    [Plugin] ShadowProjector
    129 Posts 36 Posters 98.1k Views 36 Watching
      d0n
      really useful plugin
      Would it be possible to add an option to pick the source of the shadow ? say I only want to see the projected shadow from 1 component on 1 selected face
        Just idea : makes the "solid shadow" volume from the object to the ground shadow casted ๐Ÿ˜‰
        So that will obtain a funny volume that you can colorize as you want !
        So you can calculate its volume for any process ๐Ÿ˜„
        For example compare 2 objects for know what the object who makes the biggest shadow volume! ๐Ÿ˜‰
        Or the one who makes the more beauty shadow volume!
        Poetic isn't it ? โ˜€
        Or another funny problem of reverse ingeneering ๐Ÿ˜„
        What is the object who create this shadow volume ๐Ÿ˜„
          @utiler said:
          Neat TIG!! DO you ever get time to work for money???
          This is a little like GOH's 1001Shadows, right?
          http://www.1001shadows.com/en/index.html
          ๐Ÿ‘
          Not the same thing, this shows shadows cast on selected faces by objects, I don't have that tool but I think 1001shadows projects all onto the 'ground' [of course if you have a ground-plane face selected my tool does the same]. My tool also has options of displaying the shadows - from a line, to a face, to a face with statistics...
            Select the objects you don't want to cast shadows and temporarily group them, then either put the group onto an 'off' layer or hide that group OR simply Edit>Cut the unwanted items. Then do the shadows and the unseen grouped/cut objects are ignored; then unhide the temporary group and explode it OR Edit>PastInPlace to restore the objects ?
            • PixeroP Offline
              Pixero
              Wow, thanks TIG this seem to be exactly what I wished for a little while ago. To bad it's too late for that perticular project but there will be more I'm sure.
              • StinkieS Offline
                Stinkie
                Cool! Thanks! ๐Ÿ‘
                • simon le bonS Offline
                  simon le bon
                  Hi TIG ๐Ÿ˜„ โ˜€
                  How many smart tools from you I haven't tested? a bunch of them I guess: it's a pity (but they are carefully bookmarked ๐Ÿ˜‰ ).
                  This one one more time, is full of potential ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thShadowProjector_TIG_001.jpg
                  http://i274.photobucket.com/albums/jj245/Spendauballet/iSimon/759.gif
                  simon
                    Perhaps it's my Christmas Present to SCF...
                    I've been working on it for some time... and I finally got a moment to polish if up for its release...
                    • mitcorbM Offline
                      mitcorb
                      Hi, TIG:
                      Another great tool from you.
                        simon le bon
                        http://i274.photobucket.com/albums/jj245/Spendauballet/iSimon/penguin-1.gif
                        ๐Ÿ‘ ๐Ÿ‘
                        ๐Ÿ˜Ž
                        http://i274.photobucket.com/albums/jj245/Spendauballet/iSimon/rul1ek75-1.gif
                        *s
                        • jolranJ Offline
                          jolran
                          Cool idea, TIG! ๐Ÿ‘
                            darospa
                            fantastic!!!! a great help for architectural drawings instead of cheap renderings
                            thank you
                            • utilerU Offline
                              utiler
                              ๐Ÿ‘
                              That's pretty cool, TIG. ๐Ÿ‘
                              Just Curious...
                              • pbacotP Offline
                                Something cool about this but not sure how someone makes use of it. Is it only so you can export a polygon and use it in a CAD rendering (2d)?
                                  It's as useful as you think up uses for it... ๐Ÿ˜•
                                  For example, checking the % of solar shading on some selected glazing at a certain Date/Time.
                                  Getting the area [sq'/sqm] of perhaps some selected glazing or a solar-panel that's receiving [or not receiving] direct sunlight...
                                  Because faces using a translucent material don't show normal shadows you can now use this tool to add a visible translucent 'gray' shadow-group face [with no edges] onto selected window-glass etc, to fake these shadows in a Sup render...
                                  DAE files etc don't contain shadow info but you can now include a faced snapshot of the shadows if desired.
                                  I only invented the tool - you lot need to come up with uses for it... ๐Ÿ˜‰
                                    simon le bon
                                    Dear Tig,
                                    That was exactly what I wanted to experiment: colored glasses and their colored shadows...
                                    Glasses and bottle are drawn , but ๐Ÿ˜• I can't make to "ShadowProjector" draw their shadows.. Probably too complex shapes.
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thShadowProjector_TIG_002.jpg
                                    ๐Ÿ˜’ simon
                                      driven
                                      Simon,
                                      what scale are you trying at, is it a small triangle issue... just a thought
                                        simon le bon
                                        Hi John
                                        You are right in the way I never take enough care of the scale !!! ๐Ÿ˜‰
                                        In this occurrence, the scale is not too small but too big: a glass of 135cm width !! You may be thirsty ๐Ÿ˜ฒ
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thShadowProjector_TIG_004.jpg
                                        ++simon
                                          Is the orange face 'reversed' - view in Monochrome mode to see.
                                          Shadows are only cast onto front faces.
                                          Also there is an issue with tiny faces/holes and groups/instances placed exactly onto a face and casting a shadow.
                                          I'm doing a fix now...
                                            Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=371243#p371243
                                            1.1 20111214 Addressed issues with tiny faces/holes and group/instance sitting on face whilst casting a shadow.
                                            • 1 / 7
