    SketchUp 8 M2 is out!
    157 Posts 49 Posters 41.2k Views 49 Watching
    • jbacusJ Offline
      jbacus
      1. After installing I now have a major grayed out context menu.
      2. Can't run on two machine at same time.
      Hi Ken,
      Glad you were able to get back to a working state in time to finish your project. When that's through, I think that we can probably troubleshoot the problems you reported.
      1. Some things about the Ruby API did change to support plugin installers. Grayed-out context menus are typically a problem with one or more of the scripts you have installed.
      2. Sounds like you may have the same issue wrt licensing as Jeffโ€“ if you have a network license (even a "single seat" network license) you'll have to make some changes to your configuration. Fill out this form and we'll get back to you as soon as we can with additional info.
      3. Not sure why you'd be seeing a lag with either tool activation or drawing a line. If you can get me more information about that I'll see about getting you some specific troubleshooting help.
      "...exaggerate the essential and leave the obvious unclear." --Vincent Van Gogh
      John Bacus
      jbacus@sketchup.com
      • ChiefwoodworkerC Offline
        Chiefwoodworker
        @jbacus said:
        @chiefwoodworker said:
        The biggest problem is in printing to scale.
        LayOut is the better solution to this problem and it contains many tools that will help you print more effectively to scale.
        See my reply to Jeff Hammond on this issue. LayOut is not a solution for those who do not have a Pro license which most of my students do not. Besides, a bug is a bug and should be fixed, especially if it has been around for 8 major version releases and numerous maintenance releases. This just isn't very professional of Google and its SketchUp team. But I will live and use SketchUp anyway ;<)
        Joe....
        http://www.srww.com
        • jbacusJ Offline
          jbacus
          I teach the free version of SketchUp in addition to using the Pro license for my own work so Layout is not a general solution.
          If you're teaching SketchUp to students, an 'Education' license may be the best solution. SketchUp Pro is available for cheap (sometimes free) to schools, teachers and students. Are you teaching in a context that makes you eligible for that program?
          John Bacus
          jbacus@sketchup.com
          • jeff hammondJ Offline
            @jbacus said:
            I'll leave it to the Sales gang to get you sorted out officially but it looks to me like you have a single-seat network license, not a single-user license. Fill out the form I referenced above and we'll get to you as soon as we can.
            i contacted sales via your link.. fingers crossed ๐Ÿ˜„
            thanks for the help!
              Chiefwoodworker
              Hi John,
              I teach at local community colleges and woodworking schools. I don't know if that qualifies me for an Education license, but I will look into it. Thanks for the heads up.
              Joe....
              http://www.srww.com
              • kenK Offline
                ken
                Hi Ken,
                Note jbacus
                I am familiar with the grayed out context menu and adjust my plugins to get rid of this problem and for ver 8.0.481 I had a workable setup. I even modified some plugins that use the context menu to use a tool bar or if there is a choice I will in the script, I will modify the script to not use the context menu choice. So I was happy and working.
                However, I upgraded, and I mean that all I did, and wham, the worst grayed out I have seen. Sometime the "make components or group" option was grayed out in the edit menu. So now that I have re-installed ver 8.0.481, I am back to where I was, with a working program. So to me, this upgrade was the problem.
                So, please someone find an answer.
                Thanks for your help
                Ken
                  TriciaS
                  Hi Ken,
                  Is it possible to send me your plugins directory (zipped up) so that I could try to troubleshoot the issue with the gray menus?
                  I'll send you my contact info.
                  Thanks in advance,
                  Tricia
                  Google
                    so official advice is for me to close sketchup on one machine prior to launching it on another.. ๐Ÿ˜•
                    whatever, i'm done blabbing about it..
                    i'm glad the scenes are fixed for lion and the new ruby management looks great..
                    waiting for someone to make an rbz public so i can try it out.
                      basically, if you zip your my.rb and rename it my.rbz, SU Extension Manager will load it from your 'download destination' directly into 'Plugins', saving your Users all the grief of what do I put where.
                      To quote one of our SketchUcators
                      • jgbJ Offline
                        jgb
                        I know this may sound like a dumb question ๐Ÿ˜ณ
                        I have SU 8 and have not upgraded to M1 version (just lazy)
                        Can I simply install M2 or do I need to install M1 first โ“
                        jgb
                        • pbacotP Offline
                          Where can we learn about turning plugins on and off? In my preferences / extensions there are only a few listed that may be checked off, just as previously. And as previously you need to restart to unload them.
                          EDIT: Wait NVM. This is what I was referring to. Not a built-in On / off like I hoped.
                          Mac:
                          To disable plugins:
                          Launch SketchUp.
                          Try to recreate the bug.
                          Navigate to Window > Ruby Console.
                          In the Ruby Console, type: Sketchup.plugins_disabled = true.
                          Exit SketchUp and relaunch. User supplied Ruby plugins should now be disabled and will continue to be disabled until you re-enable them.
                          Try to recreate the bug again. If you can't recreate it, then one or more of your Ruby plugins are the culprit. You may consider moving Ruby files out of the Plugins folder to isolate which plugin is causing the issue.
                          I imagined that the "Plugin Manager" that our ruby developers have been talking about is more like a full list of plugins installed and a simple way to turn them on and off. I hope that is a goal. An installer (and that's great, even though I had no problem with it) is not a manager.
                          • jbacusJ Offline
                            jbacus
                            SketchUp already includes a system that allows Ruby developers to make their tools into "Extensions", which can then be turned on/off via the Extension Manager. To learn more about that, see this blog post: "Turn Your Plugin into an Extension"
                            Additionally, SketchUp now includes a system that allows developers to make their Extensions easily installable. To learn more about that, see this blog post: "Distribute your Plugin as One File"
                            Further, there are new hooks in the API that allow folks who want to build more customized "Plugin Managers" the things they'll need to do so. Expect more news on that in the weeks/months to come as developers come up to speed with the new capabilities.
                            There is great diversity in the way that Ruby (scripts, plugins, extensions) have been created by the developer community, making it difficult for us to come up with one new system that is capable of managing them all. With SU8M2, we're trying to lay down some groundwork that improves manageability over time.
                            John Bacus
                            jbacus@sketchup.com
                            • KrisidiousK Offline
                              Krisidious
                              Sounds good John... thanks for the "One on One"... We appreciate it.
                              By: Kristoff Rand
                                jbacus...
                                Indeed... ๐Ÿ˜ฒ
                                I do have a vague 'plan' [when time allows!] to 'Extensionalize' my main scripts and then offer .zip/.rbz versions for alternative installation... if you have v8+++...
                                Thereby, up-to-date Users can install the updated tools via Preferences - but it needs considerable [unpaid] effort on my part...
                                AND there are many 'legacy' Users who will still need the .zip version...
                                ๐Ÿ˜ฒ
                                  avariant
                                  Are these new "hooks" published somewhere? Have the API docs been updated?
                                  • opalO Offline
                                    opal
                                    Another user with the greyed out menu items here.
                                    I drew a basic rectangle an as usual it surfaced backface up so I right clicked and the option to reverse faces is greyed out.
                                    Using the drop down edit menu, selecting the same face, reverse faces is no longer greyed out.
                                    .. interesting to note, I did nothing to change any settings anywhere - thought gee.. I should go get some screen shots since there were other greyed down items on the edit list and it seemed to have fixed itself.. until I drew another basic rectangle and tried again to right click.
                                    Using the drop down edit menu instead of right click seems to fix it.. odd
                                    I know.. I should be in the newbie forum
                                      You have too many Plugins loading that are making 'Commands' - an issue reported in several other threads... and awaiting Google's fix ๐Ÿ˜ฎ
                                      • opalO Offline
                                        opal
                                        ty, I read this thread and saw it was somehow plugin related. I thought it was interesting that using the drop down menu to access those commands made them work and might be a useful bit of information.
                                          Krisidious
                                          as I said before guys... this is a perfect opportunity to start fresh with a new plugin folder. that means installing each plugin fresh 1 at a time and checking to make sure it's up to date. and while your at it look for redundant plugins and outdated ones. chances are this will fix most of your greyed out issues.
                                          I don't think we've come up with a number of plugins where it reaches greyed out by bloat. it will happen at some point but I'm not sure at what number of plugins.
                                          By: Kristoff Rand
                                          • jbacusJ Offline
                                            jbacus
                                            No- SU8M2 does not require that you install M1 first.
                                            John Bacus
                                            jbacus@sketchup.com
                                            • 3 / 8
