    [Plugin] ShadowProjector
    129 Posts 36 Posters 97.5k Views 36 Watching
    • pbacotP Offline
      Something cool about this but not sure how someone makes use of it. Is it only so you can export a polygon and use it in a CAD rendering (2d)?
        It's as useful as you think up uses for it... 😕
        For example, checking the % of solar shading on some selected glazing at a certain Date/Time.
        Getting the area [sq'/sqm] of perhaps some selected glazing or a solar-panel that's receiving [or not receiving] direct sunlight...
        Because faces using a translucent material don't show normal shadows you can now use this tool to add a visible translucent 'gray' shadow-group face [with no edges] onto selected window-glass etc, to fake these shadows in a Sup render...
        DAE files etc don't contain shadow info but you can now include a faced snapshot of the shadows if desired.
        I only invented the tool - you lot need to come up with uses for it... 😉
        • simon le bonS Offline
          simon le bon
          Dear Tig,
          That was exactly what I wanted to experiment: colored glasses and their colored shadows...
          Glasses and bottle are drawn , but 😕 I can't make to "ShadowProjector" draw their shadows.. Probably too complex shapes.
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thShadowProjector_TIG_002.jpg
          😒 simon
            driven
            Simon,
            what scale are you trying at, is it a small triangle issue... just a thought
              simon le bon
              Hi John
              You are right in the way I never take enough care of the scale !!! 😉
              In this occurrence, the scale is not too small but too big: a glass of 135cm width !! You may be thirsty 😲
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thShadowProjector_TIG_004.jpg
              ++simon
                Is the orange face 'reversed' - view in Monochrome mode to see.
                Shadows are only cast onto front faces.
                Also there is an issue with tiny faces/holes and groups/instances placed exactly onto a face and casting a shadow.
                I'm doing a fix now...
                  Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=371243#p371243
                  1.1 20111214 Addressed issues with tiny faces/holes and group/instance sitting on face whilst casting a shadow.
                    simon le bon
                    Hi TIG 😉
                    This tool is a great idea ++ 👍
                    I'm very sorry The updated rb doesn't work at all and anymore for me (and the first version is overwrited arghhh!).
                    Please can you pick an eye on my following SketchUp 7 model ?
                    TIG_shadowProjector002.skp
                    Sorry for trouble 😕
                    ++simon
                      @simon le bon said:
                      Hi TIG 😉
                      [attachment=1:12he1z9c]<!-- ia1 -->TIG_shadowProjector002.skp<!-- ia1 -->[/attachment:12he1z9c]
                      Sorry for trouble 😕
                      ++simon
                      I can get it to work with reduced complexity [removing the 'glass']...
                      [attachment=0:12he1z9c]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:12he1z9c]
                      I don't have v1.0 either 😒 [lost it!]
                      I'll investigate...
                        simon le bon
                        Hi TIG,
                        Me too 👍 😉
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ShadowProjector_TIG_005.jpg
                        I'm going to test the ShadowProjector with incremental complexity models...
                        thank you for your patience and kindness
                        *s
                          Hiding the glass, or putting it onto an 'off' layer work too...
                            simon le bon
                            Dear TIG
                            As I can conclude , ShadowProjector not only take in account the geometry casted by the shadowed selected face, but also the entire geometry of the model.😒
                            Alas ShadowProjector is stopped by the first model 😕
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ShadowProjector_TIG_006.jpg
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ShadowProjector_TIG_007.jpg
                            TIG_shadowProjector_incrementalComplexity.skp
                            Simon.
                            PS1: I am not happy to be the one who show the tool limitations 😳
                            PS: [Plugin] Teapot (1.0.0) — 01 December 2009
                              You are right.
                              It would be better/quicker if it found only the objects potentially casting shadows on the face...
                              BUT the algorithm to do that robustly is beyond me [at the moment].
                              So at the moment it checks everything that's active for shadow casting even when it doesn't even cast a shadow on the face.
                              So I suggest that keep the 'active entities' simple [using temporary grouping?] and do small sets of shadows...
                                Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=371243#p371243
                                Its speed and error trapping are improved.
                                It now limits its purview to potential shadow-casting objects and is therefore quicker... 😲
                                  simon le bon
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ShadowProjector_TIG_009.jpg
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ShadowProjector_TIG_010.jpg
                                  As it is, it's already a great tool dear TIG
                                  Thank you so much to make SketchUp each day growing as a wonderful application
                                  ++simon
                                  • dereiD Offline
                                    derei
                                    I can't use the plugin 😞 It crashes my model all the time. I made a magnifier glass and a ground plane (face) . I selected the face, that was oriented with front upwards (the shadow projected on front face), then ran the plugin. ... First time it made a grouped face over my selected one. Now it just crashes every time.
                                    Model attached.
                                    magnifier.skp
                                    DESIGNER AND ARTIST DEREI.UK
                                      It Bugsplats for me too. 😕 😢
                                      It's a relatively small object and makes many tiny facets in the shadow that it needs to process.
                                      Some complex shapes just have too much geometry.
                                      I erased the unneeded coplanar edges which up the face count considerably!
                                      Also made sure the forms were solids - tiny holes leak shadows - erased unwanted internal partitions and flaps...
                                      The small detailing on the handle also makes some tiny facets when projected.
                                      Lifting the handle up 1mm so it didn't touch the face [a single point of contact or tiny common facet seems to be awkward].
                                      Making it 1000 bigger using Scale, simplifying the handle and putting the lens on an 'off' layer [you don't want it's shadow anyway ?] - I did get it to work eventually... BUT it took ages !
                                      If I copy/paste your geometry into a new SKP I get an error fix now ? message about zero length edges - BUT it doesn't 'fix' within the SKP itself - weird...
                                      • sbpronhS Offline
                                        sbpronh
                                        Using this technic and some more 😄 creating anamorph art would be great!!!! url:
                                        http://jrengozzi.wordpress.com/page/2/
                                        Regards and thanks!
                                        Harry
                                        • JuantxoJ Offline
                                          Juantxo
                                          If someone is interested there is a similar shadow projector in skelion plugin.
                                          You can project shadows at specific time, but over a range of time too, that's the main difference of the plugin.
                                          I tried with the magnifier.skp test and it works.(Time calculation about a minut)
                                            morph
                                            to TIG
                                            I try to find the way to reduce the time of ShadowProjector plugin culation process after I found it take a long time when the number of calculated face up to 50 faces.
                                            Now, I study in master degree and try to create plugin to retrieve shadow area from all day solar vector on glass face of building. When I try to put ShadowProjector algorithm to 10 loops solar vector, the time usage graph of 10 loops are not linear. It is parabola although the time usage graph in loop which use the .raytest function is linear.
                                            Please suggestion.
                                            • 2 / 7
