    Working with wrought iron
    39 Posts 11 Posters 7.0k Views 11 Watching
    • BoxB
      Sorry, didn't realise it was the thickness you wanted, Follow me as a native tool or Profile builder, http://www.smustard.com/script/ProfileBuilder might help.
        http://www.drawmetal.com/
        maybe?
        • B
          bjornkn
          Have you tried ShapeBender?
          • hellnbakH
            hellnbak
            maybe?
            Thanks, there are several pgms there that look very promising. How the heck do you keep track of all the stuff available out there for SU?
            • hellnbakH
              hellnbak
              Thanks for all the fast responses, I will check out each suggestion and see what they can do. Maybe they won't work for this particular problem but will come in handy for other things. Thanks again
                Once you get that wrought iron work down you can work on something like this:
                @N08/5970412478/" target="_blank" rel="noopener noreferrer nofollow ugc">
                http://farm7.staticflickr.com/6027/5970412478_9bb8eea837.jpg
                πŸ˜„
                • hellnbakH
                  hellnbak
                  πŸ˜„
                  Yeah right, as soon as I get that brain implant I've been saving up for πŸ˜†
                    Christmas is just around the corner. Maybe Santa will leave you one in your stocking. πŸ˜† πŸ˜†
                    • jeff hammondJ
                      you have the hard part done which is drawing all those curves πŸ˜„
                      see this sketchup for the rest:
                      iron.skp
                      that's all done with regular sketchup tools..
                      i would recommend one plugin for this stuff and it's called recurve.rb.. it has an option for you to select one of the line segments then it will select all the connecting segments to it and join them into one curve.
                      [edit] here's a link to recurve.rb:
                      http://forums.sketchucation.com/viewtopic.php?t=36822
                      [edit2] just noticed your desired output has sharp ends instead of the square ones in my drawing.. i think you can figure that bit out yourself πŸ˜‰
                      • gillesG
                        gilles
                        And the way to make it for real:
                        http://www.youtube.com/watch?feature=player_detailpage&v=l1_tF67B9CA
                          Cool! Thanks for that link. I made something similar in silver and in copper when I was in fine art school many moons ago. I used them for handles on some small vessels I made. It was fun to watch one being made in iron, though.
                          • hellnbakH
                            hellnbak
                            That really was cool. So tell me, I assume the bar was made up of four bars, so how was it made "solid" except for the section that was twisted?
                              It's welded together at the ends.
                              • hellnbakH
                                hellnbak
                                Actually the scroll work on my model does need the square ends. The pointy ends just happened to be on the example I pulled from the warehouse.
                                Thanks for the skp file, it's so tempting to just use it (not that I would do anything like that 😎 )but this weird model is gonna need a fair amount of this stuff so I just gotta buckle down and get it done. Probably the only time I'll ever need anything like this since I only work with car models, but what the hey.
                                • hellnbakH
                                  hellnbak
                                  Oh. I was hoping there was some magical secret to it πŸ˜’
                                    They're welded together by black dwarfs in underground caves. πŸ˜‰
                                    • jason_marantoJ
                                      jason_maranto
                                      I second http://www.drawmetal.com/tapermaker since it is made specifically for this purpose by somebody who does it for real.
                                      Best,
                                      Jason.
                                      • BoxB
                                        A traditional basket twist is made from one solid bar.
                                        You first have to heat the section you want to twist and cut it into four sections using a chisel.
                                        This takes quite a while and a lot of reheating. Then knock the four new bars back into place and then do the twist.
                                        • hellnbakH
                                          hellnbak
                                          Yippeeee!!! In Middle Earth, right?
                                            Where else?
