    Vertex Counting plugin?
    14 Posts 7 Posters 3.1k Views 7 Watching
    • sdmitchS Offline
      sdmitch
      @dsarchs said:
      Does anyone know if a plugin exists that can give you a quick count of how many vertices are in a given selection? If not, would that be an easy script to write?
      Here is one that will. It looks at whole model if nothing is selected.
      require 'sketchup'
      module SDM_PtCnt
        def self.point_counter
          mod=Sketchup.active_model
          ent=mod.active_entities
          sel=mod.selection
          sel=ent if sel.empty?
          @f_cnt=0;@e_cnt=0;@verts=[]
          recurse(sel)
          @verts.flatten!.uniq!
          UI.messagebox "This model contains\n\n#{@f_cnt} faces\n#{@e_cnt} edges\nand #{@verts.length-1} vertices"
        def self.recurse(ents)
          ents.each do |e|
            if e.is_a? Sketchup;;Group
              recurse(e.entities)
            elsif e.is_a? Sketchup;;ComponentInstance
              recurse(e.definition.entities)
            elsif e.is_a? Sketchup;;Face
              @f_cnt += 1;@verts<<e.vertices
            elsif e.is_a? Sketchup;;Edge
              @e_cnt += 1;@verts<<e.vertices
      if not file_loaded?(File.basename(__FILE__))
        UI.menu("Plugins").add_item("Point Counter") { SDM_PtCnt.point_counter }
        file_loaded(File.basename(__FILE__))
      http://sdmitch.blogspot.com/
        Beware of the bang methods. .flatten! and .uniq! - while faster and preferred, will return nil upon no change.
        One has to use them on separate lines to avoid potential, and likely, errors.
        @verts.flatten! @verts.uniq!
          dsarchs
          Thanks for the responses. I'll have to try this out when I get home tonight.
          Knowledge is a polite word for dead but not buried imagination.
          -e.e.cummings
            But combined as @verts.flatten.uniq! so there's only an end 'bang!' it will work.
            Without the ! it returns the changed array, with it it returns either the changed array OR nil if there's no change !!
              dsarchs
              I finally had a chance to try this out and it works (almost) perfectly!
              Almost because for some reason it always returns 1 less vertex than is actually present. For example, a square plane shows 3, a cube shows 7, etc.
              This is a complete non-issue, though, since I'm just trying to make sure the number is less than (I think) 25,000.
              Thanks again!
              -e.e.cummings
                In my code you compile an array of arrays of vertices from faces... [vs]
                The vs.flatten! explodes the arrays into one giant array.
                The vs.uniq! ensures that there are no duplicates [two abutting faces share 2 vertices].
                The vs.length returns the total number of vertices - it should not be 'short' πŸ˜•
                  dsarchs
                  I actually used the code offered by sdmitch (after having separated the command as thomthom suggested), and saved it as a plugin rather than having to cut+paste whenever I wanted to check.
                  -e.e.cummings
                    Fredo has vertex marking tools and count sides tool maybe ask to report the vert numbers?
                    A small donation goes along way πŸ‘
                    • sdmitchS Offline
                      sdmitch
                      You are correct. The count was one less than it should be. Out of habit, because Ruby array index always starts at 0, subtracting 1 from the array length is so common that it is a reflex action. The correct message statement would be
                      UI.messagebox "This model contains\n\n#{@f_cnt} faces\n#{@e_cnt} edges\nand #{@verts.length} vertices"
                        dsarchs
                        Thanks, although I'm not really worried that it lists 1 less than actual. I just checked and the limit is 64,000 vertices -- so being off by 1 is irrelevant. I mostly wanted a tool to see how many object groups I could combine for single export.
                        If I think about it I'll change the code when I get home tonight -- but either way it's working for what I need it to do.
                        -e.e.cummings
                        • fredo6F Offline
                          The new version of CountFacesBySides, part of FredoTools, now provide the count of vertices in the selection or the whole model.
                          • bac9-flclB Offline
                            bac9-flcl
                            Hey, I've just wanted to say thanks for all your answers here!
                            I'm working with CE3 too, and your code is really helpful to me. πŸ˜„
