    Maxwell for SU VS Twilight
    extensions
    121 Posts 25 Posters 37.3k Views 25 Watching
    • F
      frv
      SRX,
      maybe you should explain "lots of limitations" and "half way"when you post "With Maxwell for SU you can do it half way...(low resolution, lot of limitations...)"
      You also post Maxwell Studio is better. Most Sketchup users for Maxwell never use Studio. Its also not better but something very different for a different purpose.
      There is no such renderapp which is the best. The are all different and depending on your goals and needs you will choose a render app that fits your workflow.
      Since there are free versions try them all before you spend months, or years mastering one of them. Do not let someone tell you which one to use.
      Francois
      • srxS
        srx
        Well I was talking about my opinion based on experience with demo's of all rendering engines on the market.
        As far as I know Maxwell for SU commercial has resolution limit of HD resolution. Twilight has not.
        This difference is crucial for professional usability.
        Twilight is very user friendly for speedy results with its material templates etc. Maxwell for SU I just tried once. It's very good, but IMO only a bait for the real thing... I again suggest Thea. It has faster IR engine than Maxwell, IMO, and much cheaper than Maxwell suite.
        I agree, but also hearing from other people could be useful and time saving.
        www.saurus.rs
        • Z
          Zoom123
          Hello Francois,
          While both application are supposed to be relatively easy compared to some other similar programs, they are still not as easy that a newbie like me can learn them good enough within a few days to make a decision. (and I don't want to spend more time than that)
          What I am looking for is not necessarily an answer that "X is better" (unless X is indeed better in almost all aspects), but rather the pros and cons of each application when compared to each other to help me decide which one would be better for me.
          For example (totally random points which are probably false):
          Maxwell SU is easier to learn for a complete newbie
          Adding realistic artificial lights with Twilight is much easier
          Maxwell SU renders faster
          There is a free training course for Maxwell SU that will get you up to speed faster
          Twilight has a large and friendly online community while any kind of support for the free version of Maxwell SU is very limited.
          Maxwell SU doesn't support X and Y while Twilight does.
          etc
          I would be grateful if anybody who knows both applications could offer me such a pros/cons list, even if it wasn't complete.
          • Z
            Zoom123
            srx, HD limitation is not a problem for me as I am not a pro. In fact I would start with the free/demo versions that offer even lower resolutions.
            Is Twilight more user friendly? If that is indeed the case then this is important to me.
            What are the other limitations of Maxwell for SU compared to Twilight?
            • F
              frv
              SRX, what do you mean by a faster IR engine than Maxwell ?
              ZOOM123,
              the problem is that that are hardly any people who are equally experienced with both app's. I know Maxwell very well, have a look at our website http://www.fillieverhoeven.nl and http://www.3dfv.nl and see that all renders are Maxwell and a lot of models done in SU and Modo.
              I have tried many among them Vray. If you have any questions concerning Maxwell I can answer them for you.
              Realistic light with Maxwell is very simple.
              Maxwellrender has a great forum. Especially the Sketchup forum is very fast in answering any question, friendly as well.
              Maxwell does X & Y as well, assuming you mean rendering an elevation without perspective. Set up a camera with a long focal distance. I render many floor plans and elevations.
              Maxwell SU free version is limited for resolution as I understand.
              If you are interested in a render application you will not make you final decision when still a newbie. After some time, maybe months or years later you will. For me it became Maxwell since it produces superb render quality with a minimum of setup. It also works like a virtual world as far as lighting and camera setup. I almost feel like I am not really rendering but just putting my models in the sun or under a real light. I also like Maxwell for starting up a render very quick for a first look. Most other app's I used take more time from pushing the render button to the first rude image. This makes Maxwell for me a perfect design tool, even more so than just a render app for the final presentations.
              Francois
              • Z
                Zoom123
                Thanks Francois,
                I installed both and I started reading their manuals and playing with them.
                The installation of Twilight was basically one click, while for Maxwell i was a bit more involved (nothing too difficult though)
                One thing I noticed is that Twilight has specific tools for adding lights while for Maxwell this seems to be done with emitters which doesn't seem to be as direct and intuitive.
                • andybotA
                  andybot
                  I've recently started using twilight, whereas my main render engine is vray. (Because of the limitation of vray to export animations - particularly if objects are animated.) My main gripe thus far is IMO severely limited material settings. I intend at one point to explore making my own, but haven't had a chance to look into that. I also don't like the render quality as much, but that's just my opinion again. Besides these negatives, I find it quite satisfactory for my purposes. Easy to use, good output, and good range of fast or quick render settings.
                  • F
                    frv
                    Maxwell does lighting through emitters. That's a little less intuitive. But emitters have the advantage that they behave as materials on any surface. Emitters are also editable as materials to suit your lighting specifics. Its a bit difficult to explain to a newbie. At least I did not understand the meaning of all this. Only after a year or so my renders came to benifit from all the options I feel I can not do without now.
                    After some time you will become really good at rendering images. I feel the energy spent on an application that can only bring you so far will frustrate soon or later.
                    Limited material settings is a concerning flaw. Rendering is all about materials.
                    Francois
                    • jason_marantoJ
                      jason_maranto
                      If you haven't already, you should watch these:
                      http://www.maxwellrender.com/index.php/home/maxwell_for_sketchup/tutorials
                      Best,
                      Jason.
                      • Z
                        Zoom123
                        Best,
                        Jason.
                        I watched the first three. They are really good. I tried to find similar video tutorials for Twilight but I couldn't find any of the same quality. For newbies like me good training material is a huge plus.
                        Does any of those videos shows how the artificial lighting with emitters should be done? Looking at the titles I didn't see anything. I also scanned the Maxwell for SU manual but I couldn't find any detailed instructions of how to do artificial lighting. Detailed info seems to exist only for the full Maxwell program which uses a different interface and I assume has functions that are missing from the free application.
                        • jason_marantoJ
                          jason_maranto
                          As far as normal emitters the parameters and ways to use emitters are exactly the same... so yes I would definitely read the main manual as well (and watch the rest of the videos).
                          Maxwell is a powerful package, and there are alot of things you can do with it so it might also be nice to watch these:
                          This was made for the regular plugin before FIRE was released but most of it still applies and it does show emitters in use.
                          Also if you'd like to get really in depth then I do have a 8 hours commercial series as well:
                          http://www.vtc.com/products/Google-SketchUp-to-Maxwell-Render-Workflow-Tutorials.htm
                          And again most of this still applies because the plugins are basically the same in most ways.
                          There are a couple of other threads here worth reading to get answers to questions you may have:
                          http://forums.sketchucation.com/viewtopic.php?f=80&t=41040
                          http://forums.sketchucation.com/viewtopic.php?f=80&t=41511
                          I learned a great deal when I was beginning by joining the Maxwell forum and using the search function to read tips,tricks, and ideas from other users... as a free version user you do not get posting privileges but anybody can read and there really is a massive amount of information available there for free if you are willing to look for it:
                          http://www.maxwellrender.com/forum/index.php
                          Maxwell has strengths and weaknesses (like any package), there is no perfect render engine -- but overall I find the UI to be easy to understand and use and I love the quality of the final images.
                          Best,
                          Jason.
                          • N
                            notareal
                            If you are just learning Twilight, maybe look trough the Best Of Tips and Tricks topic.
                            For Thea Render maybe first look trough video-tutorials. Keep in mind that Thea is still relatively new renderer and all features, like full integration with various modeling apps are still in the oven.
                            • B
                              bravoddb
                              Hi, I have both, Twilight and Maxwell render for su, I have bought both, so I will not talk about the free version.
                              Twilight have the feature to put lamps, Maxwell not, just emitters, I had difficults most of the time wih the reversed faces, I applyed in both sides the emmiter materials and then they don't emmit any light.
                              Maxwell seems to be faster, but with the draft engine, with production engine, seems to take the same time as twilight. Twilight has other engines that are not unbiased and they are faster.
                              Reflections and bumps, are easy to make in both, but in Maxwell in think there is a plus in bumps.
                              No diplacement in both.
                              About resolution, Ibelieve that i enough, but some times not very often, the clients ask for resolutions above 3000.
                              I found them both very usefull, but I hope Maxwell make some changes that fixes bugs, and add some features.
                              I really like them both. But surely I can recomend, Thea Render, or Octane Render with a good Nvidia Geforce gtx card.
                              Thea is very stable, never fails, a lot of materials at the licensed useres date base.
                              Bravoddb
                              • jason_marantoJ
                                jason_maranto
                                Maxwell supports regular displacement and vector displacement as well as pretesselated displacement.
                                Maxwell also has a large materials database that you can use for free here: http://resources.maxwellrender.com
                                Best,
                                Jason.
                                • Z
                                  Zoom123
                                  Jason, from the comparison here http://www.maxwellrender.com/index.php/home/maxwell_for_sketchup/faq Maxwell for SU doesn't seem to be missing much from Maxwell Render Suite. Is this indeed the case? (there is a quite big price difference)
                                  What are "Multilight" and "Render Channels"? Are these features that Twilight has?
                                  One thing that I like in Twilight are the quick render presets which you can use to get a result quickly. This is a good thing when you are learning and you test a lot of things with "trial and error". Does Maxwell offer anything similar?
                                  But I must say that the materials database of Maxwell seems huge compared to what is offered by Twilight? Is there an online database for Twilight compatible materials that is close to what is offered by Maxwell?
                                  • Z
                                    Zoom123
                                    You can use any materials made in Kerkythea with Twilight and I can tell you that Kerkythea's material editor is quite powerful. 😉
                                    Here are some links for Kerkythea's materials.
                                    http://www.kerkythea.net/forum/viewtopic.php?p=57370#p57370
                                    http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=select&id=3
                                    Thanks massimo. Still the way they have materials organized at Maxwell seems better with all 4000 materials in one searchable database. On the other hand the ability to create materials with Kerkythea which is free is a big plus, since from what I understand to create materials for Maxwell you need to buy the Studio which is very expensive.
                                    • massimoM
                                      massimo Moderator
                                      You can use any material made in Kerkythea with Twilight and I can tell you that Kerkythea's material editor is pretty powerful. 😉
                                      • massimoM
                                        massimo Moderator
                                        I'm not a huge fan of big databases of materials. I mean you can see zillions of renders with exactly the same wood floor... I think it's better if you have the possibility to create many different kind of materials, some examples, understand how they are made and then experimenting using your creativity.
                                        • B
                                          bjornkn
                                          What? Can't you make your own textures in Maxwell, like using your own bitmaps for wallpaper, tiles etc?
                                          That would be a big con in my book.
                                          How about using a spherical camera? Not that useful if you're limited to 3000px wide, but still..
                                          • jason_marantoJ
                                            jason_maranto
                                            Multilight is a tool which will allow you to change the intensity of the individual lights sources during and after the render process... you can do lighting animations with it as well.
                                            Render Channels are special renders meant to help with post processing -- things like shadow passes and Z-Depth.
                                            The Maxwell Render Suite is definitely the tool to use if you are a rendering professional (as in you make your living rendering) -- the Maxwell for SketchUp plugin is a better choice for the occasional renderer.
                                            Either way as a beginner it's best if you use the free tools until you get a feel if this is "your thing".
                                            No presets.
                                            Best,
                                            Jason.
                                            • 1 / 7
