone like me as newbie.
                    is it possible to also look for them in order of certain term?
                    like Pull-Push, Rotate-Mirror, Texture-Map, etc.
                      Jim
                      Good idea, and something I've been thinking about trying. There are technical and social hurdles that so far have prevented implementation. How would you organizer the plugins?
                      • john2J Offline
                        john2
                        maybe categorize as
                        architecture
                        organic
                        structure
                        edge editing πŸ’­
                        or maybe like autocad categorizing like drawing, modeling , um?
                        Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                          Dan Rathbun
                          Jim pls explain again what your "sniffer" can look at?
                          • utilerU Offline
                            utiler
                            I think this one site has a good file structure, Jim...
                            http://rhin.crai.archi.fr/rld/plugins_sections.php
                            πŸ‘
                            Just Curious...
                              Jim
                              Currently, it reads the Plugins Forum, extracts topics titles containing /^[Plugin]/i along with the username of the topic.
                              Adding category info to the title isn't going to work so well since the title field has a limited length, so any category info is going to have to go in the first post using some convention (similar to the [Plugin] convention.)
                              • irwanwrI Offline
                                irwanwr
                                according to this SketchUp Plugin Reviews site, there's a plugin called Construction Line Tool by Jim and the site classify it as Essential Plugins.
                                but, i cannot find it anywhere here. any hints? thank you.
                                • BoxB Offline
                                  If you click your first link, then click the Large Red download button you will find it there called clinetool.zip
                                    Only plugins that are shared here are listed in the index. Jim hosts his own plugins on his site (follow that big, red button arrow).
                                    When we are at it, Rich also made a plugin which can draw (among others) construction (guide) lines, too:
                                    http://forums.sketchucation.com/viewtopic.php?t=37359
                                    • irwanwrI Offline
                                      irwanwr
                                      i see. thank you both Box and Gaieus.
                                      i believe that would be O'Brien and with Pen Tools?
                                      there's only one named Rich on the list.
                                      thank you very much again to both.
                                        d_e_x
                                        wow! thanks Jim for including SketchUpBIM on this list.
                                        I would anxiously look forward for SketchUpBIM to find mention on your SketchUpTips blog as well πŸ˜„
                                        http://forums.sketchucation.com/viewtopic.php?f=323&t=41840
                                          BOSS-02
                                          please i need to ask about sketchup plugins and how to setup it
                                          • mitcorbM Offline
                                            mitcorb
                                            Hi, BOSS-02:
                                            DaveR created this "sticky" thread on how to install: http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                                            If you are interested in a particular plugin and what it does, click on the link to the post. These are usually titled with [Plugin] as part of the heading. It is always a good idea to familiarize yourself with the native capabilities of Sketchup without plugins to gain a good understanding of the program.
                                            • 4 / 9
