    [Plugin] ShadowProjector
    129 Posts 36 Posters 117.0k Views 36 Watching
      Perhaps it's my Christmas Present to SCF...
      I've been working on it for some time... and I finally got a moment to polish if up for its release...
      • mitcorbM
        mitcorb
        Hi, TIG:
        Another great tool from you.
        • simon le bonS
          simon le bon
          http://i274.photobucket.com/albums/jj245/Spendauballet/iSimon/penguin-1.gif
          http://i274.photobucket.com/albums/jj245/Spendauballet/iSimon/rul1ek75-1.gif
          *s
          • jolranJ
            jolran
            Cool idea, TIG! 👍
              darospa
              fantastic!!!! a great help for architectural drawings instead of cheap renderings
              thank you
              • utilerU
                utiler
                @tig said:
                @utiler said:
                Neat TIG!! DO you ever get time to work for money???
                This is a little like GOH's 1001Shadows, right?
                http://www.1001shadows.com/en/index.html
                Not the same thing, this shows shadows cast on selected faces by objects, I don't have that tool but I think 1001shadows projects all onto the 'ground' [of course if you have a ground-plane face selected my tool does the same]. My tool also has options of displaying the shadows - from a line, to a face, to a face with statistics...
                That's pretty cool, TIG. 👍
                Just Curious...
                • pbacotP
                  Something cool about this but not sure how someone makes use of it. Is it only so you can export a polygon and use it in a CAD rendering (2d)?
                    It's as useful as you think up uses for it... 😕
                    For example, checking the % of solar shading on some selected glazing at a certain Date/Time.
                    Getting the area [sq'/sqm] of perhaps some selected glazing or a solar-panel that's receiving [or not receiving] direct sunlight...
                    Because faces using a translucent material don't show normal shadows you can now use this tool to add a visible translucent 'gray' shadow-group face [with no edges] onto selected window-glass etc, to fake these shadows in a Sup render...
                    DAE files etc don't contain shadow info but you can now include a faced snapshot of the shadows if desired.
                    I only invented the tool - you lot need to come up with uses for it... 😉
                    • simon le bonS
                      simon le bon
                      Dear Tig,
                      That was exactly what I wanted to experiment: colored glasses and their colored shadows...
                      Glasses and bottle are drawn , but 😕 I can't make to "ShadowProjector" draw their shadows.. Probably too complex shapes.
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thShadowProjector_TIG_002.jpg
                      😒 simon
                        driven
                        Simon,
                        what scale are you trying at, is it a small triangle issue... just a thought
                        • simon le bonS
                          simon le bon
                          Hi John
                          You are right in the way I never take enough care of the scale !!! 😉
                          In this occurrence, the scale is not too small but too big: a glass of 135cm width !! You may be thirsty 😲
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thShadowProjector_TIG_004.jpg
                          ++simon
                            Is the orange face 'reversed' - view in Monochrome mode to see.
                            Shadows are only cast onto front faces.
                            Also there is an issue with tiny faces/holes and groups/instances placed exactly onto a face and casting a shadow.
                            I'm doing a fix now...
                              Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=371243#p371243
                              1.1 20111214 Addressed issues with tiny faces/holes and group/instance sitting on face whilst casting a shadow.
                              • simon le bonS
                                simon le bon
                                Hi TIG 😉
                                This tool is a great idea ++ 👍
                                I'm very sorry The updated rb doesn't work at all and anymore for me (and the first version is overwrited arghhh!).
                                Please can you pick an eye on my following SketchUp 7 model ?
                                TIG_shadowProjector002.skp
                                Sorry for trouble 😕
                                ++simon
                                  @simon le bon said:
                                  Hi TIG 😉
                                  [attachment=1:12he1z9c]<!-- ia1 -->TIG_shadowProjector002.skp<!-- ia1 -->[/attachment:12he1z9c]
                                  Sorry for trouble 😕
                                  ++simon
                                  I can get it to work with reduced complexity [removing the 'glass']...
                                  [attachment=0:12he1z9c]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:12he1z9c]
                                  I don't have v1.0 either 😒 [lost it!]
                                  I'll investigate...
                                  • simon le bonS
                                    simon le bon
                                    Hi TIG,
                                    Me too 👍 😉
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ShadowProjector_TIG_005.jpg
                                    I'm going to test the ShadowProjector with incremental complexity models...
                                    thank you for your patience and kindness
                                    *s
                                      Hiding the glass, or putting it onto an 'off' layer work too...
                                      • simon le bonS
                                        simon le bon
                                        Dear TIG
                                        As I can conclude , ShadowProjector not only take in account the geometry casted by the shadowed selected face, but also the entire geometry of the model.😒
                                        Alas ShadowProjector is stopped by the first model 😕
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ShadowProjector_TIG_006.jpg
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ShadowProjector_TIG_007.jpg
                                        TIG_shadowProjector_incrementalComplexity.skp
                                        Simon.
                                        PS1: I am not happy to be the one who show the tool limitations 😳
                                        PS: [Plugin] Teapot (1.0.0) — 01 December 2009
                                          You are right.
                                          It would be better/quicker if it found only the objects potentially casting shadows on the face...
                                          BUT the algorithm to do that robustly is beyond me [at the moment].
                                          So at the moment it checks everything that's active for shadow casting even when it doesn't even cast a shadow on the face.
                                          So I suggest that keep the 'active entities' simple [using temporary grouping?] and do small sets of shadows...
                                            Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=371243#p371243
                                            Its speed and error trapping are improved.
                                            It now limits its purview to potential shadow-casting objects and is therefore quicker... 😲
                                            • 1 / 7
