    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin]Hole on Solid tool v1.6.3 upadate Jan 09, 2012
    134 Posts 43 Posters 86.3k Views 43 Watching
      ๐Ÿ‘
      Excellent tool thank you
      • V Offline
        Vicspa
        YES, excellent tool, Thank you
        • gillesG Offline
          gilles
          Trying to play with it I got this:
          Error: #<NameError: uninitialized constant BST_HoleOnSolid::TST_common>
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:37:in reset' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:31:in initialize'
          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:318:in new' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:318 /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:37:in call'
          SU8 Mac 10.6.
          • Didier BurD Offline
            Didier Bur
            Does this tool "autoloads" when starting sU, since there is no rb file in the Plugins folder ?
            DB
            • utilerU Offline
              utiler
              Hi tak2hata, well done!!!! A good solution to an age old issue among SU'ers...
              A few questions:
              1. Does the 'profile' need to be a group?
              2. Does the tool require a face or edges to create the hole in the resulting group? The reason why I ask is it would be good to extend this tool for edges to cut holes in groups [walls]. Say a window component is inserted; a nested group of edges could create the void in the wall and leave the window geometry.... not sure if this is possible.
              ๐Ÿ‘
              Just Curious...
              • mitcorbM Offline
                mitcorb
                I like the way this tool rolls. Very effective in the video.
                • sadyoS Offline
                  sadyo
                  SU8 Mac 10.6.
                  this happens to me anyway ๐Ÿ˜•
                  SU Pro 8.0.4811, Win7/x64
                    Very interesting and useful plugin. It works very well. Thank you.
                      tak2hata
                      Hi,Gilles and Sadyo.
                      I forgot fixing the problem.
                      It corrected in v1.01.
                      Didier Bur...Thanks for your advice.
                      Thanks.
                      by TAK2HATA
                        tak2hata
                        A few questions:
                        ๐Ÿ‘
                        Hi utiler.
                        Your second question is the direction of the this plugin's future.
                        1st question is No.
                        It need only face for hole.
                        by TAK2HATA
                        • utilerU Offline
                          utiler
                          FANTASTIC!!!!!!
                          Just Curious...
                          • gillesG Offline
                            gilles
                            It works fine now.
                            Great job thank you. ๐Ÿ‘
                            • gillesG Offline
                              gilles
                              Playing with it I notice that it does not detect hole in face, this could be a great improvement.
                                New concept of Boolean opรฉrations! ๐Ÿ˜Ž
                                  RichardCherry
                                  Wow!
                                  Fantastic tool. Thank you very much ๐Ÿ˜„
                                  • sadyoS Offline
                                    sadyo
                                    Great Thanks Tak2Hata, it working like a charm now
                                    • utilerU Offline
                                      utiler
                                      @tak2hata said:
                                      Hi utiler.
                                      1st question is No.
                                      Tak2hata, another question:
                                      When you create the whole in the solid it appear to expolde the profile shape; eg: circle / polygon.... Can you force the resulting edges to be hidden?
                                      thanks mate!! ๐Ÿ‘
                                      Just Curious...
                                      • mitcorbM Offline
                                        mitcorb
                                        Hi. I just tried to extract with Winzip eval version and got this in error output:
                                        Extracting file: C:\Program Files (x86)\Google\Google Sketchup 7\Plugins\HoleOnSolidTool_v1_01.zip
                                        Extracting to "C:\Program Files (x86)\Google\Google Sketchup 7\Plugins"
                                        Use Path: yes Overlay Files: no
                                        Unable to process "HoleOnSolidTool_v1_01".
                                        Severe Error: Not permitted or able to create an output directory.<<
                                        Anyone have any ideas on this? Perhaps 7zip? Note that I am placing this in x86 where my Sketchup 7 version resides. Is this tool only for Sketchup 8?
                                          RichardCherry
                                          So this plugin only works with the "Pro" version? The free version does not have solids so I am unable to use it ๐Ÿ˜ž
                                          Thanks for the great plugin even though I am unable to use it.
                                            How did you come to that conclusion? Looking through the thread it appears that other users of the free version of SketchUp have been using the plugin. The free version of SU doesn't have the Solid Tools but it still identifies solid groups and components.
                                            • 4 / 7
