    [Talk] Plugins Index
    179 Posts 70 Posters 102.7k Views 70 Watching
      Yay for anchors. I've wished for this - but strangely kept my mouth shut....
        FireFox works just fine with the # anchor tags... it was the Csaba's link was constructed [and in that I display posts in reverse chronological order so the first one is the most recent]. When the anchor-link is properly formed, so to looks to the very post itself and not to that post's thread, then it all works fine 😄
        • Dan RathbunD
          Dan Rathbun
          Agreed... and being sure the post number is in the url, should eliminate conflicts with same named anchors in the same thread.
          I'm not here much anymore.
          • B
            Ben Ritter
            Jim,
            Thanks again for the updates.
            • irwanwrI
              irwanwr
              so many plugins available. most of them works like miracles.
              might be quite confusing for someone like me as newbie.
              is it possible to also look for them in order of certain term?
              like Pull-Push, Rotate-Mirror, Texture-Map, etc.
                Jim
                Good idea, and something I've been thinking about trying. There are technical and social hurdles that so far have prevented implementation. How would you organizer the plugins?
                • john2J
                  john2
                  maybe categorize as
                  architecture
                  organic
                  structure
                  edge editing 💭
                  or maybe like autocad categorizing like drawing, modeling , um?
                  Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                  • Dan RathbunD
                    Dan Rathbun
                    Jim pls explain again what your "sniffer" can look at?
                    • utilerU
                      utiler
                      I think this one site has a good file structure, Jim...
                      http://rhin.crai.archi.fr/rld/plugins_sections.php
                      Just Curious...
                        Jim
                        Currently, it reads the Plugins Forum, extracts topics titles containing /^[Plugin]/i along with the username of the topic.
                        Adding category info to the title isn't going to work so well since the title field has a limited length, so any category info is going to have to go in the first post using some convention (similar to the [Plugin] convention.)
                        • irwanwrI
                          irwanwr
                          according to this SketchUp Plugin Reviews site, there's a plugin called Construction Line Tool by Jim and the site classify it as Essential Plugins.
                          but, i cannot find it anywhere here. any hints? thank you.
                          • BoxB
                            If you click your first link, then click the Large Red download button you will find it there called clinetool.zip
                            • GaieusG
                              Only plugins that are shared here are listed in the index. Jim hosts his own plugins on his site (follow that big, red button arrow).
                              When we are at it, Rich also made a plugin which can draw (among others) construction (guide) lines, too:
                              http://forums.sketchucation.com/viewtopic.php?t=37359
                              • irwanwrI
                                irwanwr
                                i see. thank you both Box and Gaieus.
                                i believe that would be O'Brien and with Pen Tools?
                                there's only one named Rich on the list.
                                thank you very much again to both.
                                  d_e_x
                                  wow! thanks Jim for including SketchUpBIM on this list.
                                  I would anxiously look forward for SketchUpBIM to find mention on your SketchUpTips blog as well 😄
                                  404 Not Found
                                  (forums.sketchucation.com)
                                  • B
                                    BOSS-02
                                    please i need to ask about sketchup plugins and how to setup it
                                    • mitcorbM
                                      mitcorb
                                      Hi, BOSS-02:
                                      DaveR created this "sticky" thread on how to install: http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                                      If you are interested in a particular plugin and what it does, click on the link to the post. These are usually titled with [Plugin] as part of the heading. It is always a good idea to familiarize yourself with the native capabilities of Sketchup without plugins to gain a good understanding of the program.
                                        davesec
                                        hi!
                                        i realize this is sort of a subjective subject, but could you mark maybe the top 20 'most used' or most useful plugins? i don't mean to demean anyone's efforts here, i'm sure they are all very good, but it would be a big help to me if i knew which ones are useful for almost everybody!
                                        • Dan RathbunD
                                          Dan Rathbun
                                          Dave, Jim's indexer only "sniffs" the information that is displayed on the forum topic list pages.
                                          There's no way to tell anything subjective. There are number of replies, and number of views, but these can be for other reasons (such as reporting bugs to the author, help requests, new feature requests, etc.) The number of times downloaded for files (in a batch sense,) is only something the sysops can access (I believe.) Yes you can see download number for an individual file, when you actually look AT topic page. But Jim's sniffer does not actually do that. Even if it did... that number cannot indicate much. For instance, it might be a plugin that WAS popular, but is no longer needed for the latest SU version.
                                          So what would happen, is Jim would need to have his script read a manually maintained "Must Have" list, and then he could mark (special color, etc.) the links for the plugins in the list.
                                          Any way (for now)... see this sticky topic, which IS a subjective list:
                                          Must Have Ruby Plugins - Visual Index
                                          • brookefoxB
                                            brookefox
                                            For me it would be helpful if the plugins listed here were also listed here alphabetically. I know I can search for and find any plugin in other ways, I just want my cake with a little icing, please.
                                            ~ Brooke
                                            • 6 / 9
