    Vertex Counting plugin?
    14 Posts 7 Posters 3.1k Views 7 Watching
      If the vertices belong to faces [rather than edges that don't necessarily have a face]...
      You can get the vertices in a selection thus:
      vs=[];Sketchup.active_model.selection.each{|e|vs<<e.vertices if e.class==Sketchup::Face};vs.flatten!;vs.uniq!;p vs.length
      Copy+paste into the Ruby Console - it puts the number of vertices in the Select into the Console...
      If the Selection is a Group/Instance either edit it first and Select-All OR recast the code the dig down into group.entities etc...
      • sdmitchS Offline
        sdmitch
        @dsarchs said:
        Does anyone know if a plugin exists that can give you a quick count of how many vertices are in a given selection? If not, would that be an easy script to write?
        Here is one that will. It looks at whole model if nothing is selected.
        require 'sketchup'
        module SDM_PtCnt
          def self.point_counter
            mod=Sketchup.active_model
            ent=mod.active_entities
            sel=mod.selection
            sel=ent if sel.empty?
            @f_cnt=0;@e_cnt=0;@verts=[]
            recurse(sel)
            @verts.flatten!.uniq!
            UI.messagebox "This model contains\n\n#{@f_cnt} faces\n#{@e_cnt} edges\nand #{@verts.length-1} vertices"
          def self.recurse(ents)
            ents.each do |e|
              if e.is_a? Sketchup;;Group
                recurse(e.entities)
              elsif e.is_a? Sketchup;;ComponentInstance
                recurse(e.definition.entities)
              elsif e.is_a? Sketchup;;Face
                @f_cnt += 1;@verts<<e.vertices
              elsif e.is_a? Sketchup;;Edge
                @e_cnt += 1;@verts<<e.vertices
        if not file_loaded?(File.basename(__FILE__))
          UI.menu("Plugins").add_item("Point Counter") { SDM_PtCnt.point_counter }
          file_loaded(File.basename(__FILE__))
        http://sdmitch.blogspot.com/
          Beware of the bang methods. .flatten! and .uniq! - while faster and preferred, will return nil upon no change.
          One has to use them on separate lines to avoid potential, and likely, errors.
          @verts.flatten! @verts.uniq!
            dsarchs
            Thanks for the responses. I'll have to try this out when I get home tonight.
            Knowledge is a polite word for dead but not buried imagination.
            -e.e.cummings
              But combined as @verts.flatten.uniq! so there's only an end 'bang!' it will work.
              Without the ! it returns the changed array, with it it returns either the changed array OR nil if there's no change !!
                dsarchs
                I finally had a chance to try this out and it works (almost) perfectly!
                Almost because for some reason it always returns 1 less vertex than is actually present. For example, a square plane shows 3, a cube shows 7, etc.
                This is a complete non-issue, though, since I'm just trying to make sure the number is less than (I think) 25,000.
                Thanks again!
                -e.e.cummings
                  In my code you compile an array of arrays of vertices from faces... [vs]
                  The vs.flatten! explodes the arrays into one giant array.
                  The vs.uniq! ensures that there are no duplicates [two abutting faces share 2 vertices].
                  The vs.length returns the total number of vertices - it should not be 'short' πŸ˜•
                    dsarchs
                    I actually used the code offered by sdmitch (after having separated the command as thomthom suggested), and saved it as a plugin rather than having to cut+paste whenever I wanted to check.
                    -e.e.cummings
                      Fredo has vertex marking tools and count sides tool maybe ask to report the vert numbers?
                      A small donation goes along way πŸ‘
                      • sdmitchS Offline
                        sdmitch
                        You are correct. The count was one less than it should be. Out of habit, because Ruby array index always starts at 0, subtracting 1 from the array length is so common that it is a reflex action. The correct message statement would be
                        UI.messagebox "This model contains\n\n#{@f_cnt} faces\n#{@e_cnt} edges\nand #{@verts.length} vertices"
                          dsarchs
                          Thanks, although I'm not really worried that it lists 1 less than actual. I just checked and the limit is 64,000 vertices -- so being off by 1 is irrelevant. I mostly wanted a tool to see how many object groups I could combine for single export.
                          If I think about it I'll change the code when I get home tonight -- but either way it's working for what I need it to do.
                          -e.e.cummings
                          • fredo6F Offline
                            The new version of CountFacesBySides, part of FredoTools, now provide the count of vertices in the selection or the whole model.
                            • bac9-flclB Offline
                              bac9-flcl
                              Hey, I've just wanted to say thanks for all your answers here!
                              I'm working with CE3 too, and your code is really helpful to me. πŸ˜„
