    Vray for Sketchup - Materials
    renderpluginsextensions
    62 Posts 19 Posters 91.4k Views 19 Watching
      Kaczor
      Hello everybody. I'm looking for sample scene with globe to render sample of material (example 1, example 2). I couldn't find it anywhere.
        I believe that they are Rhino scenes. Think I remember seeing a reference to it in the Rhino section over at ASGVis.
          chango70
          Anymore finds anyone?
            boo9ie
            Hy, i'm new here, so i appologize if i post in the wrong place.
            My problem is i recently started using vray for sketchup, actually, i'm still learning. As i red the manual for vray, i discovered there is something missing from my program. This might sound stupid, but i don't know if i have vray materials. In the manual it shows that if i right click on a surface, there should be "V-ray for sketchup"...in my model, it does not appear...
            Does this mean i have no materials, or i haven't installed vray properly...i tried to download materials for vray, but i don't know where to copy them..
            please help. Thank you
              It is because you are using the first version of VfSU
              Since SR1.0 the menu was not there because all materials are automatically linked.
              When asking questions it'd useful to post what version of VfSU you are using.
              There is the first version, that didn't list any version number.
              SR1.0 - v1.00.74
              SR1.5 - v1.05.30
              And now the latest which is a complete rewrite that provides OSX support:
              v1.48.?? (can't remember exactly what is the latest revision number)
                I'm sorry - you do NOT have the original version. But you are reading the manual for the original version.
                  ali64risk
                  hi
                  i have a question about Displacement...
                  please see the attached file by the link below:
                  http://www.2shared.com/file/PlBGMQqP/Desktop.html
                  it contains vismat material and visopt options which I used in my rendering.
                  when I render first skp, the result is the first jpg...
                  but when I add a simple plane without Displacement (second skp), the Displacement of first plane is gone (as you can see in second jpg)!
                  please tell me what is wrong here?
                  • andybotA Offline
                    andybot
                    @ali64risk said:
                    hi
                    did you read this post? This may answer your dilemna.
                    http://forums.sketchucation.com/viewtopic.php?f=322&t=28593
                      ali64risk
                      thank you Andy...
                      my problem solved
                        ali64risk
                        hi...
                        i have a problem with vray texture color.
                        I chose a texture in:
                        vray --> material editor --> Diffuse --> texture editor (m) --> textBitmap
                        how can I change the color of texture for vray rendering, like what we do in sketchup rendering in
                        sketchup --> materials --> edit --> color
                        does any one know how I can solve this problem?
                        thank you
                          @ali64risk said:
                          hi...
                          thank you
                          Change the colour with an image editor, like PhotoShop or Gimp. VfS doesn't support the colour adjustments in SU.
                            ali64risk
                            @thomthom said:
                            @ali64risk said:
                            hi...
                            thank you
                            thanx...
                            and one thing more:
                            is there any way for changing textures width and height in vray like what we do in:
                            sketchup --> materials --> edit --> texture
                            (I am using V-Ray 1.48.91 td)
                              You use SketchUp to do that - VfS uses the width and height set in SU.
                              Update to the latest - 1.49.01. Lots of bugs are fixed.
                                ali64risk
                                @thomthom said:
                                @ali64risk said:
                                is there any way for changing textures width and height in vray like what we do in sketchup?
                                thank you Thomas...
                                but what you said is exactly my problem
                                I used a material from:
                                Sketchup --> materials --> select --> Colors-Named
                                then:
                                Vray --> material editor --> maps --> bump (or displacement) --> texture editor --> TextBitmap
                                and I chose a texture to bump (displace) the color I had chosen.
                                how I can change the width and height for the bump (displacement) texture?
                                  Add a dummy texture in SketchUp. Just a tiny solid colour texture. It's required for SU to generate mapping data.
                                    ali64risk
                                    Thank you Thomas
                                    • V Offline
                                      valerostudio
                                      You will not be able to convert MAX VRay materials but you can take the diffuse, bump, reflection, etc maps and make your own materials from them. The best resource is the Chaos Group website, but you need to be registered. The other resource out there is http://luzindirecta.org/. I would not use the Material Studio if you are using the latest 1.49.01 version because a few things changed since that studio was created and I think it might be outdated. Can someone else confirm this? Your best bet is to take a few minutes and watch a couple of the videos on Chaos Groups YouTube Channel. You can watch the SU and Rhino videos because the principles are the same.
                                        ali64risk
                                        hi everyone
                                        i started to learn interior rendering with vfs
                                        I need some tips and techniques for how to provide light source and where to place it in closed rooms, and how to show lamps and lights in rooms.
                                        can anyone gives me some related links?
                                        • V Offline
                                          valerostudio
                                          I'm not sure why you are asking this in a materials posting, but as I always say, the tutorials on the Chaos Group YouTube page are worth their weight in gold. Watch all the ones for VR for SketchUp. You will be in good shape after that.
                                          http://www.youtube.com/user/ChaosGroupTV/search?query=sketchup
                                            ali64risk
                                            • 3 / 4
