    Vray for Sketchup - Materials
    renderpluginsextensions
    62 Posts 19 Posters 88.9k Views 19 Watching
      redot
      Will do.
      Cheers
      • alexandre skA Offline
        alexandre sk
        i also have to create my owns, but the most are terrible.
        i think this community is the perfect place to have a databank of vray for sketckup materials( .vismats ).
          raddern
          Hi, can someone help me please, I am using SketchUp 7.1 with the latest version of V-ray on a Mac 10.6.2 and every time I tried to use the material editor, SketchUp just quits. Even with vismat or jpg image by creating v-ray material in the material editor it quits and also when using the bump and displacement the same thing happens. Any ideas please.
            ScottPara
            I am not sure that sounds like a material editor issue. Sounds more like an installation problem. Have you uninstalled and then reinstalled Vray? Have you contacted Vray support with your issue. They are good about getting back to you.
            Scott
            Love the fact that some HATE my avatar.....
              raddern
              Thanks, I have not tried that yet but I have contacted them over a week and I am still waiting on them. Everything works, it renders and all the other parameters works fine. It only happens when am trying to import v-ray materials in to the materials editor and I don't know why.
              Thank you.
                remus
                Raddern, please dont post the same question multiple times. Nobody is more likely to answer your question because youve posted it 10 times.
                  raddern
                  That was not my intension and its the first time am using forum. I taught people are in to different topics and I am just trying to get help that all. Any way I tried the uninstall and reinstall but the same things happens, thanks.
                  • dkendigD Offline
                    dkendig
                    You said "every time I tried to use the material editor, SketchUp just quits". What do you mean by "use"? Are you opening the material editor? Are you rendering a material preview? Are you clicking on a material? Are you importing a material? Are you creating a material? Are you modifying a material? Are you editing a texture? Are you adding a texture? Are you removing a texture? Are you using a specific override map or setting? What are you doing? If the rest of your post was supposed to explain that, then I apologize for not being able to understand anything you're saying. We would like to help though, if we can. You said you tried to contact us about the issue, and you waited a week? How did you contact us? We don't use our forum as a point of contact. Email support@asgvis.com if you want us to answer you.
                    Devin Kendig
                    Developer
                      raddern
                      Hi, There were actually some issues with the new version of V-Ray after my last communication with the support team. I sent them the vistmat materials, they tried them and same thing happens, so they said they needed to do a patch. The issue was the importing of the vistmat materials that causes the problems.
                        Kaczor
                        Hello everybody. I'm looking for sample scene with globe to render sample of material (example 1, example 2). I couldn't find it anywhere.
                          I believe that they are Rhino scenes. Think I remember seeing a reference to it in the Rhino section over at ASGVis.
                            chango70
                            Anymore finds anyone?
                              boo9ie
                              Hy, i'm new here, so i appologize if i post in the wrong place.
                              My problem is i recently started using vray for sketchup, actually, i'm still learning. As i red the manual for vray, i discovered there is something missing from my program. This might sound stupid, but i don't know if i have vray materials. In the manual it shows that if i right click on a surface, there should be "V-ray for sketchup"...in my model, it does not appear...
                              Does this mean i have no materials, or i haven't installed vray properly...i tried to download materials for vray, but i don't know where to copy them..
                              please help. Thank you
                                It is because you are using the first version of VfSU
                                Since SR1.0 the menu was not there because all materials are automatically linked.
                                When asking questions it'd useful to post what version of VfSU you are using.
                                There is the first version, that didn't list any version number.
                                SR1.0 - v1.00.74
                                SR1.5 - v1.05.30
                                And now the latest which is a complete rewrite that provides OSX support:
                                v1.48.?? (can't remember exactly what is the latest revision number)
                                  I'm sorry - you do NOT have the original version. But you are reading the manual for the original version.
                                    ali64risk
                                    hi
                                    i have a question about Displacement...
                                    please see the attached file by the link below:
                                    http://www.2shared.com/file/PlBGMQqP/Desktop.html
                                    it contains vismat material and visopt options which I used in my rendering.
                                    when I render first skp, the result is the first jpg...
                                    but when I add a simple plane without Displacement (second skp), the Displacement of first plane is gone (as you can see in second jpg)!
                                    please tell me what is wrong here?
                                    • andybotA Offline
                                      andybot
                                      @ali64risk said:
                                      hi
                                      did you read this post? This may answer your dilemna.
                                      http://forums.sketchucation.com/viewtopic.php?f=322&t=28593
                                        ali64risk
                                        thank you Andy...
                                        my problem solved
                                          ali64risk
                                          hi...
                                          i have a problem with vray texture color.
                                          I chose a texture in:
                                          vray --> material editor --> Diffuse --> texture editor (m) --> textBitmap
                                          how can I change the color of texture for vray rendering, like what we do in sketchup rendering in
                                          sketchup --> materials --> edit --> color
                                          does any one know how I can solve this problem?
                                          thank you
                                            @ali64risk said:
                                            hi...
                                            thank you
                                            Change the colour with an image editor, like PhotoShop or Gimp. VfS doesn't support the colour adjustments in SU.
                                            • 3 / 4
