    [Plugin]Hole on Solid tool v1.6.3 upadate Jan 09, 2012
    134 Posts 43 Posters 105.2k Views 43 Watching
    • T
      tak2hata
      @utiler said:
      Hi tak2hata, well done!!!! A good solution to an age old issue among SU'ers...
      A few questions:
      1. Does the 'profile' need to be a group?
      2. Does the tool require a face or edges to create the hole in the resulting group? The reason why I ask is it would be good to extend this tool for edges to cut holes in groups [walls]. Say a window component is inserted; a nested group of edges could create the void in the wall and leave the window geometry.... not sure if this is possible.
      Hi utiler.
      Your second question is the direction of the this plugin's future.
      1st question is No.
      It need only face for hole.
      by TAK2HATA
      • utilerU
        utiler
        FANTASTIC!!!!!!
        Just Curious...
        • gillesG
          gilles
          It works fine now.
          Great job thank you. 👍
          • gillesG
            gilles
            Playing with it I notice that it does not detect hole in face, this could be a great improvement.
              New concept of Boolean opérations! 😎
                RichardCherry
                Wow!
                Fantastic tool. Thank you very much 😄
                • sadyoS
                  sadyo
                  Great Thanks Tak2Hata, it working like a charm now
                  • utilerU
                    utiler
                    @tak2hata said:
                    Hi utiler.
                    1st question is No.
                    Tak2hata, another question:
                    When you create the whole in the solid it appear to expolde the profile shape; eg: circle / polygon.... Can you force the resulting edges to be hidden?
                    thanks mate!! 👍
                    Just Curious...
                    • mitcorbM
                      mitcorb
                      Hi. I just tried to extract with Winzip eval version and got this in error output:
                      Extracting file: C:\Program Files (x86)\Google\Google Sketchup 7\Plugins\HoleOnSolidTool_v1_01.zip
                      Extracting to "C:\Program Files (x86)\Google\Google Sketchup 7\Plugins"
                      Use Path: yes Overlay Files: no
                      Unable to process "HoleOnSolidTool_v1_01".
                      Severe Error: Not permitted or able to create an output directory.<<
                      Anyone have any ideas on this? Perhaps 7zip? Note that I am placing this in x86 where my Sketchup 7 version resides. Is this tool only for Sketchup 8?
                        RichardCherry
                        So this plugin only works with the "Pro" version? The free version does not have solids so I am unable to use it 😞
                        Thanks for the great plugin even though I am unable to use it.
                          How did you come to that conclusion? Looking through the thread it appears that other users of the free version of SketchUp have been using the plugin. The free version of SU doesn't have the Solid Tools but it still identifies solid groups and components.
                            RichardCherry
                            I tried the plugin with groups and components and it would not pick the solid feature. So I assumed it only worked with the pro solids.
                              Post an example SKP file in which it doesn't work.
                                RichardCherry
                                Certainly. When I get home this evening I'll post an skp file. Any and all help is appreciated 😄
                                Edit:
                                I figured out what I was doing wrong 😄
                                You have to have the profile lined up with the solid in order for it to work. I had my profile off to the side. My mistake, sorry.
                                Gorgeous plugin.
                                • B
                                  boilingsnow
                                  really powerful tool. thank you very much.
                                    Edit:
                                    Gorgeous plugin.
                                    Yep, that would do it.
                                    • mitcorbM
                                      mitcorb
                                      As a followup on my previous comment, I did manage to extract and copy drag from the Winzip UI into the plugins folder the two files .rb and icon. When I tested in Sketchup 7, selection would not progress beyond the prompt for the first object/ group which was simply a cubic form made into a group and a circle oriented appropriately. Previously, in XP, I could right click on the zip file already in place in the plugins folder, "extract to here" and see the files deployed appropriately. Any thoughts on what I have managed to miss in the provided info?
                                      • T
                                        tak2hata
                                        Hi mitcorb.
                                        This plugin use property of volume.
                                        Sketchup supports solid in later version of 8.
                                        As matter of fact,I think this script may work ,when it judges the Group(Component) is solid.
                                        I must create the method of that judgment for that purpose.
                                        I inquire later.
                                        Thanks.
                                        by TAK2HATA
                                          @mitcorb said:
                                          Hi,tak2hata:
                                          Here is the Ruby Console error message:
                                          Error: #<NoMethodError: undefined method volume' for #<Sketchup::Group:0xa789048>> C:/Program Files (x86)/Google/Google Sketchup 7/Plugins/create_hole_on_solid.rb:298:in onLButtonDown'
                                          I'm guessing you are not using SketchUp 8 - group.volume is a method available since SU8 when SU introduced solids.
                                            Ah - just noticed the file path of your SketchUp in the error - you're on SU7. That would be the problem.
                                            • 1 / 7
