    Menu Options Keeps Graying Out!
    55 Posts 15 Posters 11.4k Views 15 Watching
      • F Offline
        flyashy
        Okay end of experiment.
        in short,
        Heavy file + Lots of plugins + repeated right click = grayed out menu.
        back to a less engorged plugins directory...
        sigh
          Jinx!
          Now I got it as well with a model I worked on. But the odd thing is that Selection Toys didn't grey out. o_O
          • EscapeArtistE Offline
            EscapeArtist
            I have a workaround that has worked for me without removing any plugins.
            When your right-click menu grays out, go to EDIT > and at the very bottom of the drop-down should the item that you just selected/right-clicked. Click that, and the same options will be available as your right-click. Select what you wanted and continue. The right-click menu will be available again until the next gray-out. Repeat for each gray-out.
            • F Offline
              flyashy
              thanks escapeartist,
              i must try that out next time i get the jinx πŸ˜‰
                EscapeArtist
                I've noticed something else. This error seems to occur after an auto-save event.
                  hmm... that should be easy to test. what happens if you disable auto-save?
                    EscapeArtist
                    Sketchup crashes and I lose my work... πŸ˜† πŸ˜’
                      lapx
                      This does not work for me. Is google finding a fix for this or is there a workaround. Its becoming impossible to work! Help?
                        EscapeArtist
                        IIRC it was a plugin issue, not a Sketchup issue.
                        Check this thread here:
                        404 Not Found
                        (forums.sketchucation.com)
                        I had the same issue, but when I updated my TTLib and Tools on Surface plugins, everything worked.
                        Hope this helps.
                        • kenK Offline
                          ken
                          Well I have update to M2 and now I really have a grayed out context menu. Make component is out in the context menu. This is the worst I have seen the grayed out menu and sometimes even the "make component" is grayed out in the edit menu.
                          I have started to disable all the plugins that I have installed lately. Haven't found a problem plugin.
                          Ken
                            It is not a single plugin - not unless you have one of Fredo's old plugins. It's a limitation in SketchUp when there's are a large number of plugins installed that add menus and toolbars.
                            So until Google has fixed this issue in SketchUp, the only remedy for this is to trim down the number of plugins installed. Be harsh about which ones you really use. When I have reinstalled my computers I no longer copy all plugins from the old to the new, I install them one by one as I need them. That way I ensure I have the latest and I also don't have any plugins I have no use for.
                            Annoying, I know.
                            • kenK Offline
                              ken
                              Annoying, I know.
                              Thomthom
                              I know it is not a single plugin. I was working, and did not have the grayed out problem. Stopped working, installed the newer version and wham, had the grayed out problem, worst than I ever had before. I am going backwards in time with the installed plugins to try to determine which plugins are the problems. It just seemed to me that the newer version is more sensitive to the grayed out problem, since that was the only change I had made.
                              Ken
                                lapx
                                I agree w ken. I didnt begin to have this problem until su 7 n 8.
                                I had tons of plugins loaded before n less loaded now and the problem
                                Persist. I think its a google problem. They must have some way of accomodating.
                                This grey out menu and the rearranging of buttons are my
                                Biggest complaints to google sketchup! Please look into!
                                • jeff hammondJ Offline
                                  they will look into it. you need to help them though.
                                  zip up your plugin folder and send it to them.
                                  they can't fix a problem if they don't know what the problem is.
                                    lapx
                                    Thanks Jeff,
                                    Will do when i return to my laptop.
                                      EscapeArtist
                                      I've got scads of plugins, so I don't think it's the total number. I may not have as many as you, though.
                                        Unless you got one of the very old plugins that had a bug in the context handler - then the problem is too many plugins - or rather, too many menu and/or toolbar buttons. Technically it's too many UI::Command objects. Bug confirmed by Google.
                                        • dukejazzD Offline
                                          dukejazz
                                          I will tell you how at My tips about running more than one sketchup
                                          http://forums.sketchucation.com/viewtopic.php?f=79&t=40254
                                          • dukejazzD Offline
                                            dukejazz
                                            These 8 rules may help
                                            1 (Limits gray-out) Keep startup and console loaded plug-ins to few and small. Most important limit over using context plugins.
                                            2 (Keeps Skp file size small) In model, components or materials get rid of unused model items: (Via) Save and purge.
                                            3 Build your model with components. Have a saved library to work from. Hide thing you don't need to see for speed. Remember rule 2
                                            4 (Watch memory flow:) With Task manager. Watch google memory sizes.
                                            5 (Max File save size) Max save file size is by power of zoom extents, and by zoom in/out decreases the save size?
                                            6 (Polyreduce if you can) Overworking objects gives higher code counts. Keep objects hollow. Delete unused or unneed lines.
                                            7 (Bug splats) Keep register clean. Delete extra ToolbarsUser-Bars and ToolbarsUserCustom-Bars, If you get to 1000 it will splats on you, also it will take away loaded memory space too.
                                            8 (Locks or slows runway Bug splats)HKEY_CURRENT_USER\Software\Google\SketchUp8
                                            a (Find) ToolbarsUser-Summary and ToolbarsUserCustom-Summary.
                                            b (via) Right-click_ permission special _ to you _write_on and read_off. others, Resticted and system read only. This (Locks) Toolbars to fix num or slows runway growth of ToolbarsUser.
                                            • 3 / 3
