    [Plugin]Hole on Solid tool v1.6.3 upadate Jan 09, 2012
    134 Posts 43 Posters 105.2k Views 43 Watching
    • T
      tak2hata
      Hi,everyone.
      This is tool for hole openning tool on solid.
      #General disclaimer
      #I MAKES NO GUARANTEE OF VALIDITY about this script.
      #Please use this script at your own risk.
      tool icon( included in zip file)
      DONWLOAD:
      Get the latest version from the PluginStore:
      http://sketchucation.com/resources/pluginstore?pln=hole_on_solid
      or AutoInstall from within SketchUp using the SketchUcation Tools
      Update in Nov 29 ,2011:
      Bug fix:I forgot erase line about "TSTcommon.langconv".
      Update in Dec 02 ,2011:
      Improved.work on Sketchup ver7( perhaps ver6).And create smooth subtracted faces from face include curve.
      Update in Dec 03 ,2011:
      Bugfix and small Improved.correct the hole shifted.
      Update in Dec 14 ,2011:
      Create hole from compoennt that has cut openning option.
      Hole on unoccluded faces group(Tentative)
      Update in Dec 16,2011
      :Bugfix:It happened when select solid by component.
      Update in Jan 03,2012
      :Add new function,Punching multiple holes.
      Modified Topics:Jan 05,2012.Title Did not correct. 😄
      Update in jan n09,2012.
      Bug fix.The hole from polygon mades smoothed side faces. it's improved.
      I found from dave's post,and irwanwr's message.Thanks.
      This zip file includes "create_hole_on_solid.rb" and "icon_openning_lg.png".
      Copy these files to "plugins" folder.
      I created this tool for using with Building structure tool.http://forums.sketchucation.com/viewtopic.php?f=323&t=35798
      But I think easy to use so It became independent tool.
      Hole On Solid v1.6.2update 2012-01-03.
      New fucntion video here.
      http://youtu.be/vW3Ed2ch8L4
      [flash=640,480:3kujc8uh]http://www.youtube.com/v/vW3Ed2ch8L4[/flash:3kujc8uh]
      Please watch this video "how to use hole on solid tool"
      http://youtu.be/Xgpw3IBuoqU
      [flash=640,480:3kujc8uh]http://www.youtube.com/v/Xgpw3IBuoqU[/flash:3kujc8uh]
      Where download My Building Smart Modeling tool for sketchup
      Hole on Solid Tool
      http://forums.sketchucation.com/viewtopic.php?f=323&t=41582
      Solid quantify
      http://forums.sketchucation.com/viewtopic.php?f=323&t=41120
      WHD Parametric Component
      Coming soon.
      Thanks.
      by TAK2HATA
        Excellent tool thank you
        • V
          Vicspa
          YES, excellent tool, Thank you
          • gillesG
            gilles
            Trying to play with it I got this:
            Error: #<NameError: uninitialized constant BST_HoleOnSolid::TST_common>
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:37:in reset' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:31:in initialize'
            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:318:in new' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:318 /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:37:in call'
            SU8 Mac 10.6.
            • Didier BurD
              Didier Bur
              Does this tool "autoloads" when starting sU, since there is no rb file in the Plugins folder ?
              DB
              • utilerU
                utiler
                Hi tak2hata, well done!!!! A good solution to an age old issue among SU'ers...
                A few questions:
                1. Does the 'profile' need to be a group?
                2. Does the tool require a face or edges to create the hole in the resulting group? The reason why I ask is it would be good to extend this tool for edges to cut holes in groups [walls]. Say a window component is inserted; a nested group of edges could create the void in the wall and leave the window geometry.... not sure if this is possible.
                Just Curious...
                • mitcorbM
                  mitcorb
                  I like the way this tool rolls. Very effective in the video.
                  • sadyoS
                    sadyo
                    SU8 Mac 10.6.
                    this happens to me anyway 😕
                    SU Pro 8.0.4811, Win7/x64
                      Very interesting and useful plugin. It works very well. Thank you.
                      • T
                        tak2hata
                        Hi,Gilles and Sadyo.
                        I forgot fixing the problem.
                        It corrected in v1.01.
                        Didier Bur...Thanks for your advice.
                        Thanks.
                        by TAK2HATA
                        • T
                          tak2hata
                          A few questions:
                          Hi utiler.
                          Your second question is the direction of the this plugin's future.
                          1st question is No.
                          It need only face for hole.
                          by TAK2HATA
                          • utilerU
                            utiler
                            FANTASTIC!!!!!!
                            Just Curious...
                            • gillesG
                              gilles
                              It works fine now.
                              Great job thank you. 👍
                              • gillesG
                                gilles
                                Playing with it I notice that it does not detect hole in face, this could be a great improvement.
                                  New concept of Boolean opérations! 😎
                                    RichardCherry
                                    Wow!
                                    Fantastic tool. Thank you very much 😄
                                    • sadyoS
                                      sadyo
                                      Great Thanks Tak2Hata, it working like a charm now
                                      • utilerU
                                        utiler
                                        @tak2hata said:
                                        Hi utiler.
                                        1st question is No.
                                        Tak2hata, another question:
                                        When you create the whole in the solid it appear to expolde the profile shape; eg: circle / polygon.... Can you force the resulting edges to be hidden?
                                        thanks mate!! 👍
                                        Just Curious...
                                        • mitcorbM
                                          mitcorb
                                          Hi. I just tried to extract with Winzip eval version and got this in error output:
                                          Extracting file: C:\Program Files (x86)\Google\Google Sketchup 7\Plugins\HoleOnSolidTool_v1_01.zip
                                          Extracting to "C:\Program Files (x86)\Google\Google Sketchup 7\Plugins"
                                          Use Path: yes Overlay Files: no
                                          Unable to process "HoleOnSolidTool_v1_01".
                                          Severe Error: Not permitted or able to create an output directory.<<
                                          Anyone have any ideas on this? Perhaps 7zip? Note that I am placing this in x86 where my Sketchup 7 version resides. Is this tool only for Sketchup 8?
                                            RichardCherry
                                            So this plugin only works with the "Pro" version? The free version does not have solids so I am unable to use it 😞
                                            Thanks for the great plugin even though I am unable to use it.
