    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 295.6k Views 135 Watching
    • DanielD Offline
      Daniel
      I've always known about hiding geometry by holding the shift key with the eraser, but last week I just noticed the "hidden" check box on the entity info window. ๐Ÿ˜ณ
      My avatar is an anachronism.
      • Bob JamesB Offline
        Bob James
        Never paid any attention to this thread until today ๐Ÿ˜ณ
        @tig said:
        .....select all faces with the same material as the one highlighted... then RickW pointed out that it is already a standard built-in tool under Select... ๐Ÿ˜ณ
        OMG ๐Ÿ˜ฒ I soooo needed this yesterday ๐Ÿ‘Š
        This thread is one of the greatest tutorials ever made!
        Now to Page 1 and read (and write down) all of the golden nuggets in this thread.
          Jim
          Yeah, this thread would make a great mini-pub for SCF. I'd probably even buy a tree-ware version as I can't retain online info as well as I can with a good sit with a book.
            make a unique texture from a portion of another!
            Seems only from the V7 and + ๐Ÿ˜‰
              Bob James
              SU Duh.pdfCompilation of DUHs
              This is an unedited regurgitation of all of the DUH items. Some are repeated.
                Cool idea! ๐Ÿ˜Ž
                I will translate it when I arrive at this page! ๐Ÿ˜„ (in fact a sort of speedy copy / past because ...
                I am now at the page 7 on French Section ! ๐Ÿ’š
                • dereiD Offline
                  derei
                  What the... ๐Ÿ˜ฒ?
                  6.I could change the radius of a circle that's been extruded - maybe using Scale Tool ๐Ÿ˜•
                  19. finding that by holding the spacebar down you can control the zoom in so you don't zip past the
                  object your zooming to
                  - really ? It doesn't seem to happen anything different when I zoom and keep spacebar pressed.
                  ...and the list can continue.
                  Maybe those should be verified, or given more detailed explanations. After all, its purpose is to teach the noobs, not to confuse them more ๐Ÿ’š
                  EDIT:
                  22. Also, any selection that only contains a single entity (not only a line) cannot be made a
                  component (or group) this way. If you select a sphere (with a bounding box), there's a single
                  "surface" selected only and you right click to turn it into a group/component in vain.
                  - try pressing G or use the Make Component icon ... ๐Ÿ˜‰ maybe is not in vain
                    1. Also, any selection that only contains a single entity (not only a line) cannot be made a
                      "surface" selected only and you right click to turn it into a group/component in vain. - try pressing G or use the Make Component icon ... maybe is not in vain
                    That's true - thus the inconsistency. SU should work the same way no matter where we access the same tool.
                    • H Offline
                      HFM
                      Found out last week that you can also color lines in your model ๐Ÿ˜ฒ
                      It even works with custom drawing styles ๐Ÿ˜„
                      Colored lines ^^
                      • jeff hammondJ Offline
                        What the... ๐Ÿ˜ฒ?
                        you can change the radius via the entity info dialog.. the same way you would change the radius of a circle except that it also works if the circle has been extruded
                        • dereiD Offline
                          derei
                          Heh, that's cool ๐Ÿ˜„ Inattentional blindness is to blame... I've seen that number of segments is grayed-out, and I didn't seen that the radius is fully editable.
                            you have a crazzy plug about that! ๐Ÿ˜‰
                            ChrisP_Color_edge By C Plassais ๐Ÿ˜Ž
                              d12dozr
                              What the... ๐Ÿ˜ฒ?
                              You can use the Move tool on the cardinal points to change the radius of an extruded circle as well
                              Nifty!
                              http://goo.gl/f7ooYh
                              • gillesG Offline
                                gilles
                                Did you know this one?
                                • dereiD Offline
                                  derei
                                  AWESOME !!! ๐Ÿ˜ฒ This is something I never would guess. Thank you! ๐Ÿ˜‰
                                  • gillesG Offline
                                    gilles
                                    works also with polygones.
                                    Rereading the user manuel is fully instructive.
                                      brandy20
                                      ๐Ÿ˜ฎ another one to add yo the list of my uncountables duh! in the last two years...
                                      Another big duh! for me, to realize just yesterday evening of this very instructing topic. Must surf more carefully through this forum. ๐Ÿ˜ณ
                                        ๐Ÿ˜ฒ
                                        no.. i didn't.
                                        that's pretty sweet.. now, i'm left wondering if i have a use for it ๐Ÿ˜„
                                        • daleD Offline
                                          dale
                                          This one was new to me (Doh)
                                          I was doing a lot of similar push pulls on a model (without joint pushpull), and inadvertently double clicked on the second one, and SketchUp duplicated the depth of the first pushpull.
                                          So i just went along double clicking, and the action repeated itself exactly.
                                          Boy could I ever have used this alot.
                                            Works the same for Offset too - double-click repeats the last used value...
                                            • 34
                                            • 35
                                            • 4 / 35
