    Maxwell for SU VS Twilight
    extensions
    121 Posts 25 Posters 25.1k Views 25 Watching
    • F Offline
      frv
      Maxwell does lighting through emitters. That's a little less intuitive. But emitters have the advantage that they behave as materials on any surface. Emitters are also editable as materials to suit your lighting specifics. Its a bit difficult to explain to a newbie. At least I did not understand the meaning of all this. Only after a year or so my renders came to benifit from all the options I feel I can not do without now.
      After some time you will become really good at rendering images. I feel the energy spent on an application that can only bring you so far will frustrate soon or later.
      Limited material settings is a concerning flaw. Rendering is all about materials.
      Francois
      • jason_marantoJ Offline
        jason_maranto
        If you haven't already, you should watch these:
        301 Moved Permanently
        (www.maxwellrender.com)
        Best,
        Jason.
        • Z Offline
          Zoom123
          Best,
          Jason.
          I watched the first three. They are really good. I tried to find similar video tutorials for Twilight but I couldn't find any of the same quality. For newbies like me good training material is a huge plus.
          Does any of those videos shows how the artificial lighting with emitters should be done? Looking at the titles I didn't see anything. I also scanned the Maxwell for SU manual but I couldn't find any detailed instructions of how to do artificial lighting. Detailed info seems to exist only for the full Maxwell program which uses a different interface and I assume has functions that are missing from the free application.
            jason_maranto
            As far as normal emitters the parameters and ways to use emitters are exactly the same... so yes I would definitely read the main manual as well (and watch the rest of the videos).
            Maxwell is a powerful package, and there are alot of things you can do with it so it might also be nice to watch these:
            This was made for the regular plugin before FIRE was released but most of it still applies and it does show emitters in use.
            Also if you'd like to get really in depth then I do have a 8 hours commercial series as well:
            404: This page could not be found.VTC - Virtual Training Company
            Online video training courses
            (www.vtc.com)
            And again most of this still applies because the plugins are basically the same in most ways.
            There are a couple of other threads here worth reading to get answers to questions you may have:
            http://forums.sketchucation.com/viewtopic.php?f=80&t=41040
            http://forums.sketchucation.com/viewtopic.php?f=80&t=41511
            I learned a great deal when I was beginning by joining the Maxwell forum and using the search function to read tips,tricks, and ideas from other users... as a free version user you do not get posting privileges but anybody can read and there really is a massive amount of information available there for free if you are willing to look for it:
            Maxwell has strengths and weaknesses (like any package), there is no perfect render engine -- but overall I find the UI to be easy to understand and use and I love the quality of the final images.
            Best,
            Jason.
            • N Offline
              notareal
              If you are just learning Twilight, maybe look trough the Best Of Tips and Tricks topic.
              For Thea Render maybe first look trough video-tutorials. Keep in mind that Thea is still relatively new renderer and all features, like full integration with various modeling apps are still in the oven.
              Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                bravoddb
                Hi, I have both, Twilight and Maxwell render for su, I have bought both, so I will not talk about the free version.
                Twilight have the feature to put lamps, Maxwell not, just emitters, I had difficults most of the time wih the reversed faces, I applyed in both sides the emmiter materials and then they don't emmit any light.
                Maxwell seems to be faster, but with the draft engine, with production engine, seems to take the same time as twilight. Twilight has other engines that are not unbiased and they are faster.
                Reflections and bumps, are easy to make in both, but in Maxwell in think there is a plus in bumps.
                No diplacement in both.
                About resolution, Ibelieve that i enough, but some times not very often, the clients ask for resolutions above 3000.
                I found them both very usefull, but I hope Maxwell make some changes that fixes bugs, and add some features.
                I really like them both. But surely I can recomend, Thea Render, or Octane Render with a good Nvidia Geforce gtx card.
                Thea is very stable, never fails, a lot of materials at the licensed useres date base.
                Bravoddb
                  jason_maranto
                  Maxwell supports regular displacement and vector displacement as well as pretesselated displacement.
                  Maxwell also has a large materials database that you can use for free here: http://resources.maxwellrender.com
                  Best,
                  Jason.
                  • Z Offline
                    Zoom123
                    Jason, from the comparison here http://www.maxwellrender.com/index.php/home/maxwell_for_sketchup/faq Maxwell for SU doesn't seem to be missing much from Maxwell Render Suite. Is this indeed the case? (there is a quite big price difference)
                    What are "Multilight" and "Render Channels"? Are these features that Twilight has?
                    One thing that I like in Twilight are the quick render presets which you can use to get a result quickly. This is a good thing when you are learning and you test a lot of things with "trial and error". Does Maxwell offer anything similar?
                    But I must say that the materials database of Maxwell seems huge compared to what is offered by Twilight? Is there an online database for Twilight compatible materials that is close to what is offered by Maxwell?
                    • Z Offline
                      Zoom123
                      You can use any materials made in Kerkythea with Twilight and I can tell you that Kerkythea's material editor is quite powerful. 😉
                      Here are some links for Kerkythea's materials.
                      http://www.kerkythea.net/forum/viewtopic.php?p=57370#p57370
                      http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=select&id=3
                      Thanks massimo. Still the way they have materials organized at Maxwell seems better with all 4000 materials in one searchable database. On the other hand the ability to create materials with Kerkythea which is free is a big plus, since from what I understand to create materials for Maxwell you need to buy the Studio which is very expensive.
                      • massimoM Offline
                        massimo Moderator
                        You can use any material made in Kerkythea with Twilight and I can tell you that Kerkythea's material editor is pretty powerful. 😉
                        • massimoM Offline
                          massimo Moderator
                          I'm not a huge fan of big databases of materials. I mean you can see zillions of renders with exactly the same wood floor... I think it's better if you have the possibility to create many different kind of materials, some examples, understand how they are made and then experimenting using your creativity.
                            bjornkn
                            What? Can't you make your own textures in Maxwell, like using your own bitmaps for wallpaper, tiles etc?
                            That would be a big con in my book.
                            How about using a spherical camera? Not that useful if you're limited to 3000px wide, but still..
                              jason_maranto
                              Multilight is a tool which will allow you to change the intensity of the individual lights sources during and after the render process... you can do lighting animations with it as well.
                              Render Channels are special renders meant to help with post processing -- things like shadow passes and Z-Depth.
                              The Maxwell Render Suite is definitely the tool to use if you are a rendering professional (as in you make your living rendering) -- the Maxwell for SketchUp plugin is a better choice for the occasional renderer.
                              Either way as a beginner it's best if you use the free tools until you get a feel if this is "your thing".
                              No presets.
                              Best,
                              Jason.
                                jason_maranto
                                Yes you can make your own texture-based materials within the plugin, but for more complex materials it's best to use MXED which is part of the full suite.
                                No spherical camera.
                                Best,
                                Jason.
                                  jason_maranto
                                  One thing to understand about the price difference is that the full Render Suite includes all the plugins for any app they support for free and all of that is cross platform as well for free. This makes it a really nice solution for people who work with multiple modeling packages on a regular basis... as I said before, it's meant for people who make a living rendering (not necessarily modeling).
                                  For instance the Maxwell Render Suite comes with all of this for free:
                                  Plugins for modeling packages:
                                  1. 3dsMAX
                                  2. Archicad
                                  3. Bonzai3D
                                  4. Cinema 4D
                                  5. Form·Z
                                  6. Houdini
                                  7. Lightwave
                                  8. Maya
                                  9. Microstation
                                  10. Modo
                                  11. Rhinoceros
                                  12. SketchUp
                                  13. Softimage
                                  14. Solidworks
                                  Plugins for post-processing packages:
                                  1. After Effects
                                  2. Nuke
                                  3. Photoshop
                                  As well as a dedicated stand-alone Studio environment to work with models from packages that are not supported by plugins. And of course the Suite is supported on Windows, Mac, and Linux.
                                  Also as an aside (to no one in particular), the overreacting on hearsay or conjecture is pretty amusing the first dozen times it happens but after a while it gets pretty tiresome -- before jerking the knee in overreaction perhaps some slight investigation about the facts is best.
                                  Best,
                                  Jason.
                                  • andybotA Offline
                                    andybot
                                    Best,
                                    Jason.
                                    lol, isn't that what forums are for... to hear the same questions and incorrect information repeated over and over. I think people are a little more savvy than to believe everything they read right away (at least I like to think so.)
                                    I think you've done a great job explaining your product. I've been following your posts and announcements with interest and when I have time I intend to give maxwell a try.
                                    Andy
                                      jason_maranto
                                      Andy
                                      I like to think so too -- but I'd like to help prevent bad information from circulating (if I can) only to make the comparisons between engines based on the very real differences.
                                      BTW to be clear I don't work on Maxwell, I'm just a enthusiastic user -- however, I do tutorial videos for software and Maxwell is one of the 5 software's I teach (SketchUp is another).
                                      Best,
                                      Jason.
                                      • Z Offline
                                        Zoom123
                                        First thank you for the info you gave so far.
                                        I would be very glad if I could be given a comparison between the engines based on the very real differences. Actually that is what I was asking, the pros and cons of each. It seems there is nobody that knows both applications well enough to do this.
                                          jason_maranto
                                          I haven't looked at twilight for quite some time, so I would be no help there but it seems to me that you already have quite a bit of information in regards to the 2 engines within this thread -- the only way you'll likely get more is by actually trying them.
                                          If you do, give back to the community by posting your thoughts and the reasons you came to the conclusions you did.
                                          Also don't underestimate the value actually working within the UI and workflow -- if it doesn't work for you then it doesn't matter how nice the results other people get are.
                                          Best,
                                          Jason.
                                          • Z Offline
                                            Zoom123
                                            I installed both applications and I am trying them. I might even add the 14 day Shaderlight Trial to the mix!
                                            • 1 / 7
