    [Plugin] ShadowProjector
    129 Posts 36 Posters 112.7k Views 36 Watching
    • simon le bonS Offline
      simon le bon
      Perhaps it's my Christmas Present to SCF...
      http://i274.photobucket.com/albums/jj245/Spendauballet/iSimon/penguin-1.gif
      http://i274.photobucket.com/albums/jj245/Spendauballet/iSimon/rul1ek75-1.gif
      *s
      • jolranJ Offline
        jolran
        Cool idea, TIG! 👍
          darospa
          fantastic!!!! a great help for architectural drawings instead of cheap renderings
          thank you
          • utilerU Offline
            utiler
            @tig said:
            @utiler said:
            Neat TIG!! DO you ever get time to work for money???
            This is a little like GOH's 1001Shadows, right?
            http://www.1001shadows.com/en/index.html
            Not the same thing, this shows shadows cast on selected faces by objects, I don't have that tool but I think 1001shadows projects all onto the 'ground' [of course if you have a ground-plane face selected my tool does the same]. My tool also has options of displaying the shadows - from a line, to a face, to a face with statistics...
            That's pretty cool, TIG. 👍
            Just Curious...
            • pbacotP Offline
              Something cool about this but not sure how someone makes use of it. Is it only so you can export a polygon and use it in a CAD rendering (2d)?
                It's as useful as you think up uses for it... 😕
                For example, checking the % of solar shading on some selected glazing at a certain Date/Time.
                Getting the area [sq'/sqm] of perhaps some selected glazing or a solar-panel that's receiving [or not receiving] direct sunlight...
                Because faces using a translucent material don't show normal shadows you can now use this tool to add a visible translucent 'gray' shadow-group face [with no edges] onto selected window-glass etc, to fake these shadows in a Sup render...
                DAE files etc don't contain shadow info but you can now include a faced snapshot of the shadows if desired.
                I only invented the tool - you lot need to come up with uses for it... 😉
                  simon le bon
                  Dear Tig,
                  That was exactly what I wanted to experiment: colored glasses and their colored shadows...
                  Glasses and bottle are drawn , but 😕 I can't make to "ShadowProjector" draw their shadows.. Probably too complex shapes.
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thShadowProjector_TIG_002.jpg
                  😒 simon
                    driven
                    Simon,
                    what scale are you trying at, is it a small triangle issue... just a thought
                      simon le bon
                      Hi John
                      You are right in the way I never take enough care of the scale !!! 😉
                      In this occurrence, the scale is not too small but too big: a glass of 135cm width !! You may be thirsty 😲
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thShadowProjector_TIG_004.jpg
                      ++simon
                        Is the orange face 'reversed' - view in Monochrome mode to see.
                        Shadows are only cast onto front faces.
                        Also there is an issue with tiny faces/holes and groups/instances placed exactly onto a face and casting a shadow.
                        I'm doing a fix now...
                          Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=371243#p371243
                          1.1 20111214 Addressed issues with tiny faces/holes and group/instance sitting on face whilst casting a shadow.
                            simon le bon
                            Hi TIG 😉
                            This tool is a great idea ++ 👍
                            I'm very sorry The updated rb doesn't work at all and anymore for me (and the first version is overwrited arghhh!).
                            Please can you pick an eye on my following SketchUp 7 model ?
                            TIG_shadowProjector002.skp
                            Sorry for trouble 😕
                            ++simon
                              @simon le bon said:
                              Hi TIG 😉
                              [attachment=1:12he1z9c]<!-- ia1 -->TIG_shadowProjector002.skp<!-- ia1 -->[/attachment:12he1z9c]
                              Sorry for trouble 😕
                              ++simon
                              I can get it to work with reduced complexity [removing the 'glass']...
                              [attachment=0:12he1z9c]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:12he1z9c]
                              I don't have v1.0 either 😒 [lost it!]
                              I'll investigate...
                                simon le bon
                                Hi TIG,
                                Me too 👍 😉
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ShadowProjector_TIG_005.jpg
                                I'm going to test the ShadowProjector with incremental complexity models...
                                thank you for your patience and kindness
                                *s
                                  Hiding the glass, or putting it onto an 'off' layer work too...
                                    simon le bon
                                    Dear TIG
                                    As I can conclude , ShadowProjector not only take in account the geometry casted by the shadowed selected face, but also the entire geometry of the model.😒
                                    Alas ShadowProjector is stopped by the first model 😕
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ShadowProjector_TIG_006.jpg
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ShadowProjector_TIG_007.jpg
                                    TIG_shadowProjector_incrementalComplexity.skp
                                    Simon.
                                    PS1: I am not happy to be the one who show the tool limitations 😳
                                    PS: [Plugin] Teapot (1.0.0) — 01 December 2009
                                      You are right.
                                      It would be better/quicker if it found only the objects potentially casting shadows on the face...
                                      BUT the algorithm to do that robustly is beyond me [at the moment].
                                      So at the moment it checks everything that's active for shadow casting even when it doesn't even cast a shadow on the face.
                                      So I suggest that keep the 'active entities' simple [using temporary grouping?] and do small sets of shadows...
                                        Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=371243#p371243
                                        Its speed and error trapping are improved.
                                        It now limits its purview to potential shadow-casting objects and is therefore quicker... 😲
                                          simon le bon
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ShadowProjector_TIG_009.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ShadowProjector_TIG_010.jpg
                                          As it is, it's already a great tool dear TIG
                                          Thank you so much to make SketchUp each day growing as a wonderful application
                                          ++simon
                                          • dereiD Offline
                                            derei
                                            I can't use the plugin 😞 It crashes my model all the time. I made a magnifier glass and a ground plane (face) . I selected the face, that was oriented with front upwards (the shadow projected on front face), then ran the plugin. ... First time it made a grouped face over my selected one. Now it just crashes every time.
                                            Model attached.
                                            magnifier.skp
                                            DESIGNER AND ARTIST DEREI.UK
                                            • 2 / 7
