    Whats Your Best Method Of Animation With SU?
    extensions
    48 Posts 14 Posters 7.0k Views 14 Watching
    • iichiversiiI Offline
      iichiversii
      I had the same proplem using shaderlight, to get it working correctly after you create tweets, set animation settings trasition to on, and deley to 1, also set render to 1 frame per sec, it worked for me, yeah my rig is only for my characters, but iv rigged tanks, cars with rigs also using the same method, if you like i could render your animation in shaderlight, for you, just send me a link to your skp file, if you like
      Bring on the Rain...
      • ashscottA Offline
        ashscott
        SKP file isn't ready for rendering at the moment but how much rendering power do you have at your disposal? My dual core laptop is struggling and it would be handy to have someone with a grunty machine that I could send pre-set skp files to who could then render them overnight.....negotiate payment of course
        Just some stuff I do with Sketchup.
          The thread seem to be warming up, maybe it's best to leave it in place then, eh?
          • W Offline
            wyatt
            @ashscott said:
            I had a go with SU Animate a long time ago and I didn't get very far - would you recommend it for the kind of object animation I am describing?
            I believe SUA has a free trial so it can't hurt to give it a try. I've not used it a lot, but found it easier to set up than Proper Animation. SUA recently released a pretty major update that now includes key frames. I've toyed with Keyframe, but haven't used it for anything so I don't know how it compares.
              tallbridgeguy
              I while back I made a video tut on keyframe with kerkythea. Maybe it helps?
              Nielsen
              http://www.tallbridgeguy.com/
                iichiversii
                I purchased Su_Animate bout 3 months ago, and updated to new version not so long ago, it is tricky to work with at first, but dont give in so easy, take time with it, do a few tests and it becomes second nature, i havent looked back and use it nearly everyday, i recommend it
                • bazB Offline
                  baz
                  @iichiversii said:
                  Baz thats a simple fly thru animation, su animate or keyframe are not needed to do this, ifyou wanted to animate the jeep to move in your scene you could use keyframe or su animate to do so, but nice fly thru, and music sets the mood, i like it 😄
                  Sorry guys, I missed the point of the thread, Ie: animation, but thanks for the patience and kind comments. Do you think I should I remove the post? (Mods could decide?)
                  Damien, just looked at your 'knife kick' animation, amazing, I had no idea this was doable in Su. It also gives me a clue as to why you approve of the entirely inappropriate music on my flythru 😄
                  I will continue to follow this thread, but I will pull my head in, promise.
                  baz
                    iichiversii
                    wouldnt remove it Baz, its a good example of a fly thru, i would like to see a rendered version of it, my knife kick animation wasnt easy to do in SU, but i have a better exampe which i wll be posting up soon, SU isnt designed to do animations i have done but with plenty of practice i came up with a way to animate, the knife clp was doing using keyframe animation plugin, and rendered in shaderlight
                    • utilerU Offline
                      utiler
                      New update to Keyframe Animation.
                      http://forums.sketchucation.com/viewtopic.php?f=323&t=33417
                      Just Curious...
                      • ashscottA Offline
                        ashscott
                        Yeah lets give it a go as is 😉
                        • ashscottA Offline
                          ashscott
                          Thats a nice video TBG, I'm gonna refer to it in future.
                          • ashscottA Offline
                            ashscott
                            So relieved about keyframe not having the problem with transformation.interpolate.....
                            Getting miles down the track with proper animation and finding I couldn't get a particular component to rotate the way I wanted was quite frustrating (yes I did adjust the component axis which works a lot of the time but had a few instances where it just wouldn't behave).
                            • HumpmetwiceH Offline
                              Humpmetwice
                              Could a sketch-up model me imported into Blender and animated that way?
                                iichiversii
                                Yes it can, i havent tried it but it can be, if i had the Blender knowledge id be doing it all the time, im sure there are tutorials on the web on how to import them
                                • ashscottA Offline
                                  ashscott
                                  Anyone got experience with Blender? Sounds like it could be cool.
                                  Ash
                                  • simon le bonS Offline
                                    simon le bon
                                    Hi all,
                                    New to the thread, interested & with no experience. 😉
                                    Do you remind this work done by shareck 👍 😮
                                    SketchUp + Sketchyphysics + Twilight= 4x4 Vehicule Animation!
                                    And this extraordinary work by Mateo Soletic on "animated Section Planes"
                                    And this strange SU + Virtual reality presented by Chris Fullmer
                                    Voodoo Camera Tracker Importer - March 9, 2011
                                    [url][/url]
                                    Here are "as is" my Camera Tools' links:
                                    Official Google SketchUp Blog: Introducing the Advanced Camera Tools
                                    Regular Polygon_[$] Keyframe Animation 1.4 (update 2011-05-27)
                                    macgile_CameraKeyMaker 1.0 (Update 2011-04-09)
                                    SU Animate
                                    RickWilson_CameraControls
                                    RickWilson_CameraDistance
                                    Jan Sandström/Pixero_JS Focal length
                                    ChrisFullmer/pixero_Camera Recorder (Pixero update)
                                    AidanChopra_Setting your field of view
                                    jharchar_Consecutive animations is it possible?
                                    😎 s
                                      Humpmetwice
                                      This is one I did with sections.
                                      [flash=500,400:3d3svcde]http://www.youtube.com/v/qOFGS3Wwh4Y?fs=1&hl=en_US[/flash:3d3svcde]
                                      • ashscottA Offline
                                        ashscott
                                        Thats cool HMT, an amazing use of sections.
                                        I have investigated things a bit further and am quite impressed with keyframe animation. It isn't the dragon slayer I was hoping for but I think that is more of a sketchup problem than anything else.
                                        I had a brief tinker with simlab composer animation edition but am just not sold on it as it is a whole new software suite.....I know with SU based animation plugins at least I can come up with a hacky way of making things look right (using layers inventively can solve a lot of functional limitations), I'm not confident that I can do that with a 3rd party piece of software like simlab composer. It looks like a great bit of gear and come of the example animations are really impressive, but I'm afraid that I will go through the learning curve of the new software and find there is something it doesn't do so well. Wheras, I am confident I can get the job done with SU and plugins even if the workflow isn't ideal.....someone prove me wrong.....
                                        I was gonna try exporting my models from SU and use something like MAYA but a whole new software package to learn and $3500 bucks? C'mon, I'm not that dedicated! 😉
                                        Someone argue with me/convince me otherwise
                                          iichiversii
                                          check this out http://forums.sketchucation.com/viewtopic.php?f=323&p=372786 its coming soon, dont know much about it as of yet but ill let you know what its like once i try a trail version if any
                                          • ashscottA Offline
                                            ashscott
                                            That certainly looks impressive.....need to tinker
                                            • 2 / 3
