    [Plugin] QuadFaceTools
    680 Posts 116 Posters 771.9k Views 116 Watching
      Bug Alert
      I just discovered an issue where the Hidden property of triangulated quads might get lost when you copy / import a quad face mesh into a model with existing scenes. In some cases the mesh can be recovered by using the Sandbox To Quads and then updating the scenes - but there is a potential for losing the Quad definition of the mesh.
      Issue logged at: https://bitbucket.org/thomthom/quadface-tools/issue/57/hidden-property-is-lost-when-activating
      Will find a solution to this. Might end up reverting back to the old way of defining Quads. Sorry for the inconvenience this might cause.
      • jarynzlesaJ
        jarynzlesa
        this plug-in deserves three thumbs up.
        http://www.vizualizaceschodiste.mypage.cz/
        • L
          Luigi987
          Amazing plugin!
          Though, on various occasions it does this:
          http://puu.sh/8aAc
          the corners always get messed up no matter how perfectly I make them.
          Not sure if this is a bug or just me being dumb, help appreciated though~
            I'm suspecting it's the shape of the quads in the corners that makes the UV mapping distort in such a manner. I'm guessing it's native quads - so I'd try to triangulate them (using the Triangulate method in QuadFace Tools.)
            Can you share a sample model?
            • L
              Luigi987
              Tried triangulating with said option, no luck.
              Here's the model part.
              example.skp
              • T
                Thiago Luz
                This plugin only works for now with 4 faces between lines is this?
                I'm sorry, I do not speak English and use an online translator does not always help a lot!
                Because I would like to map quilts, but I see that this is not possible, as this is the following example:
                http://farm7.static.flickr.com/6107/6321101719_f427ed0d38_b.jpg
                ERROR: The request could not be satisfied
                (farm7.static.flickr.com)
                  Yes, they must be quads, and you also needs to have a good topology of quads for the tools to work well.
                    Here's your sample model remapped ( I erased the hidden geometry stuff and purged before reposting to keep filesize down )
                    The screenshot got annotations to what I did.
                    example mapped.skp
                    • T
                      Thiago Luz
                      Still, a great plugin, thanks!
                        Thom,
                        Is it possible that you'll mimic Selection Toys and allow the user to choose what's on the toolbar?
                        Or am I missing the option?
                          That is in fact something I want to implement. The features and commands for this plugin has grown a lot since first version, and there's several commands still without toolbar buttons and more will come. yaiks...
                          Though first I need to get 0.6 out asap - that address the issue with scenes breaking the quads... 😞
                            That's good to hear ☀
                            Any Bezier Surface news on the horizon?
                              I hope so... 😞 I've really blown my internally estimated timeline for this... Gotto get my focus straight! First sign will be that beta for Vertex Tools open up.
                              • romboutR
                                rombout
                                i cant find a option to make quads of a selection?!
                                    You need to select a quad to then convert the mesh to quads.
                                      What kind of selection do you got?
                                      There are a couple of commands to Convert to quads:
                                      The left command "Convert Triangulated Mesh to Quads" will try to find quads in the mesh - you need to either selected a native quad or two triangles as a starting point.
                                      The right one is converting Sandbox Tools type of quad mesh into QuadFace quads.
                                      Maybe you can explain, and show, what mesh you have and what you try to convert?
                                        @tig said:
                                        [attachment=0:zfyitihf]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:zfyitihf]
                                        That's Triangulate and Remove Triangulation you highlighted... don't think it's what he's looking for.
                                        • V
                                          vouda
                                          Big congratulations for your plugin!
                                          But I have a problem. When I render with su podium the aspect ratio of edited surfaces colapses.
                                          Any solution?
                                            I do not understand what you mean by that. Got screenshot and possibly a sample model?
                                            • 11
                                            • 12
                                            • 33
                                            • 34
                                            • 10 / 34
